Other Parts Discussed in Thread: TS3DV642
I would like to multiplex 2 DRAM busses.
I would like to operate at 2 GHz or 4 Gb/s.
Would this speed be of concern for the TS3DDR4000? Is there another part that would be better?
The TS3DV642 appears to be intended for differential operation. Most of the signals I would pass thru it are single-ended.
Should that be a concern?
Can I consider CEC equivalent to the D pins? Essentially use it as another DQ pass through? Same performance characteristics?
Same for
HPD?
SCL?
SDA?
