• TIVATM C SERIES TM4C123G LaunchPad Evaluation Kit EK-TM4C123GXL
Other Parts Discussed in Thread: EK-TM4C123GXL
Good morning,
 I have just downloaded and installed Code Composer Studio and i want to connect with the
but i can't. Could you help me and give me advises about this and how can i connect it and function it ??
KInds Regards ,
Sotiris Katsimentes
  • Hello Sotirios,
    You will want to download TivaWare as well where we have many examples for this LaunchPad. Start with a simple one like blinky that can be found at [Install Path]\TivaWare_C_Series-2.2.0.295\examples\boards\ek-tm4c123gxl\blinky
    You may also need the USB drivers for the ICDI interface, and you can get those here: https://www.ti.com/tool/STELLARIS_ICDI_DRIVERS
    If Windows is not recognizing your device, download those and manually install them.
  • ''If Windows is not recognizing your device, download those and manually install them''
    Could you explain what you mean because i cant understand exactly ??
    how i can downlaoda  and from where ??
  • Hello Sotirios,
    I provided the download link in my prior post.
    If Windows is not recognizing the device, then in device manager you will have an unrecognized USB device. If that is the case, you should be able to ask Windows to install drivers for it via right click. It would then provide a popup asking to automatically look or manually search for them. Select manual search and point Windows to the downloaded USB drivers.
