Other Parts Discussed in Thread: SN74CBTLV3125
Hi Team,
Are the following errors described in 8.1 Overview of the datasheet?
"The FET multiplexers and demultiplexers are disabled when the output-enable (OE) input is high."
Hi Team,
Hi Quote-san,
Thank you for answering.
I have one more thing I want to know.
The 8.1 Overview states that it is necessary to pull up OEpin at Vcc.
On the other hand, in 9.2.1.2 Detailed Design Procedure, OE is recommended to be pulled up with Vcc or pulled down with GND.
It is desirable that the switch be turned off at SB power on.
I am worried that the switch will be turned on in 8.1.
How should I handle OEpin?
Kenji
Kenji,
You may pull up or pull down the OE pin depending on what you what to default the switch state. The intent is to prevent that pin from floating and place the device in an unknown state which could result in excess current consumption.
Thank you,
Adam
