TS5A3160: Details regarding TS5A3160 Make or Break function.
Part Number: TS5A3160
Are there more details regarding the TS5A3160 Make or Break feature? Are there other parameters to be aware of when designing with this feature? Only the Tmbb is noted with little detail
  • Hi Anvid,
    Only the Tmbb spec is needed when evaluating the make before break feature. The associated values for this spec are given under the different operating voltages which by your reference I assume you have seen. The test setup for that spec is also shown at the bottom of the datasheet if it needs to be referenced.
