Current load of each core
Other Parts Discussed in Thread: TMS320C6678, SYSBIOS
Good day, dear friends.
We use Code Composer 5.5 and DSP - TMS320C6678. In our system we start any dsp algorithms of the different complexity on each core of this dsp. I need to know current load of each core. In other words I need to know how many tasks I can start on the one core.
Does Code Composer have those instruments ????
Or maybe SysBios has any functions that may give me this information ????
  • Any help would be appreciated.
  • Hi Oleg,
    Sorry for the delayed response.
    You can add the BIOS load module & instrumentation to your applications & view the CPU load using System Analyzer (part of CCS).  To add CPU load logging you need to add the following to your *.cfg file:
    var Load = xdc.useModule('ti.sysbios.utils.Load');
    Load.swiEnabled = true;
    Load.hwiEnabled = true;
    var LoggingSetup = xdc.useModule('ti.uia.sysbios.LoggingSetup');
    /* Enable CPU Load logging */
    LoggingSetup.loadLogging = true;
     *  Enable Task, Swi, and Hwi Load logging. This allows the Idle Task
     *  usage to make more sense. Otherwise Hwi and Swi load is factored into
     *  each task's usage.
    LoggingSetup.loadTaskLogging = true;
    LoggingSetup.loadSwiLogging = true;
    LoggingSetup.loadHwiLogging = true;
    LoggingSetup.loggerType = LoggingSetup.LoggerType_JTAGRUNMODE;
    There are several logger types available, so please take a look at the logging setup wiki for more details.  All of these settings can be set by the graphical config tool as well (UIA->LoggingSetup & BIOS->CPU Load).  After all this has been setup, you can view CPU load graphs using System Analyzer (wiki).
    Hope this helps,
    -- Emmanuel
  • Emmanuel. Many thanks. I will try your solution.
