Converting int to string in GEL
I'm implementing a script in GEL that saves a specific buffer from the target's memory into a file.
I want that the name of the file will increment every time I save the buffer.
Therefore I've added a counter to the save function and I would like the name of the file to be the counter in the function.
Is it possible ?
    This is not really supported. GEL is limited in this regard. I would suggest using DSS javascript instead with the Scripting Console. It appears you are already exploring this based on your other thread and this is correct path.
    ki
