I am trying to make project with this IC "TS5V522C" but I am confused by the statement on the datasheet that says
"The TS5V522C would bypass the VGA analog signal to a destination with less distortions. DDC Channel (SCA, SCL) may require to +5Vopen drain level at the VGA connector and it may require a pull up resistor on the destination side. Active undershoot-protection circuitry on the data ports of the TS5V522C provides protection for undershoots up to -2V by sensing an undershoot event and ensuring that the switch remains in the proper off state."
In another word, I don't know how I should make a complete circuit with this IC, I need to test this before I used it. I couldn't find the solid design for it yet.
Do you have any reference design circuit for this IC so I can use and test it?
Thank you for your support
