Hi
I have created a project spec for my projects, it works fine. But i have a lot of repeated settings, and would like to have that moved to a common place, either in a file that is the imported/referenced by each project, or as a common part inside the projectspec file.
Heavily simplified Example:
Current setup:
CPU1: compilerBuildOptions=" -v28 -O2 -I commonLib -I cpu1Code" CPU2: compilerBuildOptions=" -v28 -O3 -I commonLib -I cpu2Code"
Wanted setup
common: compilerBuildOptions="-v28 -I commonLib" CPU1: compilerBuildOptions="-O2 -I cpu1Code" + common CPU2: compilerBuildOptions="-O3 -I cpu2Code" + common
I have tried using the include tag, but that seams to only work for importing a complete project.
I have tried defining a build variable with the common compiler options, but it will not expand it prperly.
Is this possible with the current projectspec implementation? please advice.
