  • Resolved
Breakpoint Manager: Error programming AET Job: There is no AET resource to support this job.
Hi I am facing the above problem.
I am using TMS470PSF761 with CCS3.3 and emulator XDS510USB Debugger.
I am not able to put the breakpoint even debug option is enabled.
Please hel[p me on this.
Satheesh G
    Do you have the latest CCS 3.3 Service Release installed? Your CCS version number should be 3.3.82.13 if you do. if you do not, please install it and try again.
    If updating does not help, provide a few more details on the steps you are taking. Are you trying to set a breakpoint in flash? Do you have the profile clock enabled?
    ki
    Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
    Having CCS problems? Check out the CCS Troubleshooting Guide
    Looking for CCS Training? Check out the CCS Training Site
    Curious about the status of a bug and know the tracking ID? Track it via the public bug tracking portal
    NOTE: When a bug is filed and a tracking ID is provided, the thread may then be suggested as "TI Thinks Resolved". Why? Please read the first FAQ of the CCS Forum Guidelines & FAQ
  • In reply to Ki-Soo Lee:
    Thanks for your reply.
    I am using 3.3..80. If i use the same IDE for other board of TMS570PSF61A.0, i am able to put the break point.
    Only for TMS470PSF761 board i am not able to put the break point. My  doubt is whether any hardware that related to debugging is get damaged?
    I am not getting this manual SPNU124 also, please share this document if any one have this.
    Satheesh G
  • Guru 130130 points
    In reply to satheesh gannoju:
    Satheesh,
    satheesh gannoju
    SPNU124 is a 1998 document that was never available in the internet. The reason is because it refers to a debugger used before Code Composer Studio, therefore it is not useful at all.
    Rafael
    When posting, click on the link Insert Code, Attach Files and more... to attach images, files or use nice formatting.
    If my reply answers your question please click on the green button "This resolved my issue".
  • In reply to desouza:
    Problem is solved for me. i removed and connected XDS510USB again, then it starts working, i am able to put the break point.
    problem is solved, but still i am not getting how the problem rectified.
    anyway thanks for your quick support.
    Satheesh G
  • In reply to satheesh gannoju:
    I faced the same problem while using CCS Version: 4.2.3.00004.
    Reconnecting the evaluation board resolved the problem but I am not sure about the reason why it was happening ;-)
    Sagar
