Other Parts Discussed in Thread: TS3USB221
I would like to ask if TS3USB221 can be use to switch I2C Signals?
Hi, Ivy,
Sorry for the late reply.
Yes you may use the TS3USB221 to switch I2C signals.
David
I am planning to use TS3USB221 for I2C mux, Do I need to provide pull ups on both sides of the MUX? what do you recommend?
Thank you.
regards,
Sneha
Hi Adam,
Thank you very much.
In our board, channel switching is not done during operation. It is controlled by a switch, and the channel will be selected prior to power on.
Pullups are provided on the 1D and 2D side, but not on the D signals. The artwork is almost finished. Is it mandatory to provide pull up on both sides, since there is no channel switching during operation?
regards,
Sneha
