There is a new installer frontend for CCSv5.1 M4 available from the download page. Post your feedback, issues and questions here!
Hi
I am trying to install 5.1.0.04001 on RHEL 6 x86_64. I installed i686 glibc and now the regular installer runs but stops after installing some things and leaving three icons (blackhawk JTAG unit) on the desktop. I also tried the new installer but it produced the exact same error message:
$ ./ccs_setup_5.1.0.04001.bin
ERROR: ld.so: object '/usr/NX/lib/libesddsp.so.0' from LD_PRELOAD cannot be preloaded: ignored.
ERROR: ld.so: object '/usr/NX/lib/libesd.so.0' from LD_PRELOAD cannot be preloaded: ignored.
Where do you want to install Code Composer Studio 5.1.0? [/opt/ti]
Installing Code Composer Studio 5.1.0...
Error in action ExecuteAction
Error in action ExecuteScript
expected boolean value but got "<%JavaFound%>"
while executing
"::InstallJammer::actions::$component $this"
while executing
"$obj execute"
(procedure "::InstallJammer::ExecuteActions" line 62)
invoked from within
"::InstallJammer::ExecuteActions $action -parent $id -conditions $eval"
(procedure "::InstallJammer::actions::ExecuteAction" line 35)
invoked from within
while executing
"$obj execute"
invoked from within
"::InstallJammer::ExecuteActions Console"
(procedure "::InstallJammer::InstallMain" line 11)
invoked from within
(procedure "ThemeMain" line 2)
invoked from within
"ThemeMain "
invoked from within
"if {![info exists ::InstallJammer]} { ThemeMain }"
(file "/installkitvfs/main.tcl" line 38584)
Any ideas?
Thanks in advance.
I didn't encountered problems during installation in Ubuntu 10.04 x86_64 (all system updated last month) [ Tip: don't forget to run installation script as "root" ;) ]
My issue is related to the license manager. After install CCS 5.1.0.04001 I tried to run the "hello world code" as test using the TI simulator. But the debugger is asking me for a license (JTAG license) as you can read below:
" License cannot be acquired.
No valid license for Code Composer Studio could be found. To be able to use any of the JTAG debugging features of Code Composer Studio you will need a license."
As you can see, it is asking me for a JTAG license although I am running the simulator (no JTAG device attached to my computer). Must I acquire a license to run C64xx simulations in CCS v5 running on Linux?
Ronaldo Viera said:I didn't encountered problems during installation in Ubuntu 10.04 x86_64 (all system updated last month) [ Tip: don't forget to run installation script as "root" ;) ]
Solved! I gone to Help > CCS Licensing information > Upgrade > Launch License setup > Activate a new license... (2nd option) > Next > FREE option > Next. And it is done! The debugger is working now!
Hello Andy
I downloaded and launched ccs_setup_5.1.0.05000.exe on my PC (Windows XP SP3), but the installation script crashed.
Here's the log:
divide by zero
while executing
while executing
"$obj execute"
invoked from within
invoked from within
while executing
"$obj execute"
invoked from within
invoked from within
divide by zero
while executing
while executing
"$obj execute"
invoked from within
invoked from within
while executing
"$obj execute"
invoked from within
invoked from within
while executing
"$obj execute"
invoked from within
"::InstallJammer::ExecuteActions $id -when $when"
(procedure "::InstallJammer::RaiseEventHandler" line 79)
invoked from within
"::InstallJammer::RaiseEventHandler .wizard"
(command bound to event)
Andy,
I installed 5.1M5 in my Ubuntu 10.04 64-bit but could not find an install log; the directory /user/.installjammerinfo contained only older logs.
Is there one created?
Thank you,
Rafael
Andy,
Interesting discussion that mentions a dependency of the lightweight installer in 64-bit systems:
http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/p/114607/416425.aspx#416425
Rafael
