Following an upgrade from 10.1? to 10.2 the IDE fails to open cleanly. The IDE starts to render and then becomes inactive with a constant high CPU load. I am using Windows 10. When I open a second CCS and select a different workspace the second one successfully opens and builds projects. I can only kill the original CCS from task manager. Returning to the original workspace the working IDE it again fails to open with the same partially rendered IDE. There are multiple entries in the log file but all end with the same line (see below).
I have also uninstalled and re-installed 10.2 and get the same partial unresponsive IDE screen.
!ENTRY org.eclipse.e4.ui.workbench 4 0 2021-03-01 11:58:37.696
!MESSAGE Exception occurred while rendering: IDEWindow=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@41e9f86 (tags: [topLevel, shellMaximized], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {workspace_v10 - rfEasyLinkEchoRx_BF868_CC1310_tirtos_ccs/Common/rfRxTx.c - Code Composer Studio}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@5e46a125, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: 0, y: 0, width: 1384, height: 928)
!STACK 0
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(SWT.java:4701)
at org.eclipse.swt.SWT.error(SWT.java:4635)
at org.eclipse.swt.SWT.error(SWT.java:4606)
at org.eclipse.swt.graphics.GC.setForeground(GC.java:4344)
at org.eclipse.ui.forms.widgets.Section.onPaint(Section.java:384)
at org.eclipse.ui.forms.widgets.ExpandableComposite.lambda$0(ExpandableComposite.java:574)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4175)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1081)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:1654)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4816)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:348)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4827)
at org.eclipse.swt.internal.win32.OS.UpdateWindow(Native Method)
at org.eclipse.swt.widgets.Decorations.setVisible(Decorations.java:1312)
at org.eclipse.swt.widgets.Shell.setVisible(Shell.java:1958)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1267)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:747)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:680)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:768)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:739)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:733)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:717)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1086)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1049)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:660)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:559)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
