Other Parts Discussed in Thread: CCSTUDIO
I installed ccstudio v11.10 on my Ubuntu 20.04.4 LTS linux pc. It is installed in user mode. I didn't use 'sudo' to install it.
If I delete everything in workspace directory. ccstudio can start once. But some functions not working properly. For example, Help->Get Started does not load anything. If I close the program, then ccstudio will hang at next start-up. The ./metadata/.log file shows the following information, with errors I googled but did not find a solution. What can I do?
!SESSION 2022-03-19 02:07:49.802 -----------------------------------------------
eclipse.buildId=4.19.0.I20210303-1800
java.version=11.0.13
java.vendor=Eclipse Adoptium
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product com.ti.ccstudio.branding.product
!ENTRY com.ti.common.core 1 0 2022-03-19 02:07:54.864
!MESSAGE path=ccs_base/DebugServer
!ENTRY com.ti.common.core 1 0 2022-03-19 02:07:54.865
!MESSAGE debugServerDir=/home/ma/ti/ccs1110/ccs/ccs_base/DebugServer
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-03-19 02:07:56.654
!MESSAGE constructor
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-03-19 02:07:56.655
!MESSAGE done with directories
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-03-19 02:07:56.656
!MESSAGE loading ti_logger
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-03-19 02:07:56.657
!MESSAGE Platform os: linux
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-03-19 02:07:56.658
!MESSAGE loading cTools
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-03-19 02:07:56.661
!MESSAGE loading TraceFactory
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-03-19 02:07:56.662
!MESSAGE loading sqlite3
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-03-19 02:07:56.663
!MESSAGE loading CloudTrace
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-03-19 02:07:56.667
!MESSAGE CloudTrace interface loaded
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2022-03-19 02:07:57.317
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
java.lang.ExceptionInInitializerError
at com.ti.chromium.browser.ChromiumBrowserContributor.createBrowser(ChromiumBrowserContributor.java:39)
at com.ti.browser.internal.TIBrowser.<init>(TIBrowser.java:98)
at com.ti.browser.internal.TIBrowser.<init>(TIBrowser.java:88)
at com.ti.browser.internal.TIBrowser.<init>(TIBrowser.java:84)
at com.ti.browser.TIBrowserFactory.createBrowser(TIBrowserFactory.java:45)
at com.ti.ccstudio.branding.internal.CCSIntroPart.createPartControl(CCSIntroPart.java:177)
at org.eclipse.ui.internal.ViewIntroAdapterPart.createPartControl(ViewIntroAdapterPart.java:135)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:158)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:155)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:365)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:999)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:964)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:140)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:405)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:332)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:202)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:91)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:42)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:999)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:659)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:544)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:528)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:73)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:765)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:730)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:714)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeTopicToBeRendered(PartRenderingEngine.java:161)
at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:92)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:133)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setToBeRendered(UIElementImpl.java:314)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:655)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:624)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:786)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:757)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:679)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:674)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1251)
at org.eclipse.ui.internal.WorkbenchPage.showPart(WorkbenchPage.java:1252)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1240)
at org.eclipse.ui.internal.WorkbenchPage.lambda$11(WorkbenchPage.java:4249)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:74)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:4247)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:4229)
at org.eclipse.ui.internal.WorkbenchIntroManager.createIntro(WorkbenchIntroManager.java:176)
at org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(WorkbenchIntroManager.java:124)
at org.eclipse.ui.application.WorkbenchWindowAdvisor.openIntro(WorkbenchWindowAdvisor.java:188)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.openIntro(IDEWorkbenchWindowAdvisor.java:573)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:933)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:96)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:83)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1469)
at org.eclipse.ui.internal.StandardTrim.createStatusLine(StandardTrim.java:118)
at org.eclipse.ui.internal.StandardTrim.createWidget(StandardTrim.java:48)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:346)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:227)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:94)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:37)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer.createWidget(ToolControlRenderer.java:129)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:71)
at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(TrimBarRenderer.java:109)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:673)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:688)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1083)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1461)
Caused by: com.teamdev.jxbrowser.engine.ChromiumProcessStartupFailureException: Process exit code: 17
at com.teamdev.jxbrowser.engine.internal.EngineImpl.throwExceptionAndCleanup(EngineImpl.java:478)
at com.teamdev.jxbrowser.engine.internal.EngineImpl.newInstance(EngineImpl.java:281)
at com.teamdev.jxbrowser.engine.Engine.newInstance(Engine.java:106)
at com.ti.chromium.browser.JxBrowser.<clinit>(JxBrowser.java:236)
... 139 more
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2022-03-19 02:07:57.321
!STACK 0
... 139 more
!ENTRY org.eclipse.equinox.event 4 0 2022-03-19 02:07:57.324
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/SET] {ChangedElement=org.eclipse.ui.internal.introview=org.eclipse.e4.ui.model.application.ui.advanced.impl.PlaceholderImpl@551725e4 (tags: [View, categoryTag:General], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer@1ce45e18, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (closeable: true), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.internal.introview=org.eclipse.e4.ui.model.application.ui.advanced.impl.PlaceholderImpl@551725e4 (tags: [View, categoryTag:General], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer@1ce45e18, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (closeable: true), AttName=toBeRendered, EventType=SET, OldValue=false, Widget=null, NewValue=true}, AttName=toBeRendered, EventType=SET, OldValue=false, Widget=null, NewValue=true} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@8eda949
!STACK 0
... 139 more
!ENTRY com.ti.ccstudio.project.ui.webcontent 1 0 2022-03-19 02:07:57.769
!MESSAGE CCS HTTP adapter started! [ccs.port:45639] - Open 'localhost:45639/ide' in web browser to see listing of available APIs...
!ENTRY com.ti.ccstudio.ui 1 0 2022-03-19 02:08:00.265
!MESSAGE CCS IDE session started!
CCS build: 11.1.0.00011
CCS location: /home/ma/ti/ccs1110/ccs
Workspace location: /data/ccs_workspace_v11
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2022-03-19 02:09:58.556
!MESSAGE No repository found at file:/home/ma/ti/ccs1110/ccs/eclipse/configuration/org.eclipse.osgi/365/data/listener_1925729951/.
