I have 4 questions on TS5A22362 :
1. Not sure the meaning of Ron_flat. Could you please let me know detail info?
2. If the max current of customer's application is 160ma to 170ma, NORMAL: 100ma, is it ok for TS5A22362?
3, What do you mean of " Bandwith " in this device?
4. cstomer 's application is UART TX/RX and GND/VCC signal MUX. Does it ok with this device? Thanks.
Hi April,
I did a search on “Ron flat” on the E2E switches and muxes forum and found the below thread:
https://e2e.ti.com/support/switches-multiplexers/f/388/t/554350
Doing a search on “TS5A22362 uart” gives the below thread:
https://e2e.ti.com/support/switches-multiplexers/f/388/t/478447
Bandwidth is defined as the frequency at which the output is attenuated by 3 dB from the pass band (DC) response.
Please see below quick video training on mux Bandwidth:
Below is the absolute maximum rating for on state current specification in TS5A22362 datasheet for different setup condition, temperature and packaging.
What is your application scenario?
Thank you,
Helen
HI April,
A surface mount board is available, please see the TS5A22362 product page, under " tools and software" tab, under " device kits and evaluation modules".
Thank you,
Helen
