The .Out and .Hex program Generated by the same program, the .out file is burn Ok and .hex is burn wrong.
We use CCS to generate .out and .hex file and .hex file generated when seleted Enable C2000 Hex Utility.
At the same time,we Confirm that there is no problem with the hardware equipment and wiring.
When we use Uniflash to burn the .out program , the chip F28069 unlocked after entering the password, then burn successfully and the indicator light showing.
There is no problem with the .out program.
Then burn the .hex file also shows that the program was successfully burned, but the indicator light showing that the program was successfully burned does not light up,
It means that the program failed to be burned, and when we input the password, the chip can no longer be unlocked.
Please help me.
