TS3DV642 - Could you please tell me the max VCC supply current(Icc) of the following condition.4k2k30p (3Gbps)?
Guru 21045 points
Other Parts Discussed in Thread: TS3DV642, TS3DV642EVM
Hi, Andrew
Could you please tell us the following question.
[Question1]
Is Icc bigger than 50uA*?
*Icc=50uA(typ) @ VCC = 3.6 V, II/O = 0, Normal Operation , Mode, EN = H (datasheet page6)
<condition>
Signal of 4k2k60p passes the switch of TS3DV642.
[Question2]
Are there the results that TS3DV642 was used for on the following condition?
For example; TV , DSC , Camcorder etc
<condition>
2:1 switching at Signal of 4k2k60p
Kanemaru
  • Hi, Andrew
    How is the investigation after than going?
    Could you kindly give us an answer by the end of the week?
    We are looking forward to your reply.
    Kanemaru
  • Hello Hideto,
    What standard are you using for 4k2k60fps?
    Andrew
  • Hi, Andrew
     I apologize…
    Signal is 4k2k30p.
    4k2k60p is mistake.
    [Question1]
    <condition>
    Signal of 4k2k30p passes the switch of TS3DV642.
     [Question2]
    <condition>
    2:1 switching at Signal of 4k2k30p.
     Kanemaru
  • Hello Hideto,
    Max observed Icc <60 uA. The Icc of the device is not dependent on that data rate of the signal passing through the device.
    We tested the data rate of the 4k2k30p HDMI 1.4.  However we do not have any consumer equipment that can output this resolution but if you would like to test this, there is an EVM available on the web that would allow this kind of testing.
    http://www.ti.com/tool/ts3dv642evm
    Andrew
