Other Parts Discussed in Thread: TS12A44513
I noticed that TI sells analog switches. I am looking for any analog switch that have the highest possible off isolation value. Which analog switch part numbers do you suggest?
1) I am trying to prevent pins of a chip from making a connection when the switch is off. These pins are very sensitive. I did notice though that they don't make a connection when I apply a 1M ohm resistor across them. So I am looking for a switch that has an "off" isolation similar to this.
2) 3
3) DC
Jack,
If you are looking at isolating in a DC sense than you can look at the off state leakage current. Using the TI.com switch selection tool I have found TS12A44513 that specifies low off-state leakage current.
Thank you,
Adam
