Can not press run-button after debugging
Hello, I have Problems with Code Composer Studios V 6.2.0.
After pressing the Debug Button, i can not press the "run" Button to start.
Is there a possibility to fix that?
Anna
  • Hello Anna,
    You need the proper Debug context selected in the Debug view. Please click on the last node in the Debug view ("Texas Instruments XDS100v2 USB Debug Probe_0/CortexR5"). Once you do that, the target execution buttons (run, halt, step, etc) will be available. Note that it appears that the target is already running. Hence when you select the proper debug context, run button will still be greyed out. But the halt button will be available.
    ki
  • thank you for your answer, can you tell me, where exactly i can find the last node in the Debug view? because if i go to my Debug Configuratione, there is already a hook at "CortexR5"
    Thanks in advance
    Anna
  • The last node in your Debug view would be what I highlighted in the image below:
    ki
