When I use the Nortify routine that comes with TI, I get stuck in an infinite loop.
After the pause, I will be prompted to have several .c files not found at an address, but the beginning of these addresses are /db/vtree/library/trees. I don't have any address like that in ti.
After I manually add the .c file, the program will still fall into an infinite loop, which is in an infinite loop after running to IPC_start in the main program.
I am using ipc1-24-03-32.This is my project file, I hope you can help me answer the question.EP_Nortify.zip
