Failed to install CCS 11
Hi team,
Windows is the latest version. CCS is failed to install. Would you help to check what happened?
Annie
  • Hi Annie,
    We have seen past isssue with the msp430 pack installer. We have not identified the root cause yet. Are you experiencing this or is this from your customer?
    One user found a conflict with Windows Subsystem for Linux (WSL). Is WSL installed on the machine with the issue?
    Also, what is the WIndows version being used?
    ki
  • Hi Ki,
    My Customer is experiencing  this issue. He has installed WSL and docker. The Windows version is V11.
    The tools he installed while learning about the MSP 430G2553 launchpad. This is the error message when installing ccs.
    Annie
  • He has installed WSL and docker. The Windows version is V11.
    Can the customer try uninstalling WSL and see if that helps?
    ki
  • Hi KL,
    Turn off the antivirus software that come with win and WSL, still this abnormal message.
    ti_msp430pack_header_files11.1.0_install.logti_msp430pack_header_files_setup_11.1.0_install.log
    The attachment is the installation log referred to in the error prompt
  • Log started 03/12/2022 at 16:04:04
    Preferred installation mode : unattended
    Trying to init installer in mode unattended
    Mode unattended successfully initialized
    [16:04:04] Error reading AppFolder property from C:/ti/ccs1110/ccs/eclipse/ccs.properties
    [16:04:04] Using default AppFolder property Texas Instruments/Code Composer Studio
    [16:04:04] eclipsedir = C:/ti/ccs1110/ccs/eclipse
  • [16:04:04] Error reading AppFolder property from C:/ti/ccs1110/ccs/eclipse/ccs.properties
    This error can be ignored. This is not the root cause of the installation failure.
    Can the customer provide this log: ti_msp430pack11.1.0_install.log
  • Hi KI,
    Log started 02/26/2022 at 14:22:03
    [14:22:03] Error reading AppFolder property from C:/ti/ccs1110/ccs/eclipse/ccs.properties
    [14:22:03] Using default AppFolder property Texas Instruments/Code Composer Studio
    [14:22:03] eclipsedir = C:/ti/ccs1110/ccs/eclipse
    Preparing to Install
    Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common
    Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb
    Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers
    Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers\TI_reg_ids
    Unpacking files
    Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers\msp430_emu.xml
    Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers\TI_reg_ids\MSP430_regids.xml
    Directory already exists: C:\ti\ccs1110\ccs\ccs_base\DebugServer\drivers
    Unpacking files
    Unpacking C:\ti\ccs1110\ccs\ccs_base\DebugServer\drivers\MSP430.dll
    Unpacking files
    Directory already exists: C:\ti\ccs1110\ccs\ccs_base\msp430
    Unpacking files
    Unpacking C:\ti\ccs1110\ccs\ccs_base\msp430\ReleaseNotes_MSP430_EmulatorsFiles.txt
    Directory already exists: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\DPInst
    Unpacking files
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\DPInst\DPInst64.exe
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\DPInst\DPInst.exe
    Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb\connections
    Unpacking files
    Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\connections\TIMSP430-USB.xml
    Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\connections\TIMSP430-USB2.xml
    Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\connections\TIMSP430-USB3.xml
    Directory already exists: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC
    Unpacking files
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC\msp430tools.inf
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC\msp430tools.cat
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC\USB_CDC_CERT.p7b
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC\installCerts.bat
    Directory already exists: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF
    Unpacking files
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF\430CDC.inf
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF\430cdc.cat
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF\installCerts.bat
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF\USB_eZ_RF.p7b
    Directory already exists: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64
    Unpacking files
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\WdfCoInstaller01009.dll
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\difxapi.dll
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\ump3410.cat
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\umpf3410.i51
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\umpusbvista.sys
    Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\usbuart3410.inf
    Unpacking files
    Unpacking C:\ti\ccs1110\ccs\ccs_base\DebugServer\drivers\TI_Bug_Icon_Red.ico
    Executing C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\USB_eZ-RF\installCerts.bat
    Script exit code: 0
    Script output:
    C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF>C:\WINDOWS\system32\certutil -addstore -f "TrustedPublisher" "USB_eZ_RF.p7b"
    TrustedPublisher "ÊÜÐÅÈεķ¢²¼Õß"
    Ïà¹ØÖ¤Êé:
    ¾«È·Æ¥Åä:
    ÔªËØ 10:
    ÐòÁкÅ: 5200e5aa2556fc1a86ed96c9d44b33c7
    °ä·¢Õß: CN=VeriSign Class 3 Public Primary Certification Authority - G5, OU=(c) 2006 VeriSign, Inc. - For authorized use only, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US
    NotBefore: 2010/2/8 8:00
    NotAfter: 2020/2/8 7:59
    ʹÓÃÕß: CN=VeriSign Class 3 Code Signing 2010 CA, OU=Terms of use at https://www.verisign.com/rpa (c)10, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US
    ·Ç¸ùÖ¤Êé
    Ö¤Êé¹þÏ£(sha1): 495847a93187cfb8c71f840cb7b41497ad95c64f
    Ö¤Êé "VeriSign Class 3 Code Signing 2010 CA" ÒѾ­ÔÚ´æ´¢ÖС£
    Ç©ÃûÓ빫ԿƥÅä
    Ïà¹ØÖ¤Êé:
    ¾«È·Æ¥Åä:
    ÔªËØ 9:
    ÐòÁкÅ: 18dad19e267de8bb4a2158cdcc6b3b4a
    NotBefore: 2006/11/8 8:00
    NotAfter: 2036/7/17 7:59
    ʹÓÃÕß: CN=VeriSign Class 3 Public Primary Certification Authority - G5, OU=(c) 2006 VeriSign, Inc. - For authorized use only, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US
    Ç©ÃûÓ빫ԿƥÅä
    ¸ùÖ¤Êé: ʹÓÃÕßÓë°ä·¢Õ߯¥Åä
    Ö¤Êé¹þÏ£(sha1): 4eb6d578499b1ccf5f581ead56be3d9b6744a5e5
    Ö¤Êé "VeriSign Class 3 Public Primary Certification Authority - G5" ÒѾ­ÔÚ´æ´¢ÖС£
    Ïà¹ØÖ¤Êé:
    ¾«È·Æ¥Åä:
    ÔªËØ 0:
    ÐòÁкÅ: 39ad63d2f5c9efdc46d734ae5e381b8f
    °ä·¢Õß: CN=VeriSign Class 3 Code Signing 2010 CA, OU=Terms of use at https://www.verisign.com/rpa (c)10, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US
    NotBefore: 2014/2/26 8:00
    NotAfter: 2017/2/26 7:59
    ʹÓÃÕß: CN=Texas Instruments Incorporated, OU=Digital ID Class 3 - Microsoft Software Validation v2, O=Texas Instruments Incorporated, L=Dallas, S=Texas, C=US
    ·Ç¸ùÖ¤Êé
    Ö¤Êé¹þÏ£(sha1): ee0c8ba018ce926432c3cc23523a34073d01954a
    Ö¤Êé "Texas Instruments Incorporated" ÒѾ­ÔÚ´æ´¢ÖС£
    CertUtil: -addstore ÃüÁî³É¹¦Íê³É¡£
    Script stderr:
    Executing C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\DPInst\DPinst64.exe /q /se /sa /lm /path "C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\USB_eZ-RF"
    Script exit code: unknown signal
    Script output:
    Script stderr:
    child killed: unknown signal
    Error running C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\DPInst\DPinst64.exe /q /se /sa /lm /path "C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\USB_eZ-RF": child killed: unknown signal
    [14:22:06] dpinst return code = unknown signal
    Exiting with code -1
    Log started 03/12/2022 at 16:12:16
    [16:12:16] Error reading AppFolder property from C:/ti/ccs1110/ccs/eclipse/ccs.properties
    [16:12:16] Using default AppFolder property Texas Instruments/Code Composer Studio
    [16:12:16] eclipsedir = C:/ti/ccs1110/ccs/eclipse
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Script exit code: 0
    Script output:
    Ïà¹ØÖ¤Êé:
    ¾«È·Æ¥Åä:
    ÔªËØ 10:
    ·Ç¸ùÖ¤Êé
    Ç©ÃûÓ빫ԿƥÅä
    Ïà¹ØÖ¤Êé:
    ¾«È·Æ¥Åä:
    ÔªËØ 9:
    Ç©ÃûÓ빫ԿƥÅä
    Ïà¹ØÖ¤Êé:
    ¾«È·Æ¥Åä:
    ÔªËØ 0:
    ·Ç¸ùÖ¤Êé
    Script stderr:
    Script output:
    Script stderr:
    [16:12:19] dpinst return code = unknown signal
  • Can you start a private conversation with me?
    ki
