Part Number: CODECOMPOSER
Hi team,
I am supporting my cusotomer generating .bin file in CCS with the following method(C2000).
1. Modify C:\ti\ccs1040\ccs\utils\tiobj2bin\tiobj2bin.bat:
Change all the hex470 and ofd470 to HEX2000 and OFD2000.
2. Adding following post-build command in CCS:
"${CCS_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin.bat" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/ofd2000.exe" "${CG_TOOL_ROOT}/bin/hex2000.exe" "${CCS_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin.exe"
It works fine in most of the computers but on one computer it is reporting:
"C:/ti/ccs1010/ccs/utils/tiobj2bin/tiobj2bin.bat"聽"DH.out"聽"DH.bin"聽"C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/ofd2000.exe"聽"C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/hex2000.exe"聽"C:/ti/ccs1010/ccs/utils/tiobj2bin/mkhex4bin.exe"
makefile:207: recipe for target 'post-build' failed
process_begin: CreateProcess(NULL, C:/ti/ccs1010/ccs/utils/tiobj2bin/tiobj2bin.bat聽DH.out聽DH.bin聽C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/ofd2000.exe聽C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/hex2000.exe聽C:/ti/ccs1010/ccs/utils/tiobj2bin/mkhex4bin.exe, ...) failed.
make (e=2):
make (e=2): 系统找不到指定的文件(Cannot find file)
Could you help to check what is problem here? Or is there a standalone method to generate .bin from .out file, since converting .out file is always successful.
Brian
