Hello CCS experts
I have a CCSv4 project setup as a portable project per "CCSv4_Tips_n_Tricks.pdf". The application is built using multiple libraries - and all projects and dependencies are referenced via the CCS UI. This (obviously) works in the UI... but not on the command-line:
Here is a reference page I found for driving the CCS projects via cmdline: http://processors.wiki.ti.com/index.php/Projects_-_Command_Line_Build/Create
I have a separate project for the SYS/BIOS config - which seems to build... but nothing meaningful happens after that:
Typical error for all libraries is as follows:
**** Build of configuration Release for project libxyz ****
C:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake -k all
gmake[1]: Entering directory `<...>CCSv4/libxyz/Release'
gmake[1]: Leaving directory `<...>CCSv4/libxyz/Release'
makefile:109: *** target pattern contains no `%'. Stop.
Build complete for project libxyz
Relevant snippet of the generated makefile is as follows:
# All Target
[109] all: "<...>/lib/Release/libxyz.a
Ram
Hi Ram,
What is the full version number of the CCS version you are using?
ki
Hi Ki
Here it is:
Code Composer Studio
Version: 4.2.1.00004
(c) Copyright Texas Instruments, 2009. All rights reserved.
Visit http://www.ti.com
*** Date: Thu Mar 31 17:52:50 PDT 2011
*** Platform Details:
*** System properties:
DEFAULT_CCS_TARGET_CONFIGURATION=E:/home/rrang/projects/perforce/mesa/orcca/CCSv4/debugger_cfg/SD.ccxml
XDCPATH=C:/Program Files/Texas Instruments/ipc_1_21_02_23/packages;C:/Program Files/Texas Instruments/bios_6_30_03_46/packages;
XPCOM.RUNTIME=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
awt.toolkit=sun.awt.windows.WToolkit
config.rootDir=C:/Program Files/Texas Instruments/xdctools_3_20_07_86
deployment.browser.args=-raise -remote openURL(%u,new-window)
deployment.browser.path=C:\Program Files\Mozilla Firefox\firefox.exe
deployment.cache.jarcompression=0
deployment.cache.max.size=-1
deployment.capture.mime.types=false
deployment.console.startup.mode=SHOW
deployment.control.panel.log=false
deployment.home.j2se.url=http://java.sun.com/j2se/
deployment.javapi.cache.enabled=true
deployment.javapi.lifecycle.exception=false
deployment.javapi.log.filename=
deployment.javapi.runtime.type=0
deployment.javapi.trace.filename=
deployment.javaws.associations=ASK_USER
deployment.javaws.autodownload=ALWAYS
deployment.javaws.home.jnlp.url=http://java.sun.com/products/javawebstart
deployment.javaws.installURL=http://java.sun.com/products/autodl/j2se
deployment.javaws.logFileName=
deployment.javaws.muffin.max=256
deployment.javaws.shortcut=ASK_IF_HINTED
deployment.javaws.splash.index=C:\Documents and Settings\rrang\Application Data\Sun\Java\Deployment\cache\6.0\splash\splash.xml
deployment.javaws.ssv.enabled=true
deployment.javaws.traceFileName=
deployment.javaws.uninstall.shortcut=false
deployment.javaws.update.timeout=1500
deployment.log=false
deployment.mime.types.use.default=true
deployment.proxy.bypass.local=false
deployment.proxy.override.hosts=
deployment.proxy.same=false
deployment.proxy.type=3
deployment.repository.askdownloaddialog.show=true
deployment.repository.enabled=true
deployment.security.SSLv2Hello=true
deployment.security.SSLv3=true
deployment.security.TLSv1=false
deployment.security.askgrantdialog.notinca=true
deployment.security.askgrantdialog.show=true
deployment.security.authenticator=true
deployment.security.browser.keystore.use=true
deployment.security.clientauth.keystore.auto=true
deployment.security.jsse.hostmismatch.warning=true
deployment.security.sandbox.awtwarningwindow=true
deployment.security.sandbox.jnlp.enhanced=true
deployment.security.trusted.policy=
deployment.system.security.cacerts=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\cacerts
deployment.system.security.jssecacerts=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\jssecacerts
deployment.system.security.trusted.certs=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\trusted.certs
deployment.system.security.trusted.clientauthcerts=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\trusted.clientcerts
deployment.system.security.trusted.jssecerts=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\trusted.jssecerts
deployment.trace=false
deployment.update.mime.types=true
deployment.user.cachedir=C:\Documents and Settings\rrang\Application Data\Sun\Java\Deployment\cache
deployment.user.extdir=C:\Documents and Settings\rrang\Application Data\Sun\Java\Deployment\ext
deployment.user.logdir=C:\Documents and Settings\rrang\Application Data\Sun\Java\Deployment\log
deployment.user.security.policy=file://C:/Documents%20and%20Settings/rrang/Application%20Data/Sun/Java/Deployment/security/java.policy
deployment.user.security.trusted.cacerts=C:\Documents and Settings\rrang\Application Data\Sun\Java\Deployment\security\trusted.cacerts
deployment.user.security.trusted.certs=C:\Documents and Settings\rrang\Application Data\Sun\Java\Deployment\security\trusted.certs
deployment.user.security.trusted.clientauthcerts=C:\Documents and Settings\rrang\Application Data\Sun\Java\Deployment\security\trusted.clientcerts
deployment.user.security.trusted.jssecacerts=C:\Documents and Settings\rrang\Application Data\Sun\Java\Deployment\security\trusted.jssecacerts
deployment.user.security.trusted.jssecerts=C:\Documents and Settings\rrang\Application Data\Sun\Java\Deployment\security\trusted.jssecerts
deployment.user.tmp=C:\Documents and Settings\rrang\Application Data\Sun\Java\Deployment\tmp
deployment.version=6.0
eclipse.buildId=4.2.1.00004
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\Program Files\Texas Instruments\ccsv4\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
be0_fc
-vm
C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=com.ti.ccstudio.branding.product
eclipse.startTime=1301606926203
eclipse.vm=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe
eclipse.vmargs=-Xms256m
-Xmx512m
-XX:MaxPermSize=256m
-DXPCOM.RUNTIME=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
-Dxpcom.bridge.executeOnDedicatedThread=no
-Dorg.eclipse.swt.browser.XULRunnerPath=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
-Dosgi.instance.area.default=file:/C:/Documents and Settings/rrang/My Documents/workspace/
-jar
C:\Program Files\Texas Instruments\ccsv4\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\endorsed
java.ext.dirs=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\ext
java.home=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre
java.io.tmpdir=C:\DOCUME~1\rrang\LOCALS~1\Temp\
java.library.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin;.;C:\WINDOWS\system32;C:\WINDOWS;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\bin;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\uscif;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\DebugServer\license;C:/Program Files/Texas Instruments/xdctools_3_20_07_86;C:\Program Files\Intel\VTune\CGGlbCache;C:\Program Files\Intel\VTune\Analyzer\Bin;C:\Program Files\Intel\VTune\Shared\Bin;C:\Program Files\Intel\Compiler\11.1\060\tbb\ia32\vc9\bin;C:\Program Files\Intel\Compiler\11.1\060\ipp\ia32\bin;C:\Program Files\Intel\Compiler\11.1\060\lib\ia32;C:\Program Files\Intel\Compiler\11.1\060\mkl\ia32\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\9.0\DLLShared\;C:\Program Files\Windows Imaging\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Perforce;C:\Program Files\MATLAB\R2010a\bin;C:\Program Files\doxygen\bin;C:\Program Files\Graphviz2.26.3\bin;C:\Program Files\QuickTime\QTSystem\;C:\strawberry\c\bin;C:\strawberry\perl\site\bin;C:\strawberry\perl\bin;C:\Program Files\OMake\bin\;C:\MinGW\bin;C:\Program Files\Java\jdk1.6.0_23\bin;C:\Program Files\Code Collaborator Client;C:\Program Files\OpenLibraries\bin;C:/Program Files/Texas Instruments/xdctools_3_20_07_86;C:\SparkBuild\i686_win32\bin;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\emulation\analysis\bin\
java.net.useSystemProxies=true
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_14-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_14
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_14-b03
javaplugin.proxy.config.type=direct
line.separator=
org.eclipse.cdt.debug.ui.debuggerActive=false
org.eclipse.swt.browser.XULRunnerInitialized=true
org.eclipse.ui.workbench.activePerspective=org.eclipse.cdt.ui.CPerspective
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax.activity,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=com.ti.ccstudio.osgi,org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\Program Files\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\bundles
osgi.configuration.area=file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/configuration/
osgi.framework=file:/c:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi_3.2.0.vTI-201010201600.jar
osgi.framework.beginningstartlevel=1
osgi.framework.extensions=com.ti.ccstudio.osgi
osgi.framework.shape=jar
osgi.framework.version=3.2.0.vTI-201010201600
osgi.frameworkClassPath=., file:c:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.osgi_4.0.0.201010201600.jar
osgi.install.area=file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/
osgi.instance.area=file:/E:/home/rrang/projects/perforce/mesa/orcca/CCSv4/
osgi.logfile=E:\home\rrang\projects\perforce\mesa\orcca\CCSv4\.metadata\.log
osgi.manifest.cache=C:\Program Files\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\Program Files\Texas Instruments\ccsv4\eclipse\plugins\com.ti.ccstudio.branding_4.1.0.201010201600\splash.bmp
osgi.splashPath=platform:/base/plugins/com.ti.ccstudio.branding
osgi.syspath=c:\Program Files\Texas Instruments\ccsv4\eclipse\plugins
osgi.user.area=file:/C:/Documents and Settings/rrang/user/
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\rt.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\i18n.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\sunrsasign.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\jsse.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\jce.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\charsets.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\classes
sun.boot.library.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 3
user.country=US
user.dir=C:\Program Files\Texas Instruments\ccsv4\eclipse
user.home=C:\Documents and Settings\rrang
user.language=en
user.name=RRANG
user.timezone=America/Los_Angeles
user.variant=
xdc.path=C:/Program Files/Texas Instruments/ipc_1_21_02_23/packages;C:/Program Files/Texas Instruments/bios_6_30_03_46/packages;;C:/Program Files/Texas Instruments/xdctools_3_20_07_86/packages
xdc.root=C:/Program Files/Texas Instruments/xdctools_3_20_07_86
*** Features:
com.ti.ccstudio (4.0.0.201010201600) "CCE Product Branding"
com.ti.dvt.graph.visualization (2.0.0.201008091238) "Visualization Plug-in"
com.ti.dvt.profileanalysismanager (2.0.0.201008091238) "Profiler Analysis Manager"
com.ti.dvt.rta (2.0.0.201008091238) "DSP/BIOS RTA"
com.ti.dvt.scripting.ui (4.0.0.201007072025) "DVT Scripting Plugin"
org.eclipse.cdt (3.1.0.vTI-201010201600) "Eclipse C/C++ Development Tools"
org.eclipse.platform (3.2.0.vTI-201010201600) "Eclipse Platform"
org.eclipse.rcp (3.2.0.vTI-201010201600) "Eclipse RCP"
org.eclipse.rtsc.xdctools_3.20 (3.20.7.86) "XDCtools UI Plugin"
org.eclipse.tm.terminal (1.0.0.vTI-201010201600) "Target Management Terminal Widget"
*** Plug-in Registry:
com.ibm.icu (3.4.4.1) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
com.ti.ccstudio.apps (4.2.0.201010201600) "CCS Headless Applications" [Resolved]
com.ti.ccstudio.binaryparser (4.0.0.201010201600) "CCE Binary Parser" [Active]
com.ti.ccstudio.branding (4.1.0.201010201600) "CCE Product Branding" [Active]
com.ti.ccstudio.breakpoint (4.0.0.201010201600) "Property Breakpoint Interfaces" [Resolved]
com.ti.ccstudio.breakpoint.core (4.0.0.201010201600) "Property Breakpoint Core" [Active]
com.ti.ccstudio.breakpoint.ui (4.0.0.201010201600) "Property Breakpoint User Interface" [Active]
com.ti.ccstudio.buildDefinitions.C6000 (4.2.0.201010201600) "CCS C6000 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.C6000_5.3 (4.2.0.201010201600) "C6000 v5.3 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_6.0 (4.2.0.201010201600) "C6000 v6.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_6.1 (4.2.0.201010201600) "C6000 v6.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_7.0 (4.2.0.201010201600) "C6000 v7.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_7.2 (4.1.3.201010201600) "C6000 v7.2 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_legacy (4.1.0.201010201600) "C6000 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.core (4.2.0.201010201600) "Managed Build Definitions Core" [Active]
com.ti.ccstudio.buildDefinitions.GNU (4.1.0.201010201600) "CCE GNU Managed Build Definitions" [Active]
com.ti.ccstudio.c6000help.doc (4.0.0) "com.ti.ccstudio.c6000help.doc" [Resolved]
com.ti.ccstudio.debug.breakpoint.ui (4.0.0.201010201600) "TI Debugger Breakpoint User Interface" [Active]
com.ti.ccstudio.debug.cacheview (1.0.0) "Cache View Plug-in" [Resolved]
com.ti.ccstudio.debug.core (4.0.0.201010201600) "CCE Debug Core" [Active]
com.ti.ccstudio.debug.memoryserver (4.0.0.201010201600) "Memory Server Plugin" [Resolved]
com.ti.ccstudio.debug.mptv (4.0.0.201010201600) "MptvName" [Resolved]
com.ti.ccstudio.debug.registers.ui (4.1.0.201010201600) "Registers UI Plug-in" [Active]
com.ti.ccstudio.debug.server.extensions (4.0.0.201010201600) "CCE Debug Server Extensions" [Active]
com.ti.ccstudio.debug.server.factory (4.0.0.201010201600) "CCE Debug Server Factory" [Active]
com.ti.ccstudio.debug.trace.core (4.0.0.201010201600) "Trace Core" [Active]
com.ti.ccstudio.debug.trace.ui (4.0.0.201010201600) "Trace UI" [Resolved]
com.ti.ccstudio.debug.ui (4.2.0.201010201600) "CCE Debug User Interface" [Active]
com.ti.ccstudio.device.setup (4.2.0.201010201600) "CCS Device Setup" [Active]
com.ti.ccstudio.disassembly.core (4.1.0.201010201600) "CCS Disassembly Core Plug-in" [Active]
com.ti.ccstudio.disassembly.ui (4.1.0.201010201600) "CCS Disassembly UI Plug-in" [Active]
com.ti.ccstudio.errorparser (4.0.0.201010201600) "CCE Error Parser" [Active]
com.ti.ccstudio.gelhelp.doc (4.0.0.201010201600) "GEL Help Document Plug-in" [Resolved]
com.ti.ccstudio.jline (4.0.0.201010201600) "Jline" [Resolved]
com.ti.ccstudio.mainhelp.doc (4.0.0) "CCS Help 4.0 Plugin" [Resolved]
com.ti.ccstudio.managedbuild.core (4.2.0.201010201600) "CCS Managed Build Core" [Active]
com.ti.ccstudio.managedbuild.ui (4.2.0.201010201600) "CCE Managed Build User Interface" [Active]
com.ti.ccstudio.marker (4.0.0.201010201600) "Marker Plug-in" [Active]
com.ti.ccstudio.memory.ui (4.0.0.201010201600) "CCS Memory UI Plug-in" [Active]
com.ti.ccstudio.multi.purpose.view (4.2.0.201010201600) "CCS Control Panel View" [Active]
com.ti.ccstudio.multi.purpose.view.contributors (4.1.0.201010201600) "Control Panel View Contributors" [Active]
com.ti.ccstudio.osgi (4.0.0.201010201600) "CCE OSGi Hooks" [Resolved]
com.ti.ccstudio.pinconnect (4.0.0.201010201600) "PinConnect Tool Plug-in" [Resolved]
com.ti.ccstudio.pinport.common (4.0.0.201010201600) "Common Plug-in For Pin and Port Connect Tools" [Resolved]
com.ti.ccstudio.portconnect (4.0.0.201010201600) "PortConnect Tool Plug-in" [Resolved]
com.ti.ccstudio.product.paths (4.1.0.201010201600) "CCS Product Paths" [Active]
com.ti.ccstudio.profile.setup (4.0.0.201010201600) "Profile Setup Plug-in" [Resolved]
com.ti.ccstudio.profile.setup.ui (4.0.0.201010201600) "Profile SetupUI Plug-in" [Active]
com.ti.ccstudio.project.core (4.2.0.201010201600) "CCS Project Core" [Resolved]
com.ti.ccstudio.project.templates (4.2.0.201010201600) "CCS Built-in Project Templates" [Resolved]
com.ti.ccstudio.project.ui (4.2.0.201010201600) "CCE Project User Interface" [Active]
com.ti.ccstudio.rhino (4.0.0.201010201600) "CCE Rhino JavaScript Engine" [Resolved]
com.ti.ccstudio.scripting.console (4.0.0.201010201600) "Scripting Console" [Active]
com.ti.ccstudio.scripting.dss (4.0.0.201010201600) "Debug Server Scripting" [Resolved]
com.ti.ccstudio.scripting.environment (4.0.0.201010201600) "CCE Scripting Environment" [Resolved]
com.ti.ccstudio.scripting.gss (4.2.0.201010201600) "CodeComposer Studio Scripting" [Resolved]
com.ti.ccstudio.scripting.ui (4.0.0.201010201600) "User Interface Scripting" [Resolved]
com.ti.ccstudio.system.hotmenu (4.0.0.201010201600) "CCS System Hotmenu Plug-in" [Active]
com.ti.ccstudio.system.setup (4.2.0.201010201600) "CCE System Setup" [Active]
com.ti.ccstudio.system.setup.ui (4.0.0.201010201600) "CCS System Setup Editor Plug-in" [Active]
com.ti.ccstudio.trace.control (4.1.0.201010201600) "Trace Control Plug-in" [Active]
com.ti.ccstudio.ui (4.1.0.201010201600) "CCS Platform User Interface" [Active]
com.ti.ccstudio.ui.cheatsheets (4.0.0.201010201600) "Cheatsheets Plug-in" [Active]
com.ti.ccstudio.ui.forms (4.0.0.201010201600) "Forms Plug-in" [Resolved]
com.ti.ccstudio.update (4.0.0.201010201600) "CCS Update Plug-in" [Active]
com.ti.ccstudio.useaccess (4.0.0.201010201600) "Use Access Plug-in" [Active]
com.ti.common.core (4.2.0.201010201600) "Common TI Platform Core" [Active]
com.ti.common.managedbuild.core (4.2.0.201010201600) "TI Common Managed-Build Core" [Active]
com.ti.common.managedbuild.ui (4.2.0.201010201600) "TI Common Managed-Build UI" [Active]
com.ti.common.project.core (4.2.0.201010201600) "TI Common Project Core" [Resolved]
com.ti.common.project.ui (4.2.0.201010201600) "TI Common Project UI" [Active]
com.ti.common.ui (4.1.0.201010201600) "Common TI User Interface" [Active]
com.ti.common.update.discovery (4.1.1.201010201600) "Extension Site Discovery" [Active]
com.ti.dvt.analysis.framework (2.0.0.201008091238) "DVT Analysis Framework" [Resolved]
com.ti.dvt.cceideadapter (2.0.0.201008091238) "CCStudio v4 IDE Adapter" [Resolved]
com.ti.dvt.ccesymbolmanager (2.0.0.201008091238) "CCStudio 4.0 Symbol Manager" [Resolved]
com.ti.dvt.codegenCoverage (2.0.0.201008091238) "Codegen_Code_Coverage Plug-in" [Active]
com.ti.dvt.control.engine (2.0.0.201008091238) "DVT Control Engine" [Resolved]
com.ti.dvt.control.gui (2.0.0.201008091238) "DVT Control GUI" [Resolved]
com.ti.dvt.coverageplugin (2.0.0.201008091238) "Coverageplugin Plug-in" [Active]
com.ti.dvt.datamodel (2.0.0.201008091238) "DVT Model" [Active]
com.ti.dvt.graph.visualization (1.0.0.201007072025) "Visualization Plug-in" [Installed]
com.ti.dvt.graph.visualization (2.0.0.201008091238) "Visualization Plug-in" [Active]
com.ti.dvt.graph.visualization.doc (2.0.0.201008091238) "Graph Visualization Help Plug-in" [Resolved]
com.ti.dvt.gridview (2.0.0.201008091238) "Gridview Plug-in" [Active]
com.ti.dvt.ideadapter (2.0.0.201008091238) "IDEAdapter" [Active]
com.ti.dvt.ideadapterplugin (2.0.0.201008091238) "IDEAdapter Plug-in" [Active]
com.ti.dvt.ofssymbolmanager (2.0.0.201008091238) "OFSSymbolManager Plug-in" [Resolved]
com.ti.dvt.profileanalysis (2.0.0.201008091238) "DVT Profile Analysis Providers" [Resolved]
com.ti.dvt.profileanalysis.doc (2.0.0.201008091238) "DVT Profile Analysis Providers Help" [Resolved]
com.ti.dvt.profileanalysismanager (1.0.0.201007072025) "Profiler Analysis Manager" [Installed]
com.ti.dvt.profileanalysismanager (2.0.0.201008091238) "Profiler Analysis Manager" [Resolved]
com.ti.dvt.profileanalysismanagerplugin (1.0.0.201007072025) "Profile Server Plug-in" [Installed]
com.ti.dvt.profileanalysismanagerplugin (2.0.0.201008091238) "Profile Server Plug-in" [Active]
com.ti.dvt.profiledata (2.0.0.201008091238) "Profile Data Source" [Resolved]
com.ti.dvt.rovsupport (2.0.0.201008091238) "Rovsupport Plug-in" [Active]
com.ti.dvt.rovsupport.doc (2.0.0.201008091238) "ROV Support Doc Plug-in" [Resolved]
com.ti.dvt.rta (1.0.0.201007072025) "DSP/BIOS RTA" [Installed]
com.ti.dvt.rta (2.0.0.201008091238) "DSP/BIOS RTA" [Active]
com.ti.dvt.rta.doc (2.0.0.201008091238) "RTA Help" [Resolved]
com.ti.dvt.rta.interfaces (1.0.0.201007072025) "RTA interfaces" [Installed]
com.ti.dvt.rta.interfaces (2.0.0.201008091238) "RTA interfaces" [Resolved]
com.ti.dvt.scripting.ui (1.0.0.201007072025) "DVT Scripting Plugin" [Resolved]
com.ti.dvt.server (3.20.7.86) "ROV Controller" [Active]
com.ti.dvt.sourceref (2.0.0.201008091238) "Source Reference Plug-in" [Resolved]
com.ti.dvt.sourcerefplugin (2.0.0.201008091238) "Source Reference Preference Plug-in" [Resolved]
com.ti.dvt.symbolmanager (2.0.0.201008091238) "SymbolManager" [Resolved]
com.ti.dvt.symbolmanagerplugin (2.0.0.201008091238) "SymbolManager Plug-in" [Active]
com.ti.dvt.tidisassembly (2.0.0.201008091238) "TIDisassembly Plug-in" [Resolved]
com.ti.dvt.trace (1.0.0.201007072025) "DVT Trace Analyzer" [Active]
com.ti.dvt.trace.doc (1.1.0.201007072025) "Trace_Analyzer_User_Guide" [Resolved]
com.ti.dvt.ui (2.0.0.201008091238) "DvtUI Plug-in" [Active]
com.ti.dvt.ui.doc (2.0.0.201008091238) "com.ti.dvt.ui.doc" [Resolved]
com.ti.dvt.via.doc (2.0.0.201008091238) "Image Analyzer" [Resolved]
com.ti.dvt.via.imvr (1.0.0.201007072025) "Image Viewer Plug-in" [Installed]
com.ti.dvt.via.imvr (2.0.0.201008091238) "Image Viewer Plug-in" [Active]
com.ti.dvt.via.plugin (2.0.0.201008091238) "Image Analyzer" [Active]
com.ti.dvt.via.plugin.ccs (2.0.0.201008091238) "Image Analyzer (CCS)" [Active]
com.ti.fnc (4.0.0.201010201600) "FlexNet Connect Plug-in" [Active]
com.ti.rta (3.20.7.86) "XDC RTA Plug-in" [Resolved]
com.ti.rta.support (3.20.7.86) "Shared ROV interface implementations" [Active]
com.ti.rtfs.rtscRegistry_1.10.01.31 (1.10.01.31) "RTFS 1.10.01.31" [Resolved]
com.ti.rtsc.IPC.product_1.21.2.23 (1.21.2.23) "IPC (Multicore and I/O) Tool Plugin" [Resolved]
com.ti.rtsc.IPC.product.ui (1.21.2.23) "IPC (Multicore and I/O) UI Plugin" [Resolved]
com.ti.rtsc.SYSBIOS.product_6.30.3.46 (6.30.3.46) "SYS/BIOS Tool Plugin" [Resolved]
com.ti.rtsc.SYSBIOS.product.ui (6.30.3.46) "SYS/BIOS UI Plugin" [Resolved]
com.ti.sdo.edma3.rtscRegistry_02.10.02 (02.10.02) "EDMA3 LLD 02.10.02 Help" [Resolved]
com.ti.targets.omf (3.20.7.86) "Object file readers" [Resolved]
com.ti.util (2.0.0.201008091238) "Util Plug-in" [Resolved]
com.ti.util.ui (2.0.0.201008091238) "Util Plug-in" [Active]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.cdt (3.1.0.200606261600) "Eclipse C/C++ Development Tools" [Resolved]
org.eclipse.cdt.core (3.1.0.vTI-201010201600) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.win32 (3.1.0.200606261600) "C/C++ Development Tools Core for Windows" [Resolved]
org.eclipse.cdt.debug.core (3.1.0.vTI-201010201600) "C/C++ Development Tools Debug Model" [Active]
org.eclipse.cdt.debug.mi.core (3.1.0.200606261600) "C/C++ Development Tools GDB/MI CDI Debugger Core" [Resolved]
org.eclipse.cdt.debug.mi.ui (3.1.0.200606261600) "C/C++ Development Tools GDB/MI CDI Debugger UI" [Resolved]
org.eclipse.cdt.debug.ui (3.1.0.vTI-201010201600) "C/C++ Development Tools Debugger UI" [Active]
org.eclipse.cdt.launch (3.1.0.vTI-201010201600) "C/C++ Development Tools Launching Support" [Active]
org.eclipse.cdt.make.core (3.1.0.vTI-201010201600) "C/C++ Standard make Build Core" [Resolved]
org.eclipse.cdt.make.ui (3.1.0.vTI-201010201600) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (3.1.0.vTI-201010201600) "C/C++ Managed Builder Core" [Active]
org.eclipse.cdt.managedbuilder.gnu.ui (3.1.0.vTI-201010201600) "GNU Managed Build Definitions" [Resolved]
org.eclipse.cdt.managedbuilder.ui (3.1.0.vTI-201010201600) "C/C++ Managed Builder UI" [Active]
org.eclipse.cdt.refactoring (3.1.0.vTI-201010201600) "C/C++ Refactoring" [Resolved]
org.eclipse.cdt.ui (3.1.0.vTI-201010201600) "C/C++ Development Tools UI" [Active]
org.eclipse.compare (3.2.0.vTI-201010201600) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism" [Active]
org.eclipse.core.expressions (3.2.0.v20060605-1400) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.2.0.v20060605-1400) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File System for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.vTI-201010201600) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.0.vTI-201010201600) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.vTI-201010201600) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.0.v20060603) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Active]
org.eclipse.dd.debug.memory.renderings.traditional (1.0.0.vTI-201010201600) "Traditional Memory Rendering" [Resolved]
org.eclipse.debug.core (3.2.0.vTI-201010201600) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.0.vTI-201010201600) "Debug UI" [Active]
org.eclipse.draw2d (3.2.0.v20060626) "Draw2d" [Resolved]
org.eclipse.equinox.common (3.2.0.vTI-201005061800) "Common Eclipse Runtime" [Installed]
org.eclipse.equinox.common (3.2.0.vTI-201010201600) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.common (3.2.0.vTI-201008051800) "Common Eclipse Runtime" [Installed]
org.eclipse.equinox.preferences (3.2.0.v20060601) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.0.v20060601) "Extension Registry Support" [Active]
org.eclipse.gef (3.2.0.v20060626) "Graphical Editing Framework" [Resolved]
org.eclipse.help (3.2.0.v20060602) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server" [Resolved]
org.eclipse.help.base (3.2.0.v20060601) "Help System Base" [Active]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Active]
org.eclipse.help.webapp (3.2.0.v20060602) "Help System Webapp" [Resolved]
org.eclipse.jface (3.2.0.vTI-201010201600) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding" [Resolved]
org.eclipse.jface.text (3.2.0.vTI-201010201600) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.0.v20060605-1400) "Refactoring Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.2.0.v20060605-1400) "Refactoring UI" [Resolved]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development Environment Runtime" [Resolved]
org.eclipse.platform (3.2.0.vTI-201010201600) "Eclipse Platform" [Resolved]
org.eclipse.rcp (3.2.0.vTI-201010201600) "Eclipse RCP" [Resolved]
org.eclipse.rtsc.project.templates (3.20.7.86) "RTSC Built-in Project Templates" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS (1.2.0.201010201600) "DSP/BIOS Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31 (1.2.0.201010201600) "DSP/BIOS v5.31 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40 (1.2.0.201010201600) "DSP/BIOS v5.40 Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC (1.2.0.201010201600) "XDC Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00 (1.2.0.201010201600) "XDC v3.00 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10 (1.2.0.201010201600) "XDC v3.10 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15 (1.2.0.201010201600) "XDC v3.15 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16 (1.2.0.201010201600) "XDC v3.16 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.contenttype (3.20.7.86) "RTSC file content describers" [Resolved]
org.eclipse.rtsc.xdctools.core (3.20.7.86) "XDCtools core" [Active]
org.eclipse.rtsc.xdctools.managedbuild.core (1.2.0.201010201600) "RTSC Managed Build Core" [Active]
org.eclipse.rtsc.xdctools.managedbuild.ui (1.2.0.201010201600) "RTSC Managed Build UI" [Active]
org.eclipse.rtsc.xdctools.model (3.20.7.86) "Model Plug-in" [Active]
org.eclipse.rtsc.xdctools.model.lang (3.20.7.86) "Lang Fragment" [Resolved]
org.eclipse.rtsc.xdctools.product_3.20.7.86 (3.20.7.86) "XDCtools Tool Plugin" [Resolved]
org.eclipse.rtsc.xdctools.product.ui (3.20.7.86) "XDCtools UI Plugin" [Resolved]
org.eclipse.rtsc.xdctools.rta (3.20.7.86) "XDCtools RTA" [Active]
org.eclipse.rtsc.xdctools.server (3.20.7.86) "XDCscript command server" [Active]
org.eclipse.rtsc.xdctools.sg (3.20.7.86) "XDCtools SG Plug-in" [Resolved]
org.eclipse.rtsc.xdctools.sg.def (3.20.7.86) "XDCtools SG Def Plug-in" [Resolved]
org.eclipse.rtsc.xdctools.ui (3.20.7.86) "Eclipse Plug-in" [Active]
org.eclipse.rtsc.xdctools.ui.contentassist (3.20.7.86) "RTSC C/C++ Content Assist" [Active]
org.eclipse.rtsc.xdctools.ui.editors (3.20.7.86) "Editors Plug-in" [Resolved]
org.eclipse.search (3.2.0.vTI-201010201600) "Search Support" [Active]
org.eclipse.swt (3.2.0.vTI-201010201600) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.0.vTI-201010201600) "Standard Widget Toolkit for Windows" [Resolved]
org.eclipse.team.core (3.2.0.I200606051140) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.0.M20060628) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.2.0.I200606011710) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200606051140) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.0.I200606051140) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.0.I200606051140) "Team Support UI" [Active]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tm.terminal (1.0.0.vTI-201010201600) "Target Management Terminal Widget" [Resolved]
org.eclipse.tm.terminal.serial (1.0.0.v20070605) "Target Management Terminal Serial Connector" [Resolved]
org.eclipse.tm.terminal.view (1.0.0.v20070620) "Target Management Terminal View" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.0.vTI-201010201600) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.0.vTI-201010201600) "Cheat Sheets" [Active]
org.eclipse.ui.console (3.1.100.vTI-201010201600) "Console" [Active]
org.eclipse.ui.editors (3.2.0.vTI-201010201600) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.100.vTI-201010201600) "External Tools" [Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.2.0.vTI-201010201600) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.0.v20060601) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.0.v20060602) "Universal Welcome" [Resolved]
org.eclipse.ui.navigator (3.2.0.I20060605-1400) "Common Navigator View" [Resolved]
org.eclipse.ui.navigator.resources (3.2.0.I20060605-1400) "Navigator Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21 Presentation Plug-in" [Resolved]
org.eclipse.ui.views (3.2.0.vTI-201010201600) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.0.I20060605-1400) "Tabbed Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.2.0.vTI-201010201600) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.vTI-201010201600) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.2.0.vTI-201010201600) "Install/Update Configurator" [Active]
org.eclipse.update.core (3.2.0.vTI-201010201600) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.0.vTI-201010201600) "Install/Update Core for Windows" [Resolved]
org.eclipse.update.scheduler (3.2.0.v20060605) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.2.0.vTI-201010201600) "Install/Update UI" [Active]
system.bundle (3.2.0.vTI-201010201600) "OSGi System Bundle" [Active]
xdc.tools.xgconf.modeldata (3.20.7.86) "Modeldata Plug-in" [Resolved]
*** User Preferences:
- removed-
*** Current Install Configuration:
Install configuration:
Last changed on Mar 31, 2011
Location: file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/configuration/org.eclipse.update/platform.xml
Configured sites:
platform:/base/
file:/C:/Program Files/Texas Instruments/bios_6_30_03_46/eclipse/
file:/C:/Program Files/Texas Instruments/ipc_1_21_02_23/eclipse/
file:/C:/Program Files/Texas Instruments/edma3_lld_02_10_04_01/eclipse/
file:/C:/Program Files/Texas Instruments/rtfs_1_10_01_31/eclipse/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/
Configured features:
ID: com.ti.ccstudio.emu.5.0.158.1, Version: 5.0.158.1
ID: com.ti.ccstudio.emu.5.0.104.0, Version: 5.0.104.0
ID: com.ti.bios_5.41, Version: 5.41.0.06
ID: org.eclipse.cdt, Version: 3.1.0.200606261600
ID: com.ti.dvt.rov, Version: 2.0.0.201008091238
ID: com.ti.ccstudio.product, Version: 4.2.1.00004
ID: com.ti.cgt.c6000.7.0, Version: 7.0.4
ID: com.bh.ccstudio.emulation, Version: 4.2.0.9
ID: com.ti.dvt.ccstudio, Version: 2.0.0.201008091238
ID: com.ti.ccstudio.c6000, Version: 4.0.0.201010201600
ID: org.eclipse.tm.terminal, Version: 1.0.0.vTI-201010201600
ID: org.eclipse.platform, Version: 3.2.0.vTI-201010201600
ID: com.ti.cgt.c6000.6.1, Version: 6.1.19
ID: com.ti.dvt.profileanalysismanager, Version: 2.0.0.201008091238
ID: com.ti.dvt.via.ccs, Version: 2.0.0.201008091238
ID: com.ti.dvt.analysis, Version: 2.0.0.201008091238
ID: com.ti.dvt.trace.ccs, Version: 2.1.0.201007072025
ID: com.ti.ccstudio.branding, Version: 4.0.0.201010201600
ID: com.sd.ccstudio.emulation, Version: 4.2.2.4
ID: org.eclipse.rcp, Version: 3.2.0.vTI-201010201600
ID: com.ti.ccstudio.rtsc, Version: 4.0.0.201010201600
ID: com.ti.dvt.rta, Version: 2.0.0.201008091238
ID: com.ti.dvt.graph.visualization, Version: 2.0.0.201008091238
ID: com.ti.dvt.core.ccstudio, Version: 2.0.0.201008091238
ID: com.ti.dvt.scripting.ui, Version: 1.0.0.201007072025
ID: com.ti.dvt.control, Version: 2.0.0.201008091238
ID: com.ti.bios_6.30, Version: 6.30.3.46
ID: com.ti.ipc_1.21, Version: 1.21.2.23
ID: com.ti.sdo.edma3_02.10.02, Version: 2.10.2
ID: com.ti.rtfs_1.10.01.31, Version: 1.10.1.31
ID: org.eclipse.rtsc.xdctools.product.ui, Version: 3.20.7.86
Configured plug-ins:
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ibm.icu_3.4.4.1.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.jcraft.jsch_0.1.28.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.apps_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.binaryparser_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.branding_4.1.0.201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint.core_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_5.3_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_6.0_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_6.1_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_7.0_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_7.2_4.1.3.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_legacy_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.GNU_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.c6000help.doc_4.0.0.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.breakpoint.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.cacheview_1.0.0.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.core_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.memoryserver_4.0.0.201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.mptv_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.registers.ui_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.server.extensions_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.server.factory_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.core_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.device.setup_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.disassembly.core_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.disassembly.ui_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.errorparser_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.gelhelp.doc_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.jline_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.mainhelp.doc_4.0.0.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.managedbuild.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.managedbuild.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.marker_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.memory.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.multi.purpose.view.contributors_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.multi.purpose.view_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.osgi_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.pinconnect_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.pinport.common_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.portconnect_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.product.paths_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.profile.setup.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.profile.setup_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.templates_4.2.0.201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.rhino_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.console_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.dss_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.environment_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.gss_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.hotmenu_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.setup.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.setup_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.trace.control_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui.cheatsheets_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui.forms_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.update_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.useaccess_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.managedbuild.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.managedbuild.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.project.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.project.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.ui_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.update.discovery_4.1.1.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.analysis.framework_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.cceideadapter_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ccesymbolmanager_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.codegenCoverage_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.control.engine_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.control.gui_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.coverageplugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.datamodel_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization.doc_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.gridview_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ideadapterplugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ideadapter_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ofssymbolmanager_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysis.doc_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanagerplugin_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanagerplugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanager_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanager_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysis_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profiledata_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rovsupport.doc_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rovsupport_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.doc_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.interfaces_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.interfaces_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.scripting.ui_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.sourcerefplugin_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.sourceref_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.symbolmanagerplugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.symbolmanager_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.tidisassembly_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.trace.doc_1.1.0.201007072025/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.trace_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ui.doc_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ui_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.doc_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.imvr_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.imvr_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.plugin.ccs_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.plugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.fnc_4.0.0.201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.util.ui_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.util_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.apache.ant_1.6.5/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.apache.lucene_1.4.103.v20060601/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ant.core_3.1.100.v20060531.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.core.win32_3.1.0.200606261600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.core_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.core_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.mi.core_3.1.0.200606261600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.mi.ui_3.1.0.200606261600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.launch_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.make.core_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.make.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.core_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.gnu.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.refactoring_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt_3.1.0.200606261600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.compare_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.boot_3.1.100.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.commands_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.contenttype_3.2.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.expressions_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.filebuffers_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.filesystem.win32.x86_1.0.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.filesystem_1.0.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.jobs_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources.compatibility_3.2.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources.win32_3.2.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime.compatibility.auth_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime.compatibility.registry_3.2.0.v20060603/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime.compatibility_3.1.100.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.variables_3.1.100.v20060605.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.dd.debug.memory.renderings.traditional_1.0.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.debug.core_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.debug.ui_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.draw2d_3.2.0.v20060626.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.vTI-201005061800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.vTI-201008051800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.preferences_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.registry_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.gef_3.2.0.v20060626.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.appserver_3.1.100.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.base_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.ui_3.2.0.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.webapp_3.2.0.v20060602/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help_3.2.0.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface.databinding_1.0.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface.text_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ltk.core.refactoring_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi.services_3.1.100.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi.util_3.1.100.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.pde.runtime_3.2.0.v20060605.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.platform_3.2.0.vTI-201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rcp_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.managedbuild.core_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.managedbuild.ui_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.search_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.swt.win32.win32.x86_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.swt_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.core_3.2.0.I200606051140.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.core_3.2.0.M20060628.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.2.0.I200606051140.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.ssh_3.2.0.I200606011710.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.ui_3.2.0.I200606051140.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.ui_3.2.0.I200606051140.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.text_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal.serial_1.0.0.v20070605.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal.view_1.0.0.v20070620.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal_1.0.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tomcat_4.1.130.v20060601/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.browser_3.2.0.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.cheatsheets_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.console_3.1.100.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.editors_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.externaltools_3.1.100.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.forms_3.2.0.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.ide_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.intro.universal_3.2.0.v20060602/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.intro_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.navigator.resources_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.navigator_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.presentations.r21_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.views.properties.tabbed_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.views_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.win32_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I20060605-1400/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.configurator_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.core.win32_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.core_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.scheduler_3.2.0.v20060605.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.ui_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/bios_6_30_03_46/eclipse/plugins/com.ti.rtsc.SYSBIOS.product.ui_6.30.3.46/
file:/C:/Program Files/Texas Instruments/bios_6_30_03_46/eclipse/plugins/com.ti.rtsc.SYSBIOS.product_6.30.3.46/
file:/C:/Program Files/Texas Instruments/ipc_1_21_02_23/eclipse/plugins/com.ti.rtsc.IPC.product.ui_1.21.2.23/
file:/C:/Program Files/Texas Instruments/ipc_1_21_02_23/eclipse/plugins/com.ti.rtsc.IPC.product_1.21.2.23/
file:/C:/Program Files/Texas Instruments/edma3_lld_02_10_04_01/eclipse/plugins/com.ti.sdo.edma3.rtscRegistry_02.10.02/
file:/C:/Program Files/Texas Instruments/rtfs_1_10_01_31/eclipse/plugins/com.ti.rtfs.rtscRegistry_1.10.01.31/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/com.ti.dvt.server_3.20.7.86.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/com.ti.rta.support_3.20.7.86.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/com.ti.rta_3.20.7.86.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/com.ti.targets.omf_3.20.7.86/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.project.templates_3.20.7.86.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.contenttype_3.20.7.86.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.core_3.20.7.86/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.model.lang_3.20.7.86.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.model_3.20.7.86.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.product.ui_3.20.7.86/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.product_3.20.7.86/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.rta_3.20.7.86/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.server_3.20.7.86/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.sg.def_3.20.7.86.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.sg_3.20.7.86.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.ui.contentassist_3.20.7.86.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.ui.editors_3.20.7.86.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/org.eclipse.rtsc.xdctools.ui_3.20.7.86.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_07_86/eclipse/plugins/xdc.tools.xgconf.modeldata_3.20.7.86.jar
Ram
