Part Number: CODECOMPOSER
Other Parts Discussed in Thread: EK-TM4C1294XL, SYSBIOS
Hi All,
I have just started to develope an ethernet application on EK-TM4C1294XL board. I have used TI-RTOS examples and imported "TCP Echo" project.
I am using CCS 10,3,1 and tried to build the tcp echo example but got following error:
configuring tcpEcho.xem4f from package/cfg/tcpEcho_pem4f.cfg ...
subdir_rules.mk:19: recipe for target 'build-784193775-inproc' failed
error: xdc.cfg.Program: "C:/ti/ccs1031/xdctools_3_62_00_08_core/packages/xdc/cfg/Program.xs", line 71: xdc.cfg.Program : The package 'ti.sysbios.knl' is not compatible with XDCtools used in this build. Please either use XDCtools compatible with that package, or update the product containing that package, or rebuild the package with XDCtools 3.50 or later.
js: "C:/ti/ccs1031/xdctools_3_62_00_08_core/packages/xdc/cfg/Main.xs", line 160: Error: Configuration failed!
gmake.exe: *** [package.mak:202: package/cfg/tcpEcho_pem4f.xdl] Error 1
js: "C:/ti/ccs1031/xdctools_3_62_00_08_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
gmake[1]: *** [build-784193775-inproc] Error 1
gmake: *** No rule to make target 'build-784193775', needed by 'configPkg/compiler.opt'.
gmake: *** No rule to make target 'build-784193775', needed by 'configPkg/linker.cmd'.
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
Could you help me to solve it and run the example?
