Compiler/TMS570LC4357: armobjdump from ti-cgt-arm_20.2.1.LTS generates incorrect disassembly
Part Number: TMS570LC4357
Other Parts Discussed in Thread: RM48L952, , HALCOGEN
Is the armobjdump utility from ti-cgt-arm_20.2.1.LTS supposed to be able to generate correct disassembly?
Trying on some big and little endian out files shows incorrect disassembly.
1. armobjdump -d --source for a little-endian RM48L952 program produced:
Disassembly of section .text:
00000280 <systemInit>:
     280: f8 40 2d e9                   push    {r3, r4, r5, r6, r7, lr}
;     systemREG1->CSDISSET = 0x00000002U | 0x00000040U;
     284: d1 4f 0e e3                   <unknown>
     288: 42 c0 a0 e3                   mov     r12, #66
     28c: ff 4f 4f e3                   <unknown>
     290: ed 5f 0e e3                   <unknown>
     294: ff 5f 4f e3                   <unknown>
     298: 63 cf 84 e5                   str     r12, [r4, #3939]
;     while((systemREG1->CSDIS & 0x42U) != 0x42U)
     29c: 5f cf 94 e5                   ldr     r12, [r4, #3935]
     2a0: 42 c0 0c e2                   and     r12, r12, #66
     2a4: 42 00 5c e3                   cmp     r12, #66
     2a8: 5f cf 94 15                   ldrne   r12, [r4, #3935]
     2ac: 03 00 00 0a                   beq     #12 <$C$L2>
Which has some instructions as <unknown>. Whereas the output from gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-objdump -d --source was:
/* SourceId : SYSTEM_SourceId_006 */
/* DesignId : SYSTEM_DesignId_006 */
/* Requirements : HL_SR471 */
void systemInit(void)
     280:       e92d40f8        push    {r3, r4, r5, r6, r7, lr}
     284:       e30e4fd1        movw    r4, #61393      ; 0xefd1
     288:       e3a0c042        mov     ip, #66 ; 0x42
     28c:       e34f4fff        movt    r4, #65535      ; 0xffff
     290:       e30e5fed        movw    r5, #61421      ; 0xefed
     294:       e34f5fff        movt    r5, #65535      ; 0xffff
     298:       e584cf63        str     ip, [r4, #3939] ; 0xf63
     29c:       e594cf5f        ldr     ip, [r4, #3935] ; 0xf5f
     2a0:       e20cc042        and     ip, ip, #66     ; 0x42
     2a4:       e35c0042        cmp     ip, #66 ; 0x42
     2a8:       1594cf5f        ldrne   ip, [r4, #3935] ; 0xf5f
     2ac:       0a000003        beq     2c0 <systemInit+0x40>
2.  armobjdump -d --source for a for a big-endian TMS570LC4357 program produced:
00000020 <adcInit>:
;     adcREG1->RSTCR = 1U;
      20: e5 9f 0a 7c                   <unknown>
      24: e3 a0 c0 01                   biceq   r10, r0, r3, ror #1
      28: e5 80 c0 00                   sbceq   r8, r0, r5, ror #1
;     adcREG1->RSTCR = 0U;
      2c: e5 9f 0a 70                   andvc   r9, r10, r5, ror #31
      30: e3 a0 c0 00                   sbceq   r10, r0, r3, ror #1
      34: e5 80 c0 00                   sbceq   r8, r0, r5, ror #1
;     adcREG1->OPMODECR |= 0x80000000U;
      38: e5 9f 0a 68                   stmdavs r10, {r0, r2, r5, r6, r7, r8, r9, r10, r11, r12, pc}
      3c: e5 90 c0 00                   sbceq   r9, r0, r5, ror #1
      40: e3 8c c1 02                   sbceq   r8, r1, #58112
      44: e5 80 c0 00                   sbceq   r8, r0, r5, ror #1
;     adcREG1->CLOCKCR = 7U;
      48: e5 9f 0a 5c                   <unknown>
      4c: e3 a0 c0 07                   strbeq  r10, [r0, r3, ror #1]
      50: e5 80 c0 00                   sbceq   r8, r0, r5, ror #1
Which has some instructions as <unknown> and others which don't make sense. Whereas the output from gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-objdump -d --source was:
00000020 <adcInit>:
/* USER CODE END */
    /** @b Initialize @b ADC1: */
    /** - Reset ADC module */
      20:       e59f0a7c        ldr     r0, [pc, #2684] ; aa4 <adc1GetConfigValue+0x200>
      24:       e3a0c001        mov     ip, #1
      28:       e580c000        str     ip, [r0]
      2c:       e59f0a70        ldr     r0, [pc, #2672] ; aa4 <adc1GetConfigValue+0x200>
      30:       e3a0c000        mov     ip, #0
      34:       e580c000        str     ip, [r0]
    /** - Enable 12-BIT ADC  */
      38:       e59f0a68        ldr     r0, [pc, #2664] ; aa8 <adc1GetConfigValue+0x204>
      3c:       e590c000        ldr     ip, [r0]
      40:       e38cc102        orr     ip, ip, #-2147483648    ; 0x80000000
      44:       e580c000        str     ip, [r0]
  • Please submit the executable files used as the input to armobjdump.  Put them in a zip file and attach that zip file to your next post.  I'll use those files to file a bug against this object file dump utility.
    Thanks and regards,
    -George
  • In the attached zip file:
    1. RM48L952_rtiblinky.out and TMS570LC4357_TI_halcogen.out are the executable files used as the input, which were generated with the TI compiler.
    2. RM48L952_rtiblinky_armodjdump.dis and TMS570LC4357_TI_halcogen_armobjdump.dis are the disassembly outputs from ti-cgt-arm_20.2.1.LTS/bin/armobjdump
    3. RM48L952_rtiblinky_arm-none-eabi-objdump.dis and TMS570LC4357_TI_halcogen_arm-none-eabi-objdump.dis are the disassembly outputs from gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-objdump
    4. generation_of_output.txt is a record of the commands run to generate the disassembly.
    armobjdump_incorrect_output.zip
    For those commands I was using the --source option as well as -d as I found the armobjdump issue when trying to correlate the assembler generated against the source. I didn't include any source in the zip in the previous post, but with just the -d option then armobjdump is still generating incorrect disassembly.
  • Thank you for notifying us of the problem and submitting a test case.  I can reproduce the same result.  I filed the entry EXT_EP-9915 to have this investigated.  You are welcome to follow it with the link below in my signature.
    Thanks and regards,
    -George
