Is it possible to add a "Call Graph" feature to Code Composer Studio?
Dear all TI and Code Composer Studio developers,
I am not a top C programmer.  I rely on tracking an example project's Call Graph, chip vendor compiler's built-in macros, functions, structures, classes, etc, to create my own working projects.  Then, I will have other top developers to improve and debug my codes.  This tactic works very well on other top IC vendor's platform.
I also love TI's top hardware quality and vast amount of example projects.  However, I find it very difficult to read TI's CCS example codes.
Is it possible to add a "Call Graph" feature to Code Composer Studio?  Also, a new feature to search TI compiler and chip specific built-in macros, functions, structures, classes, etc.?
Rapid Development is a key to success nowadays.  Relaxed
    there is a call graph that is integrated into the Debug view. Please see the graphic in section 5.6 of the CCS User's Guide:
    https://software-dl.ti.com/ccs/esd/documents/users_guide/ccs_getting-started.html#building-and-running-your-project
    You can also generate a static call graph using CG XML utilities, in addition to being able to parse the symbols for other data.
    https://software-dl.ti.com/ccs/esd/documents/sdto_cgt_cg_xml_overview.html
    ki
  • Hello Ki,
    If I run CG XML utilities on Windows 10, do I have to install a perl environment?
  • If I run CG XML utilities on Windows 10, do I have to install a perl environment?
    Only if you want to run the scripts from Perl or want to modify/create scripts.
    Please see the attached getting started text file, section1:
    cg_xml - Code Generation Tools XML Processing Scripts
    getting_started.txt
    Introduction
    This is a package of Perl scripts used to process the XML files that come
    from the TI code generation tools.  Use it to do things like build a
    spreadsheet that details the size of all the sections, or figure out how much
    of the memory map is taken up by specific libraries.
    This file contains information for first time users.  Details on specific
    releases of the package are in the file readme.txt.
    Each script directory contains a readme.txt that summarizes its contents.
    Each script is listed, along with a one line summary of what it does.
    Table of Contents
    1. First Steps
    2. File Listing
    3. Execute the Scripts
    4. Standalone Executables Use the System Temporary Directory
    5. Control How Standalone Executables use Temporary Directories and Files
    6. Keep the Files Together
    1. First Steps
    - Review the slides in overview.ppt.
    - To run the executable versions of the Perl scripts (available starting
      with release 1.20.00), nothing further needs to be installed.  Typically,
      the bin directory of this package is added to the system path.  To run the
      Perl scripts directly from Perl, or to develop scripts of your own, these
      further steps are required.
    - Install Perl version 5.8.3 or higher.  For PC users, we recommend
      Activestate Perl: http://www.activestate.com/Products/ActivePerl/
    - Install the Perl module XML::Simple version 2.12 or higher.  If you
      install ActiveState Perl version 5.8.4 or higher, this will be done
      for you.
    - To see the documentation on any script or module, run the command ...
       C:\>perldoc <name of file>
    - Documentation is also available in HTML form.  Point your web browser at
      the file index.htm in the root directory of the package.
    2. File Listing
    Dir or File            Contains
    readme.txt             Release specific information
    getting_started.txt    This file
    overview.ppt           PowerPoint slides that introduce XML, the XML output
                              available from the linker and OFD, and examples of
                              scripts that use the XML to do cool things
    index.htm              Documentation in HTML form
    map\*                  Files for working with linker map files in XML
    ofd\*                  Files for working with OFD created XML files
    docs\*                 HTML documentation
    bin\*                  Binary executable versions of the scripts
    utils\*                Latest version OFD that has XML filtering options
    cg_xml_<version>_Manifest.pdf  Software manifest, including the license.  By
                              convention, the version number is included in the
    			  file name.
    XML - eXtensible Markup Language
    OFD - Object File Display Utility
    3. Executing the Scripts
    This section is written for those who want to execute the Perl scripts
    directly from Perl.  If you only run the standalone executable versions
    of the scripts, you can ignore this section.
    As of release 0.70, the scripts can be viewed as yet another group of
    executables.  Modify the executables path to refer to the cg_xml\ofd and
    cg_xml\map directories in this package, and the scripts can be run from any
    directory.  For example ...
       c:\some\where\else>perl -S sectti.pl file.xml
    The perl -S option says to look for the script among the directories listed in
    the executables path.  Another advantage to adding the cg_xml directories to
    the path is that the "perldoc" command will work regardless of the current
    directory.
    If you do not want to modify your executables path, specifying the complete
    path to the script will work as well.  For example ...
       C:\some\where\else>perl \cg_xml\ofd\sectti.pl file.xml
    Supplying XML via Pipes
    The XML from the object file display utility (OFD) can be supplied via
    pipes.  For example ...
       C:\>ofd6x -x file.out | perl -S sectti.pl
    Supplying the XML via pipes can be slow on Windows systems.  It is sometimes
    faster (occasionally much faster) to use separate commands ...
       C:\>ofd6x -x -o=file.xml file.out
       C:\>perl -S sectti.pl file.xml
    On Unix systems, using pipes does not cause a speed issue.
    Most OFD scripts can read XML supplied via pipes, though not all of them.
    Run perldoc on the script to be sure.
    The MAP scripts, which read XML files created by the linker, cannot read
    an XML file supplied via pipes.  There is no need for it, because the linker
    can only output the XML to a named file, and not a script.
    Execution on Unix Systems
    This section presumes the cg_xml directories have been added to the
    executables path and all the scripts have execute permission set.
    This method of executing a script will always work ...
       % perl -S sectti.pl file.xml
    Executing a script directly ...
       % sectti.pl file.xml
    works fine on some Unix systems, including Cygwin.  Other Unix systems,
    such a Solaris SunOS, require the script have Unix text line endings,
    not Windows text line endings.  The scripts are maintained on a Windows
    system, and thus are supplied with Windows text line endings.  A number of
    solutions exist for converting Windows text files to Unix text files.
    Once a script can be executed directly, the Windows pipe example given above
    may be shortened further to ...
       % ofd6x -x file.out | sectti.pl
    A standalone Perl executable version of a script, such as sectti.exe, uses
    several files in a directory under the system temporary directory.  On
    Windows systems the temporary directory is typically:
       C:\Users\<username>\AppData\Local\Temp
    On Unix systems the temporary directory is typically /tmp.
    The first time an executable runs it installs those files and then uses
    them to execute.  On subsequent runs the installation step is not required,
    and thus the executable starts up much faster.
    Please insure the system temporary directory has permissions that allow
    any user to add directories.  On Unix systems, this typically requires
    that /tmp have all permissions set.
    To explicitly set the temporary directory where the standalone executables
    store temporary files, add the environment variable setting:
       PAR_GLOBAL_TMPDIR=<your directory path here>
    If you want the files in the temporary directory to be deleted each time a
    standalone executable completes execution, add the environment variable
    setting:
       PAR_GLOBAL_CLEAN=1
    Note such deletion of the temporary files will slow the startup of the
    standalone executables.
    Each of the scripts presumes a Perl module file that it uses is in the same
    directory.  OFD scripts use XML_TI_OFD.pm and linker map file scripts
    use XML_TI_MAP.pm.  Thus, do not copy a single script file to a different
    location and expect it to work.  The corresponding .pm file must be copied
    with it.
    Activestate Perl: www.activestate.com/.../
    for you.
