Other Parts Discussed in Thread: TS5A23160
Hi TI Team,
Can you please provide the best TI solution to Maxim MAX20336.
P2P is nice to have but not a must.
Thank you,
Liz
Hi Elizabeth,
The way to answer your question is to use the ti.com switch search tool. In order for a switch to be p2p ,it will need to have that same configuration and channel count.
The search tool below is filtered SPDT switch with 2 channels. Next you can sort these devices by on-resistance from least to greatest. And filter on "Powered off protection" so see best fit for your requirements.
TS5A23160 is a good option if you are not looking for p2p. It has low RON compared to TMUX136.
Please let me know if you have further questions.
Thank you,
Saminah
Saminah,
Thank you for the answer. However TS5A23160 does not have the -5.5V to +5.5V Analog Signal Range. What's our next best fit?
Thank you,
Elizabeth
Hi Elizabeth,
Please take a look at the recommendations in the device selection tool (link) to view the switches that support negative input voltages.
Saminah
