CCS 6.1.3 compiler: identifiers' significant characters
in order to make my code MISRA-compliant, I need to know if Code Composer Studio compiler has got a limit on the number of significant characters of identifiers. For example if the limit was 31,  the next lines wouldn't be compliant:
UINT_32 global_variable_with_long_name1x; /* 1st Use */
UINT_32 global_variable_with_long_name1y; /* not compliant */
As my application works properly, I suppose that there are not such limitations, but I want to be sure if eventually there is a high limit.
Thank you for your help,
Sonia
