TS3L301: TS3L301DGGR uses on single ended signal
Part Number: TS3L301
I need your help on uses of MUX switchTS3L301DGGR. Device has s good bandwidth and perfect fit for my application.  The only concern I see that  MUX switch TS3L301DGGR is targeted for differential Ethernet signal.  In my design I using this mux on single ended signal.
I am not able to find similar mux switch for single ended signal, so I am using this device.  Do you see any concern on using this device on single ended signal?
Need you support on the same.
Thanks & Regards,
Vikas Kumar (Wipro Ltd- Product Engineering Services)
+91 7842280750
  • Vikas,
    I searched "TS3l301 single ended" in the switches and mutliplexers search bar and found this post that says differential passive FET switches can be used in single ended applications.
    I do not see issue using TS3L301 in a single ended application.
    What are trying to interface that you need a 2:1 Ethernet switch with single ended signals?
    What is your high bandwidth requirement?  What is the single ended signal?  SPI, I2C, etc. ?
    Thank you,
    Adam
