Other Parts Discussed in Thread: MSP430F5340
customer, as well as TI, can reproduce an error message, that might be caused internally (compiler, parser).
Target MCU is MSP430F5340.
Customer is not able to continue his project!
Upgrading to latest MSP compiler and CCS did not solve the issue.
I attached a zip of the .pp files (“usci_uart.pp”fis the one which seems to be suspicious).
Pls contact me directly to provide you the full project when needed!
Also, I attached “console.txt” which is the full output of the build console (the error is on line 20.)
**** Build of configuration Semi-Auto for project PSE_TPS238xx ****
"C:\\ti\\ccsv7\\utils\\bin\\gmake" -k -j 8 all -O
'Building file: ../I2C_functions.c'
'Invoking: MSP430 Compiler'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="I2C_functions.d_raw" "../I2C_functions.c"
"../I2C_functions.c", line 60: warning #225-D: function "CS_getSMCLK" declared implicitly
'Finished building: ../I2C_functions.c'
'Building file: ../printf-stdarg.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="printf-stdarg.d_raw" "../printf-stdarg.c"
'Finished building: ../printf-stdarg.c'
'Building file: ../usci_uart.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="usci_uart.d_raw" "../usci_uart.c"
>> Compilation failure
subdir_rules.mk:58: recipe for target 'usci_uart.obj' failed
INTERNAL ERROR: C:\ti\ccsv7\tools\compiler\ti-cgt-msp430_20.2.5.LTS\bin\acpia430.exe experienced a segmentation fault
while processing function (unknown or file scope) file (unknown) line 0
This is caused by a defect in the TI EABI C/C++ Parser.
TI Customer Support may be able to suggest a workaround to avoid this.
Upgrading to the newest version of the compiler may fix this problem.
Contact TI in the E2E support forums at http://e2e.ti.com under
"Development Tools", "TI C/C++ Compiler". See the link titled
"Submitting an issue".
We need to see this ENTIRE error message and a complete, reproducible
test case including ALL of the command-line options.
Include the .pp file created by option --preproc_with_comment
gmake: *** [usci_uart.obj] Error 1
'Building file: C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="main_semi.d_raw" "C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c"
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 200: warning #552-D: variable "target" was set but never used
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 411: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 413: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 415: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 417: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 419: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 421: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 423: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 425: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 427: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 429: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 431: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 433: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 435: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 437: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 439: warning #190-D: enumerated type mixed with another type
"C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c", line 441: warning #190-D: enumerated type mixed with another type
'Finished building: C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/main_semi.c'
'Building file: ../sram_code.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="sram_code.d_raw" "../sram_code.c"
'Finished building: ../sram_code.c'
'Building file: ../sys_init.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="sys_init.d_raw" "../sys_init.c"
'Finished building: ../sys_init.c'
'Building file: ../usci_i2c.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="usci_i2c.d_raw" "../usci_i2c.c"
'Finished building: ../usci_i2c.c'
'Building file: ../driverlib/MSP430F5xx_6xx/adc10_a.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/adc10_a.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/adc10_a.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/adc10_a.c'
'Building file: ../tps238x.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="tps238x.d_raw" "../tps238x.c"
'Finished building: ../tps238x.c'
'Building file: ../driverlib/MSP430F5xx_6xx/adc12_a.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/adc12_a.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/adc12_a.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/adc12_a.c'
'Building file: ../driverlib/MSP430F5xx_6xx/aes.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/aes.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/aes.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/aes.c'
'Building file: ../driverlib/MSP430F5xx_6xx/battbak.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/battbak.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/battbak.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/battbak.c'
'Building file: ../driverlib/MSP430F5xx_6xx/comp_b.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/comp_b.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/comp_b.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/comp_b.c'
'Building file: ../driverlib/MSP430F5xx_6xx/crc.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/crc.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/crc.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/crc.c'
'Building file: ../driverlib/MSP430F5xx_6xx/ctsd16.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/ctsd16.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/ctsd16.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/ctsd16.c'
'Building file: ../driverlib/MSP430F5xx_6xx/dac12_a.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/dac12_a.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/dac12_a.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/dac12_a.c'
'Building file: ../driverlib/MSP430F5xx_6xx/dma.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/dma.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/dma.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/dma.c'
'Building file: ../driverlib/MSP430F5xx_6xx/eusci_a_spi.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/eusci_a_spi.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/eusci_a_spi.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/eusci_a_spi.c'
'Building file: ../driverlib/MSP430F5xx_6xx/eusci_a_uart.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/eusci_a_uart.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/eusci_a_uart.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/eusci_a_uart.c'
'Building file: ../driverlib/MSP430F5xx_6xx/eusci_b_i2c.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/eusci_b_i2c.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/eusci_b_i2c.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/eusci_b_i2c.c'
'Building file: ../driverlib/MSP430F5xx_6xx/eusci_b_spi.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/eusci_b_spi.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/eusci_b_spi.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/eusci_b_spi.c'
'Building file: ../driverlib/MSP430F5xx_6xx/flashctl.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/flashctl.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/flashctl.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/flashctl.c'
'Building file: ../driverlib/MSP430F5xx_6xx/gpio.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/gpio.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/gpio.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/gpio.c'
'Building file: ../driverlib/MSP430F5xx_6xx/lcd_b.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/lcd_b.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/lcd_b.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/lcd_b.c'
'Building file: ../driverlib/MSP430F5xx_6xx/ldopwr.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/ldopwr.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/ldopwr.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/ldopwr.c'
'Building file: ../driverlib/MSP430F5xx_6xx/mpy32.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/mpy32.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/mpy32.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/mpy32.c'
'Building file: ../driverlib/MSP430F5xx_6xx/oa.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/oa.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/oa.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/oa.c'
'Building file: ../driverlib/MSP430F5xx_6xx/pmap.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/pmap.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/pmap.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/pmap.c'
'Building file: ../driverlib/MSP430F5xx_6xx/pmm.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/pmm.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/pmm.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/pmm.c'
'Building file: ../driverlib/MSP430F5xx_6xx/ram.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/ram.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/ram.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/ram.c'
'Building file: ../driverlib/MSP430F5xx_6xx/ref.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/ref.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/ref.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/ref.c'
'Building file: ../driverlib/MSP430F5xx_6xx/rtc_b.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/rtc_b.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/rtc_b.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/rtc_b.c'
'Building file: ../driverlib/MSP430F5xx_6xx/rtc_a.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/rtc_a.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/rtc_a.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/rtc_a.c'
'Building file: ../driverlib/MSP430F5xx_6xx/rtc_c.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/rtc_c.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/rtc_c.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/rtc_c.c'
'Building file: ../driverlib/MSP430F5xx_6xx/sd24_b.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/sd24_b.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/sd24_b.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/sd24_b.c'
'Building file: ../driverlib/MSP430F5xx_6xx/sfr.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/sfr.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/sfr.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/sfr.c'
'Building file: ../driverlib/MSP430F5xx_6xx/sysctl.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/sysctl.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/sysctl.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/sysctl.c'
'Building file: ../driverlib/MSP430F5xx_6xx/tec.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/tec.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/tec.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/tec.c'
'Building file: ../driverlib/MSP430F5xx_6xx/timer_a.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/timer_a.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/timer_a.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/timer_a.c'
'Building file: ../driverlib/MSP430F5xx_6xx/timer_d.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/timer_d.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/timer_d.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/timer_d.c'
'Building file: ../driverlib/MSP430F5xx_6xx/timer_b.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/timer_b.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/timer_b.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/timer_b.c'
'Building file: ../driverlib/MSP430F5xx_6xx/tlv.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/tlv.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/tlv.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/tlv.c'
'Building file: ../driverlib/MSP430F5xx_6xx/usci_a_spi.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/usci_a_spi.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/usci_a_spi.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/usci_a_spi.c'
'Building file: ../driverlib/MSP430F5xx_6xx/ucs.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/ucs.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/ucs.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/ucs.c'
'Building file: ../driverlib/MSP430F5xx_6xx/usci_a_uart.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/usci_a_uart.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/usci_a_uart.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/usci_a_uart.c'
'Building file: ../driverlib/MSP430F5xx_6xx/usci_b_spi.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/usci_b_spi.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/usci_b_spi.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/usci_b_spi.c'
'Building file: ../driverlib/MSP430F5xx_6xx/wdt_a.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/wdt_a.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/wdt_a.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/wdt_a.c'
'Building file: ../driverlib/MSP430F5xx_6xx/usci_b_i2c.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/bin/cl430" -vmspx --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Project/ccs" --include_path="C:/Users/a0193102/Desktop/Phoenix/TPS23880Ref_MSP430F5340/TPS23880Ref_MSP430F5340/TPS23880Ref/Source/driverlib/MSP430F5xx_6xx" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_20.2.5.LTS/include" --define=DEPRECATED --define=__MSP430F5340__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="driverlib/MSP430F5xx_6xx/usci_b_i2c.d_raw" --obj_directory="driverlib/MSP430F5xx_6xx" "../driverlib/MSP430F5xx_6xx/usci_b_i2c.c"
'Finished building: ../driverlib/MSP430F5xx_6xx/usci_b_i2c.c'
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
>> Compilation failure
