I ran the installer on Ubuntu 10.04 with sudo and it failed to fetch data from HTTP urls. The reason is that I'm behind the proxy server.
Please add manual proxy configuration to the installer
Michael,
I don't recall having problems in my Ubuntu 10.04 64-bit (I am also behind a proxy), but since I am in the TI intranet this may have influenced this outcome.
I imagine you already checked the usual suspects: set the proxy in Firefox browser, in the menu System --> Preferences --> Network Proxy and in the command-line environment variable http_proxy=<my_proxy_server>:<port>
Can you please confirm if you have everything correctly set as above?
Rafael.
Hi Rafael,
I have checked all settings mentioned above one again and they look good. I have 'system wide' proxy and I have 'use system proxy' in Firefox. Iahe http_proxy set correctly for both user and root. Here is the error message I got from the installer.
Error in action ExecuteAction
Error in action FetchURL
couldn't open socket: host is unreachable
while executing
"::http::geturl $url -validate 1"
(procedure "::InstallJammer::actions::FetchURL" line 19)
invoked from within
"::InstallJammer::actions::$component $this"
while executing
"$obj execute"
(procedure "::InstallJammer::ExecuteActions" line 62)
invoked from within
"::InstallJammer::ExecuteActions $action -parent $id -conditions $eval"
(procedure "::InstallJammer::actions::ExecuteAction" line 35)
invoked from within
while executing
"$obj execute"
invoked from within
invoked from within
while executing
invoked from within
while executing
"$obj execute"
invoked from within
invoked from within
while executing
"$obj execute"
invoked from within
invoked from within
while executing
"$obj execute"
invoked from within
"::InstallJammer::ExecuteActions $id -when $when"
(procedure "::InstallJammer::RaiseEventHandler" line 79)
invoked from within
"::InstallJammer::RaiseEventHandler .wizard"
(command bound to event)
