E2E,
I'm using 2x TMUX1308-Q1 in my system.
I want to know if I can connect the control pins A0-A2 of the two devices in parallel so that my MCU only needs 3 GPIO to control both muxes at the sames time. I have weak pull downs on the bus to avoid floating nodes but do I need to have a series resistor on each pin A0-A2 as well?
Also to save GPIO can I tie the EN pin directly to ground and have the device always enabled or do I need a weak pull down resistor as well?
Thank you,
Adam
