Other Parts Discussed in Thread: TMUX1574
Dear Sir,
We are currently using the part SN74CBTLV3257 as a switch to select I2S audio signals, however, we found noisy audio in the output when this part is added to the circuit. When this switch is removed and direct connect to the two I2S interfaces, then no noise is gone. We have tried several methods and still can't fix the noisy audio problem. Do you have any good suggestions to fix the problem?
Thanks for your support.
Kenneth Wong
