IPC Register Fields Appear Twice in CPU1 Registers View
In an F2837xD controlCARD project the IPC register fields appear twice when CPU1 is selected:
It does not appear twice in the CPU2 context.
Is this intentional and if so, what is the difference between them please?
Thank you.
    I see those bitfield entries are duplicated in the F28x7x_ipc_regs_cpu module xml files. I will bring this thread to the attention of the device experts for followup.
    ki
    Thank you so much for reporting the issue. As Ki mentioned we have identified the reason it is showing twice for CPU1. It will be fixed in future release. Meanwhile you can copy the attached file at:
    C:/ti/ccs1110/ccs/ccs_base/common/targetdb/Modules/C2000/F28x7x_ipc_regs_cpu1.xml
    <module id="IPC_REGS_CPU1" HW_revision="" description="IPC CPU1 Registers">
      <register id="IPCACK" width="32" page="1" offset="0x0" internal="0" description="IPC incoming flag clear (acknowledge) register">
        <bitfield id="IPC0" description="Local IPC Flag 0 AcknowledgementLocal IPC Flag 0 Acknowledgement" begin="0" end="0" width="1" rwaccess="R/W"/>
        <bitfield id="IPC1" description="Local IPC Flag 1 AcknowledgementLocal IPC Flag 1 Acknowledgement" begin="1" end="1" width="1" rwaccess="R/W"/>
        <bitfield id="IPC2" description="Local IPC Flag 2 AcknowledgementLocal IPC Flag 2 Acknowledgement" begin="2" end="2" width="1" rwaccess="R/W"/>
        <bitfield id="IPC3" description="Local IPC Flag 3 AcknowledgementLocal IPC Flag 3 Acknowledgement" begin="3" end="3" width="1" rwaccess="R/W"/>
        <bitfield id="IPC4" description="Local IPC Flag 4 AcknowledgementLocal IPC Flag 4 Acknowledgement" begin="4" end="4" width="1" rwaccess="R/W"/>
        <bitfield id="IPC5" description="Local IPC Flag 5 AcknowledgementLocal IPC Flag 5 Acknowledgement" begin="5" end="5" width="1" rwaccess="R/W"/>
        <bitfield id="IPC6" description="Local IPC Flag 6 AcknowledgementLocal IPC Flag 6 Acknowledgement" begin="6" end="6" width="1" rwaccess="R/W"/>
        <bitfield id="IPC7" description="Local IPC Flag 7 AcknowledgementLocal IPC Flag 7 Acknowledgement" begin="7" end="7" width="1" rwaccess="R/W"/>
        <bitfield id="IPC8" description="Local IPC Flag 8 AcknowledgementLocal IPC Flag 8 Acknowledgement" begin="8" end="8" width="1" rwaccess="R/W"/>
        <bitfield id="IPC9" description="Local IPC Flag 9 AcknowledgementLocal IPC Flag 9 Acknowledgement" begin="9" end="9" width="1" rwaccess="R/W"/>
        <bitfield id="IPC10" description="Local IPC Flag 10 AcknowledgementLocal IPC Flag 10 Acknowledgement" begin="10" end="10" width="1" rwaccess="R/W"/>
        <bitfield id="IPC11" description="Local IPC Flag 11 AcknowledgementLocal IPC Flag 11 Acknowledgement" begin="11" end="11" width="1" rwaccess="R/W"/>
        <bitfield id="IPC12" description="Local IPC Flag 12 AcknowledgementLocal IPC Flag 12 Acknowledgement" begin="12" end="12" width="1" rwaccess="R/W"/>
        <bitfield id="IPC13" description="Local IPC Flag 13 AcknowledgementLocal IPC Flag 13 Acknowledgement" begin="13" end="13" width="1" rwaccess="R/W"/>
        <bitfield id="IPC14" description="Local IPC Flag 14 AcknowledgementLocal IPC Flag 14 Acknowledgement" begin="14" end="14" width="1" rwaccess="R/W"/>
        <bitfield id="IPC15" description="Local IPC Flag 15 AcknowledgementLocal IPC Flag 15 Acknowledgement" begin="15" end="15" width="1" rwaccess="R/W"/>
        <bitfield id="IPC16" description="Local IPC Flag 16 AcknowledgementLocal IPC Flag 16 Acknowledgement" begin="16" end="16" width="1" rwaccess="R/W"/>
        <bitfield id="IPC17" description="Local IPC Flag 17 AcknowledgementLocal IPC Flag 17 Acknowledgement" begin="17" end="17" width="1" rwaccess="R/W"/>
        <bitfield id="IPC18" description="Local IPC Flag 18 AcknowledgementLocal IPC Flag 18 Acknowledgement" begin="18" end="18" width="1" rwaccess="R/W"/>
        <bitfield id="IPC19" description="Local IPC Flag 19 AcknowledgementLocal IPC Flag 19 Acknowledgement" begin="19" end="19" width="1" rwaccess="R/W"/>
        <bitfield id="IPC20" description="Local IPC Flag 20 AcknowledgementLocal IPC Flag 20 Acknowledgement" begin="20" end="20" width="1" rwaccess="R/W"/>
        <bitfield id="IPC21" description="Local IPC Flag 21 AcknowledgementLocal IPC Flag 21 Acknowledgement" begin="21" end="21" width="1" rwaccess="R/W"/>
        <bitfield id="IPC22" description="Local IPC Flag 22 AcknowledgementLocal IPC Flag 22 Acknowledgement" begin="22" end="22" width="1" rwaccess="R/W"/>
        <bitfield id="IPC23" description="Local IPC Flag 23 AcknowledgementLocal IPC Flag 23 Acknowledgement" begin="23" end="23" width="1" rwaccess="R/W"/>
        <bitfield id="IPC24" description="Local IPC Flag 24 AcknowledgementLocal IPC Flag 24 Acknowledgement" begin="24" end="24" width="1" rwaccess="R/W"/>
        <bitfield id="IPC25" description="Local IPC Flag 25 AcknowledgementLocal IPC Flag 25 Acknowledgement" begin="25" end="25" width="1" rwaccess="R/W"/>
        <bitfield id="IPC26" description="Local IPC Flag 26 AcknowledgementLocal IPC Flag 26 Acknowledgement" begin="26" end="26" width="1" rwaccess="R/W"/>
        <bitfield id="IPC27" description="Local IPC Flag 27 AcknowledgementLocal IPC Flag 27 Acknowledgement" begin="27" end="27" width="1" rwaccess="R/W"/>
        <bitfield id="IPC28" description="Local IPC Flag 28 AcknowledgementLocal IPC Flag 28 Acknowledgement" begin="28" end="28" width="1" rwaccess="R/W"/>
        <bitfield id="IPC29" description="Local IPC Flag 29 AcknowledgementLocal IPC Flag 29 Acknowledgement" begin="29" end="29" width="1" rwaccess="R/W"/>
        <bitfield id="IPC30" description="Local IPC Flag 30 AcknowledgementLocal IPC Flag 30 Acknowledgement" begin="30" end="30" width="1" rwaccess="R/W"/>
        <bitfield id="IPC31" description="Local IPC Flag 31 AcknowledgementLocal IPC Flag 31 Acknowledgement" begin="31" end="31" width="1" rwaccess="R/W"/>
      </register>
      <register id="IPCSTS" width="32" page="1" offset="0x2" internal="0" description="IPC incoming flag status register">
        <bitfield id="IPC0" description="Local IPC Flag 0 StatusLocal IPC Flag 0 Status" begin="0" end="0" width="1" rwaccess="R/W"/>
        <bitfield id="IPC1" description="Local IPC Flag 1 StatusLocal IPC Flag 1 Status" begin="1" end="1" width="1" rwaccess="R/W"/>
        <bitfield id="IPC2" description="Local IPC Flag 2 StatusLocal IPC Flag 2 Status" begin="2" end="2" width="1" rwaccess="R/W"/>
        <bitfield id="IPC3" description="Local IPC Flag 3 StatusLocal IPC Flag 3 Status" begin="3" end="3" width="1" rwaccess="R/W"/>
        <bitfield id="IPC4" description="Local IPC Flag 4 StatusLocal IPC Flag 4 Status" begin="4" end="4" width="1" rwaccess="R/W"/>
        <bitfield id="IPC5" description="Local IPC Flag 5 StatusLocal IPC Flag 5 Status" begin="5" end="5" width="1" rwaccess="R/W"/>
        <bitfield id="IPC6" description="Local IPC Flag 6 StatusLocal IPC Flag 6 Status" begin="6" end="6" width="1" rwaccess="R/W"/>
        <bitfield id="IPC7" description="Local IPC Flag 7 StatusLocal IPC Flag 7 Status" begin="7" end="7" width="1" rwaccess="R/W"/>
        <bitfield id="IPC8" description="Local IPC Flag 8 StatusLocal IPC Flag 8 Status" begin="8" end="8" width="1" rwaccess="R/W"/>
        <bitfield id="IPC9" description="Local IPC Flag 9 StatusLocal IPC Flag 9 Status" begin="9" end="9" width="1" rwaccess="R/W"/>
        <bitfield id="IPC10" description="Local IPC Flag 10 StatusLocal IPC Flag 10 Status" begin="10" end="10" width="1" rwaccess="R/W"/>
        <bitfield id="IPC11" description="Local IPC Flag 11 StatusLocal IPC Flag 11 Status" begin="11" end="11" width="1" rwaccess="R/W"/>
        <bitfield id="IPC12" description="Local IPC Flag 12 StatusLocal IPC Flag 12 Status" begin="12" end="12" width="1" rwaccess="R/W"/>
        <bitfield id="IPC13" description="Local IPC Flag 13 StatusLocal IPC Flag 13 Status" begin="13" end="13" width="1" rwaccess="R/W"/>
        <bitfield id="IPC14" description="Local IPC Flag 14 StatusLocal IPC Flag 14 Status" begin="14" end="14" width="1" rwaccess="R/W"/>
        <bitfield id="IPC15" description="Local IPC Flag 15 StatusLocal IPC Flag 15 Status" begin="15" end="15" width="1" rwaccess="R/W"/>
        <bitfield id="IPC16" description="Local IPC Flag 16 StatusLocal IPC Flag 16 Status" begin="16" end="16" width="1" rwaccess="R/W"/>
        <bitfield id="IPC17" description="Local IPC Flag 17 StatusLocal IPC Flag 17 Status" begin="17" end="17" width="1" rwaccess="R/W"/>
        <bitfield id="IPC18" description="Local IPC Flag 18 StatusLocal IPC Flag 18 Status" begin="18" end="18" width="1" rwaccess="R/W"/>
        <bitfield id="IPC19" description="Local IPC Flag 19 StatusLocal IPC Flag 19 Status" begin="19" end="19" width="1" rwaccess="R/W"/>
        <bitfield id="IPC20" description="Local IPC Flag 20 StatusLocal IPC Flag 20 Status" begin="20" end="20" width="1" rwaccess="R/W"/>
        <bitfield id="IPC21" description="Local IPC Flag 21 StatusLocal IPC Flag 21 Status" begin="21" end="21" width="1" rwaccess="R/W"/>
        <bitfield id="IPC22" description="Local IPC Flag 22 StatusLocal IPC Flag 22 Status" begin="22" end="22" width="1" rwaccess="R/W"/>
        <bitfield id="IPC23" description="Local IPC Flag 23 StatusLocal IPC Flag 23 Status" begin="23" end="23" width="1" rwaccess="R/W"/>
        <bitfield id="IPC24" description="Local IPC Flag 24 StatusLocal IPC Flag 24 Status" begin="24" end="24" width="1" rwaccess="R/W"/>
        <bitfield id="IPC25" description="Local IPC Flag 25 StatusLocal IPC Flag 25 Status" begin="25" end="25" width="1" rwaccess="R/W"/>
        <bitfield id="IPC26" description="Local IPC Flag 26 StatusLocal IPC Flag 26 Status" begin="26" end="26" width="1" rwaccess="R/W"/>
        <bitfield id="IPC27" description="Local IPC Flag 27 StatusLocal IPC Flag 27 Status" begin="27" end="27" width="1" rwaccess="R/W"/>
        <bitfield id="IPC28" description="Local IPC Flag 28 StatusLocal IPC Flag 28 Status" begin="28" end="28" width="1" rwaccess="R/W"/>
        <bitfield id="IPC29" description="Local IPC Flag 29 StatusLocal IPC Flag 29 Status" begin="29" end="29" width="1" rwaccess="R/W"/>
        <bitfield id="IPC30" description="Local IPC Flag 30 StatusLocal IPC Flag 30 Status" begin="30" end="30" width="1" rwaccess="R/W"/>
        <bitfield id="IPC31" description="Local IPC Flag 31 StatusLocal IPC Flag 31 Status" begin="31" end="31" width="1" rwaccess="R/W"/>
      </register>
      <register id="IPCSET" width="32" page="1" offset="0x4" internal="0" description="IPC remote flag set register">
        <bitfield id="IPC0" description="Set Remote IPC0 FlagSet Remote IPC0 Flag" begin="0" end="0" width="1" rwaccess="R/W"/>
        <bitfield id="IPC1" description="Set Remote IPC1 FlagSet Remote IPC1 Flag" begin="1" end="1" width="1" rwaccess="R/W"/>
        <bitfield id="IPC2" description="Set Remote IPC2 FlagSet Remote IPC2 Flag" begin="2" end="2" width="1" rwaccess="R/W"/>
        <bitfield id="IPC3" description="Set Remote IPC3 FlagSet Remote IPC3 Flag" begin="3" end="3" width="1" rwaccess="R/W"/>
        <bitfield id="IPC4" description="Set Remote IPC4 FlagSet Remote IPC4 Flag" begin="4" end="4" width="1" rwaccess="R/W"/>
        <bitfield id="IPC5" description="Set Remote IPC5 FlagSet Remote IPC5 Flag" begin="5" end="5" width="1" rwaccess="R/W"/>
        <bitfield id="IPC6" description="Set Remote IPC6 FlagSet Remote IPC6 Flag" begin="6" end="6" width="1" rwaccess="R/W"/>
        <bitfield id="IPC7" description="Set Remote IPC7 FlagSet Remote IPC7 Flag" begin="7" end="7" width="1" rwaccess="R/W"/>
        <bitfield id="IPC8" description="Set Remote IPC8 FlagSet Remote IPC8 Flag" begin="8" end="8" width="1" rwaccess="R/W"/>
        <bitfield id="IPC9" description="Set Remote IPC9 FlagSet Remote IPC9 Flag" begin="9" end="9" width="1" rwaccess="R/W"/>
        <bitfield id="IPC10" description="Set Remote IPC10 FlagSet Remote IPC10 Flag" begin="10" end="10" width="1" rwaccess="R/W"/>
        <bitfield id="IPC11" description="Set Remote IPC11 FlagSet Remote IPC11 Flag" begin="11" end="11" width="1" rwaccess="R/W"/>
        <bitfield id="IPC12" description="Set Remote IPC12 FlagSet Remote IPC12 Flag" begin="12" end="12" width="1" rwaccess="R/W"/>
        <bitfield id="IPC13" description="Set Remote IPC13 FlagSet Remote IPC13 Flag" begin="13" end="13" width="1" rwaccess="R/W"/>
        <bitfield id="IPC14" description="Set Remote IPC14 FlagSet Remote IPC14 Flag" begin="14" end="14" width="1" rwaccess="R/W"/>
        <bitfield id="IPC15" description="Set Remote IPC15 FlagSet Remote IPC15 Flag" begin="15" end="15" width="1" rwaccess="R/W"/>
        <bitfield id="IPC16" description="Set Remote IPC16 FlagSet Remote IPC16 Flag" begin="16" end="16" width="1" rwaccess="R/W"/>
        <bitfield id="IPC17" description="Set Remote IPC17 FlagSet Remote IPC17 Flag" begin="17" end="17" width="1" rwaccess="R/W"/>
        <bitfield id="IPC18" description="Set Remote IPC18 FlagSet Remote IPC18 Flag" begin="18" end="18" width="1" rwaccess="R/W"/>
        <bitfield id="IPC19" description="Set Remote IPC19 FlagSet Remote IPC19 Flag" begin="19" end="19" width="1" rwaccess="R/W"/>
        <bitfield id="IPC20" description="Set Remote IPC20 FlagSet Remote IPC20 Flag" begin="20" end="20" width="1" rwaccess="R/W"/>
        <bitfield id="IPC21" description="Set Remote IPC21 FlagSet Remote IPC21 Flag" begin="21" end="21" width="1" rwaccess="R/W"/>
        <bitfield id="IPC22" description="Set Remote IPC22 FlagSet Remote IPC22 Flag" begin="22" end="22" width="1" rwaccess="R/W"/>
        <bitfield id="IPC23" description="Set Remote IPC23 FlagSet Remote IPC23 Flag" begin="23" end="23" width="1" rwaccess="R/W"/>
        <bitfield id="IPC24" description="Set Remote IPC24 FlagSet Remote IPC24 Flag" begin="24" end="24" width="1" rwaccess="R/W"/>
        <bitfield id="IPC25" description="Set Remote IPC25 FlagSet Remote IPC25 Flag" begin="25" end="25" width="1" rwaccess="R/W"/>
        <bitfield id="IPC26" description="Set Remote IPC26 FlagSet Remote IPC26 Flag" begin="26" end="26" width="1" rwaccess="R/W"/>
        <bitfield id="IPC27" description="Set Remote IPC27 FlagSet Remote IPC27 Flag" begin="27" end="27" width="1" rwaccess="R/W"/>
        <bitfield id="IPC28" description="Set Remote IPC28 FlagSet Remote IPC28 Flag" begin="28" end="28" width="1" rwaccess="R/W"/>
        <bitfield id="IPC29" description="Set Remote IPC29 FlagSet Remote IPC29 Flag" begin="29" end="29" width="1" rwaccess="R/W"/>
        <bitfield id="IPC30" description="Set Remote IPC30 FlagSet Remote IPC30 Flag" begin="30" end="30" width="1" rwaccess="R/W"/>
        <bitfield id="IPC31" description="Set Remote IPC31 FlagSet Remote IPC31 Flag" begin="31" end="31" width="1" rwaccess="R/W"/>
      </register>
      <register id="IPCCLR" width="32" page="1" offset="0x6" internal="0" description="IPC remote flag clear register">
        <bitfield id="IPC0" description="Clear Remote IPC0 FlagClear Remote IPC0 Flag" begin="0" end="0" width="1" rwaccess="R/W"/>
        <bitfield id="IPC1" description="Clear Remote IPC1 FlagClear Remote IPC1 Flag" begin="1" end="1" width="1" rwaccess="R/W"/>
        <bitfield id="IPC2" description="Clear Remote IPC2 FlagClear Remote IPC2 Flag" begin="2" end="2" width="1" rwaccess="R/W"/>
        <bitfield id="IPC3" description="Clear Remote IPC3 FlagClear Remote IPC3 Flag" begin="3" end="3" width="1" rwaccess="R/W"/>
        <bitfield id="IPC4" description="Clear Remote IPC4 FlagClear Remote IPC4 Flag" begin="4" end="4" width="1" rwaccess="R/W"/>
        <bitfield id="IPC5" description="Clear Remote IPC5 FlagClear Remote IPC5 Flag" begin="5" end="5" width="1" rwaccess="R/W"/>
        <bitfield id="IPC6" description="Clear Remote IPC6 FlagClear Remote IPC6 Flag" begin="6" end="6" width="1" rwaccess="R/W"/>
        <bitfield id="IPC7" description="Clear Remote IPC7 FlagClear Remote IPC7 Flag" begin="7" end="7" width="1" rwaccess="R/W"/>
        <bitfield id="IPC8" description="Clear Remote IPC8 FlagClear Remote IPC8 Flag" begin="8" end="8" width="1" rwaccess="R/W"/>
        <bitfield id="IPC9" description="Clear Remote IPC9 FlagClear Remote IPC9 Flag" begin="9" end="9" width="1" rwaccess="R/W"/>
        <bitfield id="IPC10" description="Clear Remote IPC10 FlagClear Remote IPC10 Flag" begin="10" end="10" width="1" rwaccess="R/W"/>
        <bitfield id="IPC11" description="Clear Remote IPC11 FlagClear Remote IPC11 Flag" begin="11" end="11" width="1" rwaccess="R/W"/>
        <bitfield id="IPC12" description="Clear Remote IPC12 FlagClear Remote IPC12 Flag" begin="12" end="12" width="1" rwaccess="R/W"/>
        <bitfield id="IPC13" description="Clear Remote IPC13 FlagClear Remote IPC13 Flag" begin="13" end="13" width="1" rwaccess="R/W"/>
        <bitfield id="IPC14" description="Clear Remote IPC14 FlagClear Remote IPC14 Flag" begin="14" end="14" width="1" rwaccess="R/W"/>
        <bitfield id="IPC15" description="Clear Remote IPC15 FlagClear Remote IPC15 Flag" begin="15" end="15" width="1" rwaccess="R/W"/>
        <bitfield id="IPC16" description="Clear Remote IPC16 FlagClear Remote IPC16 Flag" begin="16" end="16" width="1" rwaccess="R/W"/>
        <bitfield id="IPC17" description="Clear Remote IPC17 FlagClear Remote IPC17 Flag" begin="17" end="17" width="1" rwaccess="R/W"/>
        <bitfield id="IPC18" description="Clear Remote IPC18 FlagClear Remote IPC18 Flag" begin="18" end="18" width="1" rwaccess="R/W"/>
        <bitfield id="IPC19" description="Clear Remote IPC19 FlagClear Remote IPC19 Flag" begin="19" end="19" width="1" rwaccess="R/W"/>
        <bitfield id="IPC20" description="Clear Remote IPC20 FlagClear Remote IPC20 Flag" begin="20" end="20" width="1" rwaccess="R/W"/>
        <bitfield id="IPC21" description="Clear Remote IPC21 FlagClear Remote IPC21 Flag" begin="21" end="21" width="1" rwaccess="R/W"/>
        <bitfield id="IPC22" description="Clear Remote IPC22 FlagClear Remote IPC22 Flag" begin="22" end="22" width="1" rwaccess="R/W"/>
        <bitfield id="IPC23" description="Clear Remote IPC23 FlagClear Remote IPC23 Flag" begin="23" end="23" width="1" rwaccess="R/W"/>
        <bitfield id="IPC24" description="Clear Remote IPC24 FlagClear Remote IPC24 Flag" begin="24" end="24" width="1" rwaccess="R/W"/>
        <bitfield id="IPC25" description="Clear Remote IPC25 FlagClear Remote IPC25 Flag" begin="25" end="25" width="1" rwaccess="R/W"/>
        <bitfield id="IPC26" description="Clear Remote IPC26 FlagClear Remote IPC26 Flag" begin="26" end="26" width="1" rwaccess="R/W"/>
        <bitfield id="IPC27" description="Clear Remote IPC27 FlagClear Remote IPC27 Flag" begin="27" end="27" width="1" rwaccess="R/W"/>
        <bitfield id="IPC28" description="Clear Remote IPC28 FlagClear Remote IPC28 Flag" begin="28" end="28" width="1" rwaccess="R/W"/>
        <bitfield id="IPC29" description="Clear Remote IPC29 FlagClear Remote IPC29 Flag" begin="29" end="29" width="1" rwaccess="R/W"/>
        <bitfield id="IPC30" description="Clear Remote IPC30 FlagClear Remote IPC30 Flag" begin="30" end="30" width="1" rwaccess="R/W"/>
        <bitfield id="IPC31" description="Clear Remote IPC31 FlagClear Remote IPC31 Flag" begin="31" end="31" width="1" rwaccess="R/W"/>
      </register>
      <register id="IPCFLG" width="32" page="1" offset="0x8" internal="0" description="IPC remote flag status register">
        <bitfield id="IPC0" description="Remote IPC0 Flag StatusRemote IPC0 Flag Status" begin="0" end="0" width="1" rwaccess="R/W"/>
        <bitfield id="IPC1" description="Remote IPC1 Flag StatusRemote IPC1 Flag Status" begin="1" end="1" width="1" rwaccess="R/W"/>
        <bitfield id="IPC2" description="Remote IPC2 Flag StatusRemote IPC2 Flag Status" begin="2" end="2" width="1" rwaccess="R/W"/>
        <bitfield id="IPC3" description="Remote IPC3 Flag StatusRemote IPC3 Flag Status" begin="3" end="3" width="1" rwaccess="R/W"/>
        <bitfield id="IPC4" description="Remote IPC4 Flag StatusRemote IPC4 Flag Status" begin="4" end="4" width="1" rwaccess="R/W"/>
        <bitfield id="IPC5" description="Remote IPC5 Flag StatusRemote IPC5 Flag Status" begin="5" end="5" width="1" rwaccess="R/W"/>
        <bitfield id="IPC6" description="Remote IPC6 Flag StatusRemote IPC6 Flag Status" begin="6" end="6" width="1" rwaccess="R/W"/>
        <bitfield id="IPC7" description="Remote IPC7 Flag StatusRemote IPC7 Flag Status" begin="7" end="7" width="1" rwaccess="R/W"/>
        <bitfield id="IPC8" description="Remote IPC8 Flag StatusRemote IPC8 Flag Status" begin="8" end="8" width="1" rwaccess="R/W"/>
        <bitfield id="IPC9" description="Remote IPC9 Flag StatusRemote IPC9 Flag Status" begin="9" end="9" width="1" rwaccess="R/W"/>
        <bitfield id="IPC10" description="Remote IPC10 Flag StatusRemote IPC10 Flag Status" begin="10" end="10" width="1" rwaccess="R/W"/>
        <bitfield id="IPC11" description="Remote IPC11 Flag StatusRemote IPC11 Flag Status" begin="11" end="11" width="1" rwaccess="R/W"/>
        <bitfield id="IPC12" description="Remote IPC12 Flag StatusRemote IPC12 Flag Status" begin="12" end="12" width="1" rwaccess="R/W"/>
        <bitfield id="IPC13" description="Remote IPC13 Flag StatusRemote IPC13 Flag Status" begin="13" end="13" width="1" rwaccess="R/W"/>
        <bitfield id="IPC14" description="Remote IPC14 Flag StatusRemote IPC14 Flag Status" begin="14" end="14" width="1" rwaccess="R/W"/>
        <bitfield id="IPC15" description="Remote IPC15 Flag StatusRemote IPC15 Flag Status" begin="15" end="15" width="1" rwaccess="R/W"/>
        <bitfield id="IPC16" description="Remote IPC16 Flag StatusRemote IPC16 Flag Status" begin="16" end="16" width="1" rwaccess="R/W"/>
        <bitfield id="IPC17" description="Remote IPC17 Flag StatusRemote IPC17 Flag Status" begin="17" end="17" width="1" rwaccess="R/W"/>
        <bitfield id="IPC18" description="Remote IPC18 Flag StatusRemote IPC18 Flag Status" begin="18" end="18" width="1" rwaccess="R/W"/>
        <bitfield id="IPC19" description="Remote IPC19 Flag StatusRemote IPC19 Flag Status" begin="19" end="19" width="1" rwaccess="R/W"/>
        <bitfield id="IPC20" description="Remote IPC20 Flag StatusRemote IPC20 Flag Status" begin="20" end="20" width="1" rwaccess="R/W"/>
        <bitfield id="IPC21" description="Remote IPC21 Flag StatusRemote IPC21 Flag Status" begin="21" end="21" width="1" rwaccess="R/W"/>
        <bitfield id="IPC22" description="Remote IPC22 Flag StatusRemote IPC22 Flag Status" begin="22" end="22" width="1" rwaccess="R/W"/>
        <bitfield id="IPC23" description="Remote IPC23 Flag StatusRemote IPC23 Flag Status" begin="23" end="23" width="1" rwaccess="R/W"/>
        <bitfield id="IPC24" description="Remote IPC24 Flag StatusRemote IPC24 Flag Status" begin="24" end="24" width="1" rwaccess="R/W"/>
        <bitfield id="IPC25" description="Remote IPC25 Flag StatusRemote IPC25 Flag Status" begin="25" end="25" width="1" rwaccess="R/W"/>
        <bitfield id="IPC26" description="Remote IPC26 Flag StatusRemote IPC26 Flag Status" begin="26" end="26" width="1" rwaccess="R/W"/>
        <bitfield id="IPC27" description="Remote IPC27 Flag StatusRemote IPC27 Flag Status" begin="27" end="27" width="1" rwaccess="R/W"/>
        <bitfield id="IPC28" description="Remote IPC28 Flag StatusRemote IPC28 Flag Status" begin="28" end="28" width="1" rwaccess="R/W"/>
        <bitfield id="IPC29" description="Remote IPC29 Flag StatusRemote IPC29 Flag Status" begin="29" end="29" width="1" rwaccess="R/W"/>
        <bitfield id="IPC30" description="Remote IPC30 Flag StatusRemote IPC30 Flag Status" begin="30" end="30" width="1" rwaccess="R/W"/>
        <bitfield id="IPC31" description="Remote IPC31 Flag StatusRemote IPC31 Flag Status" begin="31" end="31" width="1" rwaccess="R/W"/>
      </register>
      <register id="IPCCOUNTERL" width="32" page="1" offset="0xc" internal="0" description="IPC Counter Low Register ">
        <bitfield id="COUNT" description="IPC Counter's lower 32-bitIPC Counter's lower 32-bit" begin="31" end="0" width="32" rwaccess="R/W"/>
      </register>
      <register id="IPCCOUNTERH" width="32" page="1" offset="0xe" internal="0" description="IPC Counter High Register ">
        <bitfield id="COUNT" description="IPC Counter's upper 32-bitIPC Counter's upper 32-bit" begin="31" end="0" width="32" rwaccess="R/W"/>
      </register>
      <register id="IPCSENDCOM" width="32" page="1" offset="0x10" internal="0" description="Local to Remote IPC Command Register">
        <bitfield id="COMMAND" description="Local to Remote IPC CommandLocal to Remote IPC Command" begin="31" end="0" width="32" rwaccess="R/W"/>
      </register>
      <register id="IPCSENDADDR" width="32" page="1" offset="0x12" internal="0" description="Local to Remote IPC Address Register">
        <bitfield id="ADDRESS" description="Local to Remote IPC AddressLocal to Remote IPC Address" begin="31" end="0" width="32" rwaccess="R/W"/>
      </register>
      <register id="IPCSENDDATA" width="32" page="1" offset="0x14" internal="0" description="Local to Remote IPC Data Register">
        <bitfield id="WDATA" description="Local to Remote IPC DataLocal to Remote IPC Data" begin="31" end="0" width="32" rwaccess="R/W"/>
      </register>
      <register id="IPCREMOTEREPLY" width="32" page="1" offset="0x16" internal="0" description="Remote to Local IPC Reply Data Register">
        <bitfield id="RDATA" description="Remote to Local IPC Return DataRemote to Local IPC Return Data" begin="31" end="0" width="32" rwaccess="R/W"/>
      </register>
      <register id="IPCRECVCOM" width="32" page="1" offset="0x18" internal="0" description="Remote to Local IPC Command Register">
        <bitfield id="COMMAND" description="Remote to Local IPC CommandRemote to Local IPC Command" begin="31" end="0" width="32" rwaccess="R/W"/>
      </register>
      <register id="IPCRECVADDR" width="32" page="1" offset="0x1a" internal="0" description="Remote to Local IPC Address Register">
        <bitfield id="ADDRESS" description="Remote to Local IPC AddressRemote to Local IPC Address" begin="31" end="0" width="32" rwaccess="R/W"/>
      </register>
      <register id="IPCRECVDATA" width="32" page="1" offset="0x1c" internal="0" description="Remote to Local IPC Data Register">
        <bitfield id="WDATA" description="Remote to Local IPC DataRemote to Local IPC Data" begin="31" end="0" width="32" rwaccess="R/W"/>
      </register>
      <register id="IPCLOCALREPLY" width="32" page="1" offset="0x1e" internal="0" description="Local to Remote IPC Reply Data Register">
        <bitfield id="RDATA" description="Local to Remote IPC Return DataLocal to Remote IPC Return Data" begin="31" end="0" width="32" rwaccess="R/W"/>
      </register>
      <register id="IPCBOOTSTS" width="32" page="1" offset="0x20" internal="0" description="CPU2 to CPU1 IPC Boot Status Register">
        <bitfield id="BOOTSTS" description="CPU2 to CPU1 IPC Boot StatusCPU2 to CPU1 IPC Boot Status" begin="31" end="0" width="32" rwaccess="R/W"/>
      </register>
      <register id="IPCBOOTMODE" width="32" page="1" offset="0x22" internal="0" description="CPU1 to CPU2 IPC Boot Mode Register">
        <bitfield id="BOOTMODE" description="CPU1 to CPU2 IPC Boot ModeCPU1 to CPU2 IPC Boot Mode" begin="31" end="0" width="32" rwaccess="R/W"/>
      </register>
      <register id="PUMPREQUEST" width="32" page="1" offset="0x24" internal="0" description="Flash programming semaphore PUMP request register">
        <bitfield id="SEM" description="Flash Pump Request Semaphore between CPU1 and CPU2Flash Pump Request Semaphore between CPU1 and CPU2" begin="1" end="0" width="2" rwaccess="R/W"/>
        <bitfield id="KEY" description="Key Qualifier for writes to this registerKey Qualifier for writes to this register" begin="31" end="16" width="16" rwaccess="R/W"/>
      </register>
    </module>
    This should fix the issue.
    With Best Regards,
    Santosh
  • Thanks Ki and Santosh.
