gmake Error
i have installed CCS V10.4.0.00006
when trying to build the project i get this error
**** Build of configuration Debug for project HMI_APP_SW ****
"C:\\ti\\ccs1010\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
source/subdir_rules.mk:9: recipe for target 'source/ArincEncoding.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-1.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-1.bat, ...) failed.
gmake: *** [source/ArincEncoding.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/Cbit.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-2.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-2.bat, ...) failed.
gmake: *** [source/Cbit.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/Degraded.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-3.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-3.bat, ...) failed.
gmake: *** [source/Degraded.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/Failure.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-4.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-4.bat, ...) failed.
gmake: *** [source/Failure.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/Gps_Decode.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-5.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-5.bat, ...) failed.
gmake: *** [source/Gps_Decode.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/Pbit.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-6.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-6.bat, ...) failed.
gmake: *** [source/Pbit.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/PowerOff.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-7.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-7.bat, ...) failed.
gmake: *** [source/PowerOff.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/Process_Hmi.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-8.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-8.bat, ...) failed.
gmake: *** [source/Process_Hmi.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/Radio_marker.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-9.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-9.bat, ...) failed.
gmake: *** [source/Radio_marker.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/Sys_Config_Data.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-a.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-a.bat, ...) failed.
gmake: *** [source/Sys_Config_Data.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/Sys_Config_Display.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-b.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-b.bat, ...) failed.
gmake: *** [source/Sys_Config_Display.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/Watchdog.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-c.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-c.bat, ...) failed.
gmake: *** [source/Watchdog.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/lcd_pix_data.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-d.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-d.bat, ...) failed.
gmake: *** [source/lcd_pix_data.obj] Error 2
source/subdir_rules.mk:9: recipe for target 'source/lcd_pro.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-e.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-e.bat, ...) failed.
gmake: *** [source/lcd_pro.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/can.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-f.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-f.bat, ...) failed.
gmake: *** [source/COMMON/can.obj] Error 2
source/COMMON/subdir_rules.mk:16: recipe for target 'source/COMMON/dabort.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-10.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-10.bat, ...) failed.
gmake: *** [source/COMMON/dabort.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/dmm.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-11.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-11.bat, ...) failed.
gmake: *** [source/COMMON/dmm.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/emif.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-12.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-12.bat, ...) failed.
gmake: *** [source/COMMON/emif.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/errata_SSWF021_45.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-13.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-13.bat, ...) failed.
gmake: *** [source/COMMON/errata_SSWF021_45.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/esm.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-14.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-14.bat, ...) failed.
gmake: *** [source/COMMON/esm.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/gio.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-15.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-15.bat, ...) failed.
gmake: *** [source/COMMON/gio.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/i2c.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-16.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-16.bat, ...) failed.
gmake: *** [source/COMMON/i2c.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/notification.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-17.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-17.bat, ...) failed.
gmake: *** [source/COMMON/notification.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/pinmux.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-18.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-18.bat, ...) failed.
gmake: *** [source/COMMON/pinmux.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/sci.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-19.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-19.bat, ...) failed.
gmake: *** [source/COMMON/sci.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/spi.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-1a.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-1a.bat, ...) failed.
gmake: *** [source/COMMON/spi.obj] Error 2
source/COMMON/subdir_rules.mk:16: recipe for target 'source/COMMON/sys_core.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-1b.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-1b.bat, ...) failed.
gmake: *** [source/COMMON/sys_core.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/sys_dma.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-1c.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-1c.bat, ...) failed.
gmake: *** [source/COMMON/sys_dma.obj] Error 2
source/COMMON/subdir_rules.mk:16: recipe for target 'source/COMMON/sys_intvecs.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-1d.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-1d.bat, ...) failed.
gmake: *** [source/COMMON/sys_intvecs.obj] Error 2
source/COMMON/subdir_rules.mk:16: recipe for target 'source/COMMON/sys_mpu.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-1e.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-1e.bat, ...) failed.
gmake: *** [source/COMMON/sys_mpu.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/sys_pcr.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-1f.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-1f.bat, ...) failed.
gmake: *** [source/COMMON/sys_pcr.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/sys_phantom.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-20.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-20.bat, ...) failed.
gmake: *** [source/COMMON/sys_phantom.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/sys_pmm.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-21.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-21.bat, ...) failed.
gmake: *** [source/COMMON/sys_pmm.obj] Error 2
source/COMMON/subdir_rules.mk:16: recipe for target 'source/COMMON/sys_pmu.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-22.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-22.bat, ...) failed.
gmake: *** [source/COMMON/sys_pmu.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/sys_selftest.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-23.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-23.bat, ...) failed.
gmake: *** [source/COMMON/sys_selftest.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/sys_startup.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-24.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-24.bat, ...) failed.
gmake: *** [source/COMMON/sys_startup.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/sys_vim.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-25.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-25.bat, ...) failed.
gmake: *** [source/COMMON/sys_vim.obj] Error 2
source/COMMON/subdir_rules.mk:9: recipe for target 'source/COMMON/system.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-26.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-26.bat, ...) failed.
gmake: *** [source/COMMON/system.obj] Error 2
source/Function_HealthStatus/subdir_rules.mk:9: recipe for target 'source/Function_HealthStatus/HealthStatus_Data.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-27.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-27.bat, ...) failed.
gmake: *** [source/Function_HealthStatus/HealthStatus_Data.obj] Error 2
source/Function_HealthStatus/subdir_rules.mk:9: recipe for target 'source/Function_HealthStatus/HealthStatus_Display.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-28.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-28.bat, ...) failed.
gmake: *** [source/Function_HealthStatus/HealthStatus_Display.obj] Error 2
source/Function_SYS/subdir_rules.mk:9: recipe for target 'source/Function_SYS/Sys_MarkerVol_Data.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-29.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-29.bat, ...) failed.
gmake: *** [source/Function_SYS/Sys_MarkerVol_Data.obj] Error 2
source/Function_SYS/subdir_rules.mk:9: recipe for target 'source/Function_SYS/Sys_MarkerVol_Display.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-2a.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-2a.bat, ...) failed.
gmake: *** [source/Function_SYS/Sys_MarkerVol_Display.obj] Error 2
source/LCD Driver/subdir_rules.mk:9: recipe for target 'source/LCD Driver/LCD.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-2b.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-2b.bat, ...) failed.
gmake: *** [source/LCD Driver/LCD.obj] Error 2
source/Library/subdir_rules.mk:9: recipe for target 'source/Library/lcd_Key.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-2c.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-2c.bat, ...) failed.
gmake: *** [source/Library/lcd_Key.obj] Error 2
source/Library/subdir_rules.mk:9: recipe for target 'source/Library/lcd_Knob.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-2d.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-2d.bat, ...) failed.
gmake: *** [source/Library/lcd_Knob.obj] Error 2
source/Main/subdir_rules.mk:9: recipe for target 'source/Main/main.obj' failed
process_begin: CreateProcess(C:\Users\RC59947\AppData\Local\Temp\make17600-2e.bat, C:\Users\RC59947\AppData\Local\Temp\make17600-2e.bat, ...) failed.
gmake: *** [source/Main/main.obj] Error 2
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
please help me to resolve this issue.
Thanks.
