My CCS "Debug Active Project" command fails to launch, under circumstances identical to when it previously succeeded.
Details:
Console Report:
C674X_0: File Loader: Data verification failed at address 0xC0074600 Please verify target memory and memory map. Comment: The target memory, memory map, and linker command file are all identical to when the system worked previously. Nothing changed, except now the "Debug Active Project" fails to launch. It does successfully connect to the target board, so I can view the CPU registers, etc. Possible Clues?
Error found during data verification.
Ensure the linker command file matches the memory map.
