Other Parts Discussed in Thread: SYSBIOS, CCSTUDIO
I have some trouble with Resource Explorer in CCS. I want to import an example design into my ccs workspace, but it's failing with the import.
Error Message:
The error message states "Error communicating with cloud agent"
My basic setup is:
- Windows 10
- CCS 10.3.1.00003
- Launchxl- CC1352R1
I have gone through the troubleshooting page on:
https://software-dl.ti.com/ccs/esd/documents/ti_cloud_agent.html#Troubleshooting
I started with downloading "Ticloudagent__2.exe" from https://dev.ti.com/download
I started testing with a browser:
Switched logging on according to the troubleshooting page:
C:\Users\[your ID]\TICloudAgent\ticloudagent.bat
1) Firefox Version 89
Extension seemed to be installed ok
But it does not work.
2) Chrome Version 91
Extension seemed to be installed ok. And it worked:
Please find attached the log files for firefoy anf chrome.
Interim result:
It's working with chrome.
Then switching to CCS
with log enabled in bat file in [CCS INSTALL DIR]\ccs\ccs_base\cloudagent\ticloudagent.bat
Resource ecxplorer is failling with
when running CCS and Ressource explorer (and cloud agent from Resource explorer) i see in the logs:
from C:\temp\my.log --> ccs_my.log
---ARGS--- not_chrome ---NOT_CHROME---
And it did not work. The "not_chrome" version did not work either when running the test in a normal webbrowser.
My questions:
1) it looks like there are several instances of TiCloudAgent on my computer.
With the installation of Ticloudagent__2.exe i get all the stuff in
C:\Users\USER_ID\TICloudAgent
2) but CCS seems to use TiCloud agent stuff from:
3) can i switch the webengine of CCS/eclipse to chrome or sth?
Main Issue is: I need some help on importing examples via resource explorer.
Thanks in advance
Kind regards
Joerg
Firefox logs
---ARGS--- "C:\Users\Fancy_Username\AppData\Local\Texas Instruments\TICloudAgent\resources\Mozilla\com.ti.ticloudagent.json" jid1-OUyb80wrjJhfaQ@jetpack ---CHROME---
2021-06-16T09:45:20.847Z: main_chrome: Staring directory = C:\Users\JOERGH~1\TICLOU~1\src
2021-06-16T09:45:20.847Z: Starting Agent!
2021-06-16T09:45:20.862Z: Module( Agent )->Web socket server started!
2021-06-16T09:45:21.478Z: Overridden Proxy =
2021-06-16T09:45:21.493Z: Discovered Module : DeviceDetector
2021-06-16T09:45:21.493Z: Discovered Module : DS
2021-06-16T09:45:21.493Z: Discovered Module : EventBroker
2021-06-16T09:45:21.493Z: Discovered Module : File
2021-06-16T09:45:21.493Z: Failed to load module : rex_redirect.js : Error: Cannot find module '../../../../tirex4/ti-rex-core/cloud-agent-module'
at Function.Module._resolveFilename (module.js:547:15)
at Function.Module._load (module.js:474:25)
at Module.require (module.js:596:17)
at require (internal/module.js:11:18)
at Object.<anonymous> (C:\Users\JOERGH~1\TICLOU~1\src\modules\rex_redirect.js:3:19)
at Module._compile (module.js:652:30)
at Object.Module._extensions..js (module.js:663:10)
at Module.load (module.js:565:32)
at tryModuleLoad (module.js:505:12)
at Function.Module._load (module.js:497:3)
2021-06-16T09:45:21.493Z: rov_server_redirect: looking in: C:\Users\eclipse\dropins
2021-06-16T09:45:21.493Z: rov_server_redirect: looking in: C:\Users\eclipse\plugins
2021-06-16T09:45:21.493Z: rov_server_redirect: looking in: C:\Users\eclipse\Eclipse.app\Contents\Eclipse\dropins
2021-06-16T09:45:21.493Z: rov_server_redirect: looking in: C:\Users\eclipse\Eclipse.app\Contents\Eclipse\plugins
2021-06-16T09:45:21.493Z: Failed to load module : rov_server_redirect.js : Error: rov_server.js was not found (this is expected in cloud)
at Object.<anonymous> (C:\Users\JOERGH~1\TICLOU~1\src\modules\rov_server_redirect.js:65:11)
at module_1.createModule.then (C:\Users\JOERGH~1\TICLOU~1\src\host_agent.js:23:42)
at <anonymous>
2021-06-16T09:45:21.534Z: Discovered Module : Serial
2021-06-16T09:45:21.534Z: Discovered Module : TargetSupport
2021-06-16T09:45:21.538Z: Discovered Module : USB
2021-06-16T09:45:21.542Z: Discovered Module : USB-HID
2021-06-16T09:45:21.544Z: Agent main module running on port 26551
2021-06-16T09:45:21.544Z: len=
2021-06-16T09:45:21.544Z: 5
2021-06-16T09:45:21.544Z: buf=
2021-06-16T09:45:21.544Z: {"port":26551,"version":"4.10","buildVersion":"3168"}
Chrome logs:
---ARGS--- chrome-extension://pfillhniocmjcapelhjcianojmoidjdk/ --parent-window 0 ---CHROME---
2021-06-16T09:44:09.935Z: main_chrome: Staring directory = C:\Users\JOERGH~1\TICLOU~1\src
2021-06-16T09:44:09.935Z: Starting Agent!
2021-06-16T09:44:09.950Z: Module( Agent )->Web socket server started!
2021-06-16T09:44:10.558Z: Overridden Proxy =
2021-06-16T09:44:10.575Z: Discovered Module : DeviceDetector
2021-06-16T09:44:10.576Z: Discovered Module : DS
2021-06-16T09:44:10.578Z: Discovered Module : EventBroker
2021-06-16T09:44:10.578Z: Discovered Module : File
2021-06-16T09:44:10.578Z: Failed to load module : rex_redirect.js : Error: Cannot find module '../../../../tirex4/ti-rex-core/cloud-agent-module'
2021-06-16T09:44:10.578Z: rov_server_redirect: looking in: C:\Users\eclipse\dropins
2021-06-16T09:44:10.578Z: rov_server_redirect: looking in: C:\Users\eclipse\plugins
2021-06-16T09:44:10.578Z: rov_server_redirect: looking in: C:\Users\eclipse\Eclipse.app\Contents\Eclipse\dropins
2021-06-16T09:44:10.578Z: rov_server_redirect: looking in: C:\Users\eclipse\Eclipse.app\Contents\Eclipse\plugins
2021-06-16T09:44:10.578Z: Failed to load module : rov_server_redirect.js : Error: rov_server.js was not found (this is expected in cloud)
at <anonymous>
2021-06-16T09:44:10.611Z: Discovered Module : Serial
2021-06-16T09:44:10.611Z: Discovered Module : TargetSupport
2021-06-16T09:44:10.611Z: Discovered Module : USB
2021-06-16T09:44:10.611Z: Discovered Module : USB-HID
2021-06-16T09:44:10.611Z: Agent main module running on port 25395
2021-06-16T09:44:10.611Z: len=
2021-06-16T09:44:10.626Z: 5
2021-06-16T09:44:10.626Z: buf=
2021-06-16T09:44:10.626Z: {"port":25395,"version":"4.10","buildVersion":"3168"}
2021-06-16T09:44:10.641Z: Module( Agent )->[wss.onConnection]
2021-06-16T09:44:10.644Z: Module( Agent )->[ws.onMessage]{"command":"listCommands","id":1,"data":[]}
2021-06-16T09:44:10.645Z: Module( Agent )->[ResponseHandler]{"data":{"commands":["listSubModules","createSubModule","listCommands","addConfigProperty","registerModuleWebSocket","registerModuleByPath"]},"response":1}
2021-06-16T09:44:10.648Z: Module( Agent )->[ws.onMessage]{"command":"addConfigProperty","id":2,"data":["cloudAgentInstallerServerURL","https://dev.ti.com/ticloudagent"]}
2021-06-16T09:44:10.649Z: Setting property cloudAgentInstallerServerURL : https://dev.ti.com/ticloudagent
2021-06-16T09:44:10.650Z: Module( Agent )->[ResponseHandler]{"response":2}
2021-06-16T09:44:10.651Z: Module( Agent )->[ws.onMessage]{"command":"createSubModule","id":3,"data":["DeviceDetector"]}
2021-06-16T09:44:10.652Z: Module( Agent )->Creating new module
2021-06-16T09:44:10.654Z: Module( DeviceDetector )->Web socket server started!
2021-06-16T09:44:10.657Z: detected usb id 0451_bef3
2021-06-16T09:44:10.657Z: detected usb id 0c45_648b
2021-06-16T09:44:10.657Z: detected usb id 046d_08e5
2021-06-16T09:44:10.658Z: detected usb id 413c_8197
2021-06-16T09:44:10.658Z: detected usb id 046d_c30e
2021-06-16T09:44:10.659Z: detected usb id 046d_c52b
2021-06-16T09:44:10.659Z: detected usb id 8087_0024
2021-06-16T09:44:10.659Z: detected usb id 413c_2134
2021-06-16T09:44:10.660Z: detected usb id 413c_2513
2021-06-16T09:44:10.660Z: detected usb id 8087_0024
2021-06-16T09:44:10.660Z: detected usb id 8086_1e26
2021-06-16T09:44:10.661Z: detected usb id 8086_1e2d
2021-06-16T09:44:10.661Z: detected usb id 413c_5534
2021-06-16T09:44:10.661Z: detected usb id 8086_1e31
2021-06-16T09:44:10.662Z: Module( Agent )->[ResponseHandler]{"data":{"port":33749},"response":3}
2021-06-16T09:44:10.666Z: Module( DeviceDetector )->[wss.onConnection]
2021-06-16T09:44:10.668Z: Module( DeviceDetector )->[ws.onMessage]{"command":"listCommands","id":1,"data":[]}
2021-06-16T09:44:10.669Z: Module( DeviceDetector )->[ResponseHandler]{"data":{"commands":["listSubModules","createSubModule","listCommands","detectDebugProbes","detectDevice","detectDeviceWithProbe","identifyProbe","filesNeeded","populateDeviceList"]},"response":1}
2021-06-16T09:44:10.671Z: Module( DeviceDetector )->[ws.onMessage]{"command":"filesNeeded","id":2,"data":[]}
2021-06-16T09:44:10.672Z: DriverInstaller options: {}
2021-06-16T09:44:10.674Z: Getting file info by category: https://dev.ti.com/ticloudagent/getFilesByCategory?os=win&bitSize=64&categories=core,tixds110
2021-06-16T09:44:10.674Z: Looking up proxy settings for url https://dev.ti.com/ticloudagent
2021-06-16T09:44:10.708Z: Setting proxy to
2021-06-16T09:44:10.708Z: installer.js using proxy:
2021-06-16T09:44:11.393Z: {"files":[{"name":"ccs_base/common/bin/libusb-1.0.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/ti_targetdb_parser.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/jioxds110.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/jscxds110.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/jtagdata.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xds110/boot_loader.axf","version":"2021-01-22T18:57:15.472Z"},{"name":"ccs_base/common/uscif/xds110/boot_loader.bin","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/common/uscif/xds110/firmware_3.0.0.15.bin","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xds110/xds110reset.exe","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xds110/xdsdfu.exe","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdsalias.cfg","version":"2021-01-22T18:57:15.472Z"},{"name":"ccs_base/common/uscif/xdsboard.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/BatchDriverInstaller.exe","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdserror.cfg","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/DSLite.exe","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdserror.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/DebugProperties.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdsfamily.cfg","version":"2021-01-22T18:57:15.472Z"},{"name":"ccs_base/DebugServer/bin/DebugServer.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdsfast3.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/FlashDLLDB.xml","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/common/uscif/xdsicicle.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/LibraryLoader.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdsinitial.cfg","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/XPCOMUtility.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdslocal.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-console-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/uscif/xdsroute.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-console-l1-2-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/uscif/xdstrove.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-datetime-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/AETOperationServer.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-debug-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/AETProperties.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-errorhandling-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/AETPropertyHelper.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-file-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/DeviceIdentifier.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-file-l1-2-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/ICETargetAdapter.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-file-l2-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/cToolsIF.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-handle-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/ctools.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-heap-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/ctoolsndbg.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-interlocked-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/pathinfo.ini","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-libraryloader-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/xmldb/aet_config/aetdvrs.xml","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-localization-l1-2-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/drivers/cmapi.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-memory-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/drivers/cmapi.out","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-namedpipe-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/drivers/prsc.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-processenvironment-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-processthreads-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-processthreads-l1-1-1.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/x64/WdfCoInstaller01009.dll","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-profile-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/x64/winusbcoinstaller2.dll","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-rtlsupport-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/xds110_cmsis20.cat","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-string-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/xds110_cmsis20.inf","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-synch-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/xds110_debug.cat","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-synch-l1-2-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/xds110_debug.inf","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-sysinfo-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/xds110_ports.cat","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-timezone-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/xds110_ports.inf","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-util-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-conio-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-convert-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-environment-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-filesystem-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-heap-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-locale-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-math-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-multibyte-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-private-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-process-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-runtime-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-stdio-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-string-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-time-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-utility-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/msvcp140.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/ti_xpcom.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/tiofr11.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/tiofr_gnu.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/tiofr_tial.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/ucrtbase.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/vcruntime140.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/vcruntime140_1.dll","version":"2020-06-16T14:25:17.790Z"},{"name":"ccs_base/DebugServer/components/components.txt","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/propertyDB/FlashPropertiesTranslator.xml","version":"2021-01-22T18:57:15.472Z"},{"name":"ccs_base/DebugServer/propertyDB/PropertiesDB.xml","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/schemas/PropertiesDB.xsd","version":"2020-06-16T14:25:17.790Z"},{"name":"ccs_base/DebugServer/schemas/PropertiesSaveSetting.xsd","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/scripts/cc13xx-cc26xx-mass-erase.dsls","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/scripts/flash.dsls","version":"2020-08-06T13:51:27.569Z"},{"name":"ccs_base/DebugServer/scripts/help.dsls","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/scripts/identifyProbe.dsls","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/scripts/load.dsls","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/scripts/memory.dsls","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/scripts/serial.dsls","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/common/bin/CCReg.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/MiniDump.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/fs.exe","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/fsclean.bat","version":"2020-08-06T13:51:27.569Z"},{"name":"ccs_base/common/bin/fsutil.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/liblldb_ccs.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/setup_parser.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/ti_logger.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/xerces-c_2_8.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/targetdb/drivers/TI_reg_ids/regids.xsd","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/common/targetdb/setup_parser.xsd","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/common/targetdb/setup_parser_cache.xsd","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/emulation/tpi/tpi.ini","version":"2020-04-21T20:44:05.202Z"}],"drivers":["ccs_base/emulation/windows/xds110_drivers"]}
2021-06-16T09:44:11.394Z: registrationNeeded = ccs_base/emulation/windows/xds110_drivers
2021-06-16T09:44:11.394Z: Module( DeviceDetector )->[ResponseHandler]{"data":false,"response":2}
2021-06-16T09:44:11.394Z: Module( DeviceDetector )->[ws.onMessage]{"command":"detectDebugProbes","id":3,"data":[]}
2021-06-16T09:44:11.394Z: DriverInstaller options: {}
2021-06-16T09:44:11.394Z: Getting file info by category: https://dev.ti.com/ticloudagent/getFilesByCategory?os=win&bitSize=64&categories=core,tixds110
2021-06-16T09:44:11.394Z: Looking up proxy settings for url https://dev.ti.com/ticloudagent
2021-06-16T09:44:11.425Z: Setting proxy to
2021-06-16T09:44:11.425Z: installer.js using proxy:
2021-06-16T09:44:11.957Z: {"files":[{"name":"ccs_base/common/bin/libusb-1.0.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/ti_targetdb_parser.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/jioxds110.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/jscxds110.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/jtagdata.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xds110/boot_loader.axf","version":"2021-01-22T18:57:15.472Z"},{"name":"ccs_base/common/uscif/xds110/boot_loader.bin","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/common/uscif/xds110/firmware_3.0.0.15.bin","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xds110/xds110reset.exe","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xds110/xdsdfu.exe","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdsalias.cfg","version":"2021-01-22T18:57:15.472Z"},{"name":"ccs_base/common/uscif/xdsboard.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/BatchDriverInstaller.exe","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdserror.cfg","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/DSLite.exe","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdserror.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/DebugProperties.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdsfamily.cfg","version":"2021-01-22T18:57:15.472Z"},{"name":"ccs_base/DebugServer/bin/DebugServer.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdsfast3.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/FlashDLLDB.xml","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/common/uscif/xdsicicle.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/LibraryLoader.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdsinitial.cfg","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/XPCOMUtility.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/uscif/xdslocal.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-console-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/uscif/xdsroute.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-console-l1-2-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/common/uscif/xdstrove.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-datetime-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/AETOperationServer.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-debug-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/AETProperties.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-errorhandling-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/AETPropertyHelper.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-file-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/DeviceIdentifier.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-file-l1-2-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/ICETargetAdapter.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-file-l2-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/cToolsIF.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-handle-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/ctools.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-heap-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/ctoolsndbg.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-interlocked-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/bin/pathinfo.ini","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-libraryloader-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/analysis/xmldb/aet_config/aetdvrs.xml","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-localization-l1-2-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/drivers/cmapi.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-memory-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/drivers/cmapi.out","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-namedpipe-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/drivers/prsc.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-processenvironment-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-processthreads-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-processthreads-l1-1-1.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/x64/WdfCoInstaller01009.dll","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-profile-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/x64/winusbcoinstaller2.dll","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-rtlsupport-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/xds110_cmsis20.cat","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-string-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/xds110_cmsis20.inf","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-synch-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/xds110_debug.cat","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-synch-l1-2-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/xds110_debug.inf","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-sysinfo-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/xds110_ports.cat","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-timezone-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/emulation/windows/xds110_drivers/xds110_ports.inf","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-core-util-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-conio-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-convert-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-environment-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-filesystem-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-heap-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-locale-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-math-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-multibyte-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-private-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-process-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-runtime-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-stdio-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-string-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-time-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/api-ms-win-crt-utility-l1-1-0.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/msvcp140.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/ti_xpcom.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/tiofr11.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/tiofr_gnu.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/tiofr_tial.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/DebugServer/bin/ucrtbase.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/vcruntime140.dll","version":"2019-04-29T19:02:11.854Z"},{"name":"ccs_base/DebugServer/bin/vcruntime140_1.dll","version":"2020-06-16T14:25:17.790Z"},{"name":"ccs_base/DebugServer/components/components.txt","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/propertyDB/FlashPropertiesTranslator.xml","version":"2021-01-22T18:57:15.472Z"},{"name":"ccs_base/DebugServer/propertyDB/PropertiesDB.xml","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/schemas/PropertiesDB.xsd","version":"2020-06-16T14:25:17.790Z"},{"name":"ccs_base/DebugServer/schemas/PropertiesSaveSetting.xsd","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/scripts/cc13xx-cc26xx-mass-erase.dsls","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/scripts/flash.dsls","version":"2020-08-06T13:51:27.569Z"},{"name":"ccs_base/DebugServer/scripts/help.dsls","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/scripts/identifyProbe.dsls","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/scripts/load.dsls","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/scripts/memory.dsls","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/DebugServer/scripts/serial.dsls","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/common/bin/CCReg.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/MiniDump.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/fs.exe","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/fsclean.bat","version":"2020-08-06T13:51:27.569Z"},{"name":"ccs_base/common/bin/fsutil.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/liblldb_ccs.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/setup_parser.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/ti_logger.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/bin/xerces-c_2_8.dll","version":"2021-04-01T20:24:19.835Z"},{"name":"ccs_base/common/targetdb/drivers/TI_reg_ids/regids.xsd","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/common/targetdb/setup_parser.xsd","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/common/targetdb/setup_parser_cache.xsd","version":"2020-04-21T20:44:05.202Z"},{"name":"ccs_base/emulation/tpi/tpi.ini","version":"2020-04-21T20:44:05.202Z"}],"drivers":["ccs_base/emulation/windows/xds110_drivers"]}
2021-06-16T09:44:11.957Z: registrationNeeded = ccs_base/emulation/windows/xds110_drivers
2021-06-16T09:44:11.973Z: ERROR: found no pnpId match: ACPI\PNP0501\0
2021-06-16T09:44:11.973Z: ERROR: found no pnpId match: USB\VID_0451&PID_BEF3&MI_03\6&772C2DB&0&0003
2021-06-16T09:44:12.015Z: Module( DeviceDetector )->[ResponseHandler]{"data":{"probes":[{"connectionXml":"TIXDS110_Connection","id":"0","serialNumber":"L41009I6","comPorts":["COM4"],"overrides":{"Debug Probe Selection":"1","-- Enter the serial number":"L41009I6"}}]},"response":3}
2021-06-16T09:44:12.015Z: Module( DeviceDetector )->[ws.onMessage]{"command":"detectDevice","id":4,"data":["0"]}
2021-06-16T09:44:12.015Z: Module( DeviceDetector )->[ResponseHandler]{"data":{"id":"LAUNCHXL-CC1352R1","name":"CC1352R1 LaunchPad (Dual band 868MHz and 2.4GHz)","deviceXml":"cc1352r1f3","family":"LPRF"},"response":4}
CCS logs:
2021-06-16T10:32:31.967Z: main: Staring directory = C:\ti\ccs1031\ccs\ccs_base\cloudagent\src 2021-06-16T10:32:31.972Z: Starting Agent! 2021-06-16T10:32:32.005Z: Module( Agent )->Web socket server started! 2021-06-16T10:32:33.799Z: Overridden Proxy = 2021-06-16T10:32:33.861Z: Discovered Module : DeviceDetector 2021-06-16T10:32:33.863Z: Discovered Module : DS 2021-06-16T10:32:33.865Z: Discovered Module : EventBroker 2021-06-16T10:32:33.868Z: Discovered Module : File 2021-06-16T10:32:33.978Z: Overridden Proxy = 2021-06-16T10:32:33.998Z: Discovered Module : DeviceDetector 2021-06-16T10:32:34.002Z: Discovered Module : DS 2021-06-16T10:32:34.012Z: Discovered Module : EventBroker 2021-06-16T10:32:34.027Z: Overridden Proxy = 2021-06-16T10:32:34.030Z: Discovered Module : File 2021-06-16T10:32:34.051Z: Discovered Module : DeviceDetector 2021-06-16T10:32:34.053Z: Discovered Module : DS 2021-06-16T10:32:34.055Z: Discovered Module : EventBroker 2021-06-16T10:32:34.058Z: Discovered Module : File 2021-06-16T10:32:34.140Z: Overridden Proxy = 2021-06-16T10:32:34.234Z: Discovered Module : DeviceDetector 2021-06-16T10:32:34.236Z: Discovered Module : DS 2021-06-16T10:32:34.239Z: Discovered Module : EventBroker 2021-06-16T10:32:34.242Z: Discovered Module : File 2021-06-16T10:32:34.329Z: Overridden Proxy = 2021-06-16T10:32:34.348Z: Discovered Module : DeviceDetector 2021-06-16T10:32:34.350Z: Discovered Module : DS 2021-06-16T10:32:34.375Z: Discovered Module : EventBroker 2021-06-16T10:32:34.378Z: Discovered Module : File 2021-06-16T10:32:34.381Z: Overridden Proxy = 2021-06-16T10:32:34.400Z: Discovered Module : DeviceDetector 2021-06-16T10:32:34.402Z: Discovered Module : DS 2021-06-16T10:32:34.405Z: Discovered Module : EventBroker 2021-06-16T10:32:34.412Z: Discovered Module : File 2021-06-16T10:32:35.343Z: Discovered Module : Tirex 2021-06-16T10:32:35.343Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\dropins 2021-06-16T10:32:35.346Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\plugins 2021-06-16T10:32:35.368Z: rov_server_redirect: found: C:\ti\ccs1031\ccs\eclipse\plugins/com.ti.rov_1.0.0.202010121439 2021-06-16T10:32:35.368Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\Eclipse.app\Contents\Eclipse\dropins 2021-06-16T10:32:35.368Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\Eclipse.app\Contents\Eclipse\plugins 2021-06-16T10:32:35.368Z: rov_server_redirect: setting XDCTOOLS_JAVA_HOME to C:\ti\ccs1031\ccs\eclipse\jre 2021-06-16T10:32:35.378Z: rov_server_redirect: requiring C:\ti\ccs1031\ccs\eclipse\plugins\com.ti.rov_1.0.0.202010121439\rov_server.js 2021-06-16T10:32:35.389Z: Discovered Module : ROVServer 2021-06-16T10:32:35.477Z: Discovered Module : Serial 2021-06-16T10:32:35.478Z: Discovered Module : TargetSupport 2021-06-16T10:32:35.482Z: Discovered Module : USB 2021-06-16T10:32:35.489Z: Discovered Module : USB-HID 2021-06-16T10:32:35.490Z: Agent main module running on port 1652 2021-06-16T10:32:35.638Z: Discovered Module : Tirex 2021-06-16T10:32:35.641Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\dropins 2021-06-16T10:32:35.646Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\plugins 2021-06-16T10:32:35.649Z: rov_server_redirect: found: C:\ti\ccs1031\ccs\eclipse\plugins/com.ti.rov_1.0.0.202010121439 2021-06-16T10:32:35.654Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\Eclipse.app\Contents\Eclipse\dropins 2021-06-16T10:32:35.662Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\Eclipse.app\Contents\Eclipse\plugins 2021-06-16T10:32:35.669Z: rov_server_redirect: setting XDCTOOLS_JAVA_HOME to C:\ti\ccs1031\ccs\eclipse\jre 2021-06-16T10:32:35.682Z: rov_server_redirect: requiring C:\ti\ccs1031\ccs\eclipse\plugins\com.ti.rov_1.0.0.202010121439\rov_server.js 2021-06-16T10:32:35.685Z: Discovered Module : ROVServer 2021-06-16T10:32:35.694Z: Discovered Module : Tirex 2021-06-16T10:32:35.696Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\dropins 2021-06-16T10:32:35.697Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\plugins 2021-06-16T10:32:35.700Z: rov_server_redirect: found: C:\ti\ccs1031\ccs\eclipse\plugins/com.ti.rov_1.0.0.202010121439 2021-06-16T10:32:35.700Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\Eclipse.app\Contents\Eclipse\dropins 2021-06-16T10:32:35.701Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\Eclipse.app\Contents\Eclipse\plugins 2021-06-16T10:32:35.702Z: rov_server_redirect: setting XDCTOOLS_JAVA_HOME to C:\ti\ccs1031\ccs\eclipse\jre 2021-06-16T10:32:35.703Z: rov_server_redirect: requiring C:\ti\ccs1031\ccs\eclipse\plugins\com.ti.rov_1.0.0.202010121439\rov_server.js 2021-06-16T10:32:35.724Z: Discovered Module : ROVServer 2021-06-16T10:32:35.781Z: Discovered Module : Serial 2021-06-16T10:32:35.782Z: Discovered Module : TargetSupport 2021-06-16T10:32:35.786Z: Discovered Module : USB 2021-06-16T10:32:35.792Z: Discovered Module : USB-HID 2021-06-16T10:32:35.795Z: Agent main module running on port 1654 2021-06-16T10:32:35.822Z: Discovered Module : Serial 2021-06-16T10:32:35.824Z: Discovered Module : TargetSupport 2021-06-16T10:32:35.836Z: Discovered Module : USB 2021-06-16T10:32:35.844Z: Discovered Module : USB-HID 2021-06-16T10:32:35.845Z: Agent main module running on port 1656 2021-06-16T10:32:35.847Z: Discovered Module : Tirex 2021-06-16T10:32:35.850Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\dropins 2021-06-16T10:32:35.851Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\plugins 2021-06-16T10:32:35.853Z: rov_server_redirect: found: C:\ti\ccs1031\ccs\eclipse\plugins/com.ti.rov_1.0.0.202010121439 2021-06-16T10:32:35.854Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\Eclipse.app\Contents\Eclipse\dropins 2021-06-16T10:32:35.855Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\Eclipse.app\Contents\Eclipse\plugins 2021-06-16T10:32:35.856Z: rov_server_redirect: setting XDCTOOLS_JAVA_HOME to C:\ti\ccs1031\ccs\eclipse\jre 2021-06-16T10:32:35.856Z: rov_server_redirect: requiring C:\ti\ccs1031\ccs\eclipse\plugins\com.ti.rov_1.0.0.202010121439\rov_server.js 2021-06-16T10:32:35.889Z: Discovered Module : ROVServer 2021-06-16T10:32:35.905Z: Discovered Module : Tirex 2021-06-16T10:32:35.908Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\dropins 2021-06-16T10:32:35.909Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\plugins 2021-06-16T10:32:35.911Z: rov_server_redirect: found: C:\ti\ccs1031\ccs\eclipse\plugins/com.ti.rov_1.0.0.202010121439 2021-06-16T10:32:35.912Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\Eclipse.app\Contents\Eclipse\dropins 2021-06-16T10:32:35.913Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\Eclipse.app\Contents\Eclipse\plugins 2021-06-16T10:32:35.914Z: rov_server_redirect: setting XDCTOOLS_JAVA_HOME to C:\ti\ccs1031\ccs\eclipse\jre 2021-06-16T10:32:35.914Z: rov_server_redirect: requiring C:\ti\ccs1031\ccs\eclipse\plugins\com.ti.rov_1.0.0.202010121439\rov_server.js 2021-06-16T10:32:35.918Z: Discovered Module : ROVServer 2021-06-16T10:32:35.948Z: Discovered Module : Serial 2021-06-16T10:32:35.949Z: Discovered Module : TargetSupport 2021-06-16T10:32:35.954Z: Discovered Module : USB 2021-06-16T10:32:35.960Z: Discovered Module : USB-HID 2021-06-16T10:32:35.961Z: Agent main module running on port 1653 2021-06-16T10:32:35.970Z: Discovered Module : Serial 2021-06-16T10:32:35.972Z: Discovered Module : TargetSupport 2021-06-16T10:32:35.975Z: Discovered Module : USB 2021-06-16T10:32:35.992Z: Discovered Module : USB-HID 2021-06-16T10:32:35.993Z: Agent main module running on port 1658 2021-06-16T10:32:36.073Z: Discovered Module : Tirex 2021-06-16T10:32:36.076Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\dropins 2021-06-16T10:32:36.077Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\plugins 2021-06-16T10:32:36.080Z: rov_server_redirect: found: C:\ti\ccs1031\ccs\eclipse\plugins/com.ti.rov_1.0.0.202010121439 2021-06-16T10:32:36.082Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\Eclipse.app\Contents\Eclipse\dropins 2021-06-16T10:32:36.083Z: rov_server_redirect: looking in: C:\ti\ccs1031\ccs\eclipse\Eclipse.app\Contents\Eclipse\plugins 2021-06-16T10:32:36.084Z: rov_server_redirect: setting XDCTOOLS_JAVA_HOME to C:\ti\ccs1031\ccs\eclipse\jre 2021-06-16T10:32:36.085Z: rov_server_redirect: requiring C:\ti\ccs1031\ccs\eclipse\plugins\com.ti.rov_1.0.0.202010121439\rov_server.js 2021-06-16T10:32:36.091Z: Discovered Module : ROVServer 2021-06-16T10:32:36.154Z: Discovered Module : Serial 2021-06-16T10:32:36.156Z: Discovered Module : TargetSupport 2021-06-16T10:32:36.159Z: Discovered Module : USB 2021-06-16T10:32:36.166Z: Discovered Module : USB-HID 2021-06-16T10:32:36.167Z: Agent main module running on port 1657
