I'm just modified the pinterrupt example based on my project requirement. I can produce the executable file but while debugging, I'm facing an issue internally Xdc_Runtime_error.
* ======== ti_sysbios_rts_MemAlloc_alloc ========
static Void *ti_sysbios_rts_MemAlloc_alloc(SizeT size)
Header *packet;
SizeT allocSize;
xdc_runtime_Error_Block eb;
allocSize = size + sizeof(Header);
* If size is very large and allocSize overflows, the result will be
* smaller than size. In this case, don't try to allocate.
if (allocSize < size) {
return (NULL);
xdc_runtime_Error_init(&eb);
packet = (Header *)xdc_runtime_Memory_alloc(NULL, allocSize, 0, &eb);
if (packet == NULL) {
return (NULL);
packet->header.actualBuf = (Ptr)packet;
packet->header.size = allocSize;
return (packet + 1);
So, I tried to change the (target).cmd file Heapsize and program stacksize from a reference working ( sensor and collector example modified project ). #10099-D: program will not fit into available memory error occurred.
How do I edit .cmd file to allocate more space?
It would be immense help if anyone assist me.
Keerthivasan
