What is the Off isolation from input to output over frequency? The datasheet lists an isolation number at 100KHz, but the signals I am using are in the MHz range.
Manuel,
Unfortunately, the off isolation plot is not in the TS3A5223 datasheet. A similar transmission gate switch with similar performance does have an isolation plot vs frequency.
What signals are you putting through the switch? Why level of isolation do you require for your application?
Thank you,
Adam
