Other Parts Discussed in Thread: MSP430F5522, CCSTUDIO, MSP430F2274, CODECOMPOSER, SYSBIOS, TMP100
Why does the linker fail to produce the object code when the .map file reveals only ~18kB flash usage? The part is MSP430F5522, which has 32kB flash memory.
Purchased License
We have two products listed under the "Manage Activated Software" tab on TI's myRegistered Software site. They are: "CCSTUDIO TMDSCCS-HWN01A-v4.0" and "CCSTUDIO TMDSCCS-MCUN01-v4.0," which are listed as "Active" and not expired in myRegistered Software.
Please note I have attempted many things to ensure CCSv4 is properly licensed.
I have specified a "re-hosted" license file using myRegistered Software on TI's website and the "Specify a license file" option under the "Licensing options..." menu.
The title bar says "... - Code Composer Studio (Licensed)"
About Code Composer Studio
Version: 4.2.3.00004
About Code composer Studio Features
Version: 4.0.0.201102161800
Build id: N201102161800
Configuration Details Follow:
*** Date: Thu Jun 23 09:08:43 EDT 2011
*** Platform Details:
*** System properties:
DEFAULT_CCS_TARGET_CONFIGURATION=C:/Texas
Instruments/SimpliciTI-CCS-1.1.1/Projects/Examples/eZ430RF/prjv4/CCS/Project/MSP430F2274.ccxml
XPCOM.RUNTIME=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
awt.toolkit=sun.awt.windows.WToolkit
deployment.browser.args=-raise -remote openURL(%u,new-window)
deployment.browser.path=C:\Program Files\Mozilla Firefox\firefox.exe
deployment.cache.jarcompression=0
deployment.cache.max.size=-1
deployment.capture.mime.types=true
deployment.console.startup.mode=HIDE
deployment.control.panel.log=false
deployment.home.j2se.url=http://java.sun.com/j2se/
deployment.javapi.cache.enabled=true
deployment.javapi.lifecycle.exception=false
deployment.javapi.log.filename=
deployment.javapi.runtime.type=0
deployment.javapi.trace.filename=
deployment.javaws.associations=ASK_USER
deployment.javaws.autodownload=ALWAYS
deployment.javaws.home.jnlp.url=http://java.sun.com/products/javawebstart
deployment.javaws.installURL=http://java.sun.com/products/autodl/j2se
deployment.javaws.logFileName=
deployment.javaws.muffin.max=256
deployment.javaws.shortcut=ASK_IF_HINTED
deployment.javaws.ssv.enabled=true
deployment.javaws.traceFileName=
deployment.javaws.uninstall.shortcut=false
deployment.javaws.update.timeout=1500
deployment.log=false
deployment.mime.types.use.default=true
deployment.proxy.bypass.local=false
deployment.proxy.override.hosts=
deployment.proxy.same=false
deployment.proxy.type=3
deployment.repository.askdownloaddialog.show=true
deployment.repository.enabled=true
deployment.security.SSLv2Hello=true
deployment.security.SSLv3=true
deployment.security.TLSv1=false
deployment.security.askgrantdialog.notinca=true
deployment.security.askgrantdialog.show=true
deployment.security.authenticator=true
deployment.security.browser.keystore.use=true
deployment.security.clientauth.keystore.auto=true
deployment.security.jsse.hostmismatch.warning=true
deployment.security.sandbox.awtwarningwindow=true
deployment.security.sandbox.jnlp.enhanced=true
deployment.security.trusted.policy=
deployment.system.security.cacerts=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\cacerts
deployment.system.security.jssecacerts=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\jssecacerts
deployment.system.security.trusted.certs=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\trusted.certs
deployment.system.security.trusted.clientauthcerts=C:\Program
Files\Texas
Instruments\ccsv4\eclipse\jre\lib\security\trusted.clientcerts
deployment.system.security.trusted.jssecerts=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\trusted.jssecerts
deployment.trace=false
deployment.update.mime.types=true
deployment.user.cachedir=C:\Documents and Settings\rw197\Application Data\Sun\Java\Deployment\cache
deployment.user.extdir=C:\Documents and Settings\rw197\Application Data\Sun\Java\Deployment\ext
deployment.user.logdir=C:\Documents and Settings\rw197\Application Data\Sun\Java\Deployment\log
deployment.user.security.policy=file://C:/Documents%20and%20Settings/rw197/Application%20Data/Sun/Java/Deployment/security/java.policy
deployment.user.security.trusted.cacerts=C:\Documents
Data\Sun\Java\Deployment\security\trusted.cacerts
deployment.user.security.trusted.certs=C:\Documents
Data\Sun\Java\Deployment\security\trusted.certs
deployment.user.security.trusted.clientauthcerts=C:\Documents
Data\Sun\Java\Deployment\security\trusted.clientcerts
deployment.user.security.trusted.jssecacerts=C:\Documents
Data\Sun\Java\Deployment\security\trusted.jssecacerts
deployment.user.security.trusted.jssecerts=C:\Documents
Data\Sun\Java\Deployment\security\trusted.jssecerts
deployment.user.tmp=C:\Documents and Settings\rw197\Application Data\Sun\Java\Deployment\tmp
deployment.version=6.0
eclipse.buildId=4.2.3.00004
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\Program Files\Texas Instruments\ccsv4\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
c48_1780
-clean
-data
/C:/Texas Instruments/SimpliciTI-CCS-1.1.1/Projects/Examples/eZ430RF/
-vm
C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=com.ti.ccstudio.branding.product
eclipse.startTime=1308834277631
eclipse.vm=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-XX:MaxPermSize=96m
-DXPCOM.RUNTIME=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
-Dxpcom.bridge.executeOnDedicatedThread=no
-Dorg.eclipse.swt.browser.XULRunnerPath=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
-Dosgi.instance.area.default=file:/C:/Documents and Settings/rw197/My Documents/workspace/
-jar
C:\Program Files\Texas Instruments\ccsv4\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\endorsed
java.ext.dirs=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\ext
java.home=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre
java.io.tmpdir=C:\DOCUME~1\rw197\LOCALS~1\Temp\
java.library.path=C:\Program
Files\Texas
Instruments\ccsv4\eclipse\jre\bin;.;C:\WINDOWS\system32;C:\WINDOWS;C:\Program
Files\Texas Instruments\ccsv4\eclipse\..\common\bin;C:\Program
Files\Texas Instruments\ccsv4\eclipse\..\common\uscif;C:\Program
Files\Texas Instruments\ccsv4\eclipse\..\DebugServer\license;C:\Program
Files\Texas Instruments\ccsv4\eclipse\..\DebugServer\license;C:/Program
Files/Texas Instruments
Old/xdctools_3_15_02_62;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\SecureCRT\;C:\PROGRA~1\PICC;c:\Program Files\Microsoft SQL
Server\90\Tools\binn\;C:\Program Files\TortoiseSVN\bin;C:/Program
Files/Texas Instruments Old/xdctools_3_15_02_62;C:\Program Files\Texas
Instruments\ccsv4\eclipse\..\emulation\analysis\bin\
java.net.useSystemProxies=true
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_14-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_14
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_14-b03
javaplugin.proxy.config.type=direct
line.separator=
org.eclipse.swt.browser.XULRunnerInitialized=true
org.eclipse.ui.workbench.activePerspective=org.eclipse.cdt.ui.CPerspective
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax.activity,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=com.ti.ccstudio.osgi,org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\Program Files\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\bundles
osgi.clean=true
osgi.configuration.area=file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/configuration/
osgi.framework=file:/c:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi_3.2.0.vTI-201102161800.jar
osgi.framework.beginningstartlevel=1
osgi.framework.extensions=com.ti.ccstudio.osgi
osgi.framework.shape=jar
osgi.framework.version=3.2.0.vTI-201102161800
osgi.frameworkClassPath=.,
file:c:/Program Files/Texas
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.osgi_4.0.0.201102161800.jar
osgi.install.area=file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/
osgi.instance.area=file:/C:/Texas Instruments/SimpliciTI-CCS-1.1.1/Projects/Examples/eZ430RF/
osgi.logfile=C:\Texas Instruments\SimpliciTI-CCS-1.1.1\Projects\Examples\eZ430RF\.metadata\.log
osgi.manifest.cache=C:\Program Files\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\Program
Files\Texas
Instruments\ccsv4\eclipse\plugins\com.ti.ccstudio.branding_4.2.2.201102161800\splash.bmp
osgi.splashPath=platform:/base/plugins/com.ti.ccstudio.branding
osgi.syspath=c:\Program Files\Texas Instruments\ccsv4\eclipse\plugins
osgi.user.area=file:/C:/Documents and Settings/rw197/user/
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Texas Instruments\ccsv4\eclipse\jre\lib\rt.jar;C:\Program
Files\Texas Instruments\ccsv4\eclipse\jre\lib\i18n.jar;C:\Program
Files\Texas Instruments\ccsv4\eclipse\jre\lib\sunrsasign.jar;C:\Program
Files\Texas Instruments\ccsv4\eclipse\jre\lib\jsse.jar;C:\Program
Files\Texas Instruments\ccsv4\eclipse\jre\lib\jce.jar;C:\Program
Files\Texas Instruments\ccsv4\eclipse\jre\lib\charsets.jar;C:\Program
Files\Texas Instruments\ccsv4\eclipse\jre\classes
sun.boot.library.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 3
user.country=US
user.dir=C:\Program Files\Texas Instruments\ccsv4\eclipse
user.home=C:\Documents and Settings\rw197
user.language=en
user.name=rw197
user.timezone=America/New_York
user.variant=
*** Features:
com.ti.ccstudio (4.0.0.201102161800) "CCE Product Branding"
com.ti.dvt.graph.visualization (2.0.0.201011171816) "Visualization Plug-in"
com.ti.dvt.profileanalysismanager (2.0.0.201011171816) "Profiler Analysis Manager"
com.ti.dvt.rta (2.0.0.201011171816) "DSP/BIOS RTA"
com.ti.dvt.scripting.ui (4.0.0.201007072025) "DVT Scripting Plugin"
org.eclipse.cdt (3.1.0.vTI-201102161800) "Eclipse C/C++ Development Tools"
org.eclipse.platform (3.2.0.vTI-201102161800) "Eclipse Platform"
org.eclipse.rcp (3.2.0.vTI-201102161800) "Eclipse RCP"
org.eclipse.rtsc.xdctools_3.20 (3.20.6.81) "XDCtools UI Plugin"
org.eclipse.rtsc.xdctools_3.20 (3.20.0.41) "XDCtools UI Plugin"
org.eclipse.tm.terminal (1.0.0.vTI-201102161800) "Target Management Terminal Widget"
*** Plug-in Registry:
com.ibm.icu (3.4.4.1) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
com.ti.bios.rta (5.41.10.36) "BIOS 5 RTA Plug-in" [Resolved]
com.ti.ccstudio.apps (4.2.0.201010201600) "CCS Headless Applications" [Installed]
com.ti.ccstudio.apps (4.2.2.201102161800) "CCS Headless Applications" [Resolved]
com.ti.ccstudio.binaryparser (4.0.0.201010201600) "CCE Binary Parser" [Installed]
com.ti.ccstudio.binaryparser (4.0.0.201102161800) "CCE Binary Parser" [Active]
com.ti.ccstudio.branding (4.1.0.201010201600) "CCE Product Branding" [Installed]
com.ti.ccstudio.branding (4.2.2.201102161800) "CCE Product Branding" [Resolved]
com.ti.ccstudio.breakpoint (4.0.0.201010201600) "Property Breakpoint Interfaces" [Installed]
com.ti.ccstudio.breakpoint (4.0.0.201102161800) "Property Breakpoint Interfaces" [Resolved]
com.ti.ccstudio.breakpoint.core (4.0.0.201010201600) "Property Breakpoint Core" [Installed]
com.ti.ccstudio.breakpoint.core (4.0.0.201102161800) "Property Breakpoint Core" [Active]
com.ti.ccstudio.breakpoint.ui (4.0.0.201010201600) "Property Breakpoint User Interface" [Installed]
com.ti.ccstudio.breakpoint.ui (4.0.0.201102161800) "Property Breakpoint User Interface" [Active]
com.ti.ccstudio.buildDefinitions.C2000 (4.2.2.201102161800) "CCS C2000 Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000 (4.2.0.201010201600) "CCS C2000 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000_4.1 (4.2.0.201010201600) "CCE C2000 v4.1 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000_4.1 (4.2.2.201102161800) "CCS C2000 v4.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_5.0 (4.2.0.201010201600) "CCE C2000 v5.0 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000_5.0 (4.2.2.201102161800) "CCS C2000 v5.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_5.1 (4.2.0.201010201600) "CCE C2000 v5.1 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000_5.1 (4.2.2.201102161800) "CCS C2000 v5.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_5.2 (4.2.0.201010201600) "CCE C2000 v5.2 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000_5.2 (4.2.2.201102161800) "CCS C2000 v5.2 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_6.0 (4.2.0.201010201600) "CCS C2000 v6.0 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000_6.0 (4.2.2.201102161800) "CCS C2000 v6.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_legacy (4.1.0.201010201600) "CCS C2000 Legacy Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000_legacy (4.1.0.201102161800) "CCS C2000 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.core (4.2.0.201010201600) "Managed Build Definitions Core" [Installed]
com.ti.ccstudio.buildDefinitions.core (4.2.2.201102161800) "Managed Build Definitions Core" [Active]
com.ti.ccstudio.builddefinitions.generator (4.2.2.201102161800) "CCS Build Definitions Generator" [Active]
com.ti.ccstudio.buildDefinitions.GNU (4.1.0.201010201600) "CCE GNU Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.GNU (4.2.2.201102161800) "CCE GNU Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.MSP430 (4.2.2.201102161800) "CCS MSP430 Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.MSP430 (4.2.0.201010201600) "CCS MSP430 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_2.0 (4.2.2.201102161800) "CCS MSP430 v2.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_2.0 (4.2.0.201010201600) "MSP430 v2.0 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_3.0 (4.2.2.201102161800) "CCS MSP430 v3.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.0 (4.2.0.201010201600) "MSP430 v3.0 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_3.1 (4.2.2.201102161800) "CCS MSP430 v3.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.1 (4.2.0.201010201600) "MSP430 v3.1 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_3.2 (4.2.2.201102161800) "CCS MSP430 v3.2 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.2 (4.2.0.201010201600) "MSP430 v3.2 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_3.3 (4.2.2.201102161800) "CCS MSP430 v3.3 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.3 (4.1.3.201010201600) "MSP430 v3.3 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_3.4 (4.2.2.201102161800) "CCS MSP430 v3.4 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.4 (4.2.0.201010201600) "MSP430 v3.4 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_legacy (4.2.0.201010201600) "CCS MSP430 Legacy Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_legacy (4.2.2.201102161800) "CCS MSP430 Legacy Managed Build Definitions" [Active]
com.ti.ccstudio.c2000help.doc (4.0.0) "com.ti.ccstudio.c2000help.doc" [Resolved]
com.ti.ccstudio.debug.breakpoint.ui (4.0.0.201010201600) "TI Debugger Breakpoint User Interface" [Installed]
com.ti.ccstudio.debug.breakpoint.ui (4.0.0.201102161800) "TI Debugger Breakpoint User Interface" [Active]
com.ti.ccstudio.debug.cacheview (1.0.0) "Cache View Plug-in" [Resolved]
com.ti.ccstudio.debug.core (4.0.0.201010201600) "CCE Debug Core" [Installed]
com.ti.ccstudio.debug.core (4.2.2.201102161800) "CCE Debug Core" [Active]
com.ti.ccstudio.debug.memoryserver (4.0.0.201010201600) "Memory Server Plugin" [Resolved]
com.ti.ccstudio.debug.memoryserver (4.0.0.201102161800) "Memory Server Plugin" [Resolved]
com.ti.ccstudio.debug.mptv (4.0.0.201010201600) "MptvName" [Installed]
com.ti.ccstudio.debug.mptv (4.0.0.201102161800) "MptvName" [Resolved]
com.ti.ccstudio.debug.registers.ui (4.1.0.201010201600) "Registers UI Plug-in" [Installed]
com.ti.ccstudio.debug.registers.ui (4.1.0.201102161800) "Registers UI Plug-in" [Resolved]
com.ti.ccstudio.debug.server.extensions (4.0.0.201010201600) "CCE Debug Server Extensions" [Installed]
com.ti.ccstudio.debug.server.extensions (4.0.0.201102161800) "CCE Debug Server Extensions" [Active]
com.ti.ccstudio.debug.server.factory (4.0.0.201010201600) "CCE Debug Server Factory" [Resolved]
com.ti.ccstudio.debug.server.factory (4.0.0.201102161800) "CCE Debug Server Factory" [Active]
com.ti.ccstudio.debug.trace.core (4.0.0.201010201600) "Trace Core" [Installed]
com.ti.ccstudio.debug.trace.core (4.0.0.201102161800) "Trace Core" [Resolved]
com.ti.ccstudio.debug.trace.msp430 (4.0.0.201010201600) "MSP430 State Storage" [Installed]
com.ti.ccstudio.debug.trace.msp430 (4.0.0.201102161800) "MSP430 State Storage" [Resolved]
com.ti.ccstudio.debug.trace.ui (4.0.0.201010201600) "Trace UI" [Installed]
com.ti.ccstudio.debug.trace.ui (4.0.0.201102161800) "Trace UI" [Resolved]
com.ti.ccstudio.debug.ui (4.2.0.201010201600) "CCE Debug User Interface" [Installed]
com.ti.ccstudio.debug.ui (4.2.2.201102161800) "CCE Debug User Interface" [Active]
com.ti.ccstudio.debug.ui.msp430 (4.0.0.201010201600) "CCE Debug User Interface for MSP430" [Installed]
com.ti.ccstudio.debug.ui.msp430 (4.2.2.201102161800) "CCE Debug User Interface for MSP430" [Active]
com.ti.ccstudio.device.setup (4.2.0.201010201600) "CCS Device Setup" [Installed]
com.ti.ccstudio.device.setup (4.2.2.201102161800) "CCS Device Setup" [Resolved]
com.ti.ccstudio.disassembly.core (4.1.0.201010201600) "CCS Disassembly Core Plug-in" [Resolved]
com.ti.ccstudio.disassembly.core (4.1.0.201102161800) "CCS Disassembly Core Plug-in" [Active]
com.ti.ccstudio.disassembly.ui (4.1.0.201010201600) "CCS Disassembly UI Plug-in" [Installed]
com.ti.ccstudio.disassembly.ui (4.1.0.201102161800) "CCS Disassembly UI Plug-in" [Active]
com.ti.ccstudio.errorparser (4.0.0.201010201600) "CCE Error Parser" [Installed]
com.ti.ccstudio.errorparser (4.0.0.201102161800) "CCE Error Parser" [Active]
com.ti.ccstudio.gelhelp.doc (4.0.0.201010201600) "GEL Help Document Plug-in" [Installed]
com.ti.ccstudio.gelhelp.doc (4.0.0.201102161800) "GEL Help Document Plug-in" [Resolved]
com.ti.ccstudio.jline (4.0.0.201010201600) "Jline" [Installed]
com.ti.ccstudio.jline (4.0.0.201102161800) "Jline" [Resolved]
com.ti.ccstudio.mainhelp.doc (4.0.0) "CCS Help 4.0 Plugin" [Resolved]
com.ti.ccstudio.managedbuild.core (4.2.0.201010201600) "CCS Managed Build Core" [Installed]
com.ti.ccstudio.managedbuild.core (4.2.2.201102161800) "CCS Managed Build Core" [Active]
com.ti.ccstudio.managedbuild.ui (4.2.0.201010201600) "CCE Managed Build User Interface" [Installed]
com.ti.ccstudio.managedbuild.ui (4.2.2.201102161800) "CCE Managed Build User Interface" [Active]
com.ti.ccstudio.marker (4.0.0.201010201600) "Marker Plug-in" [Installed]
com.ti.ccstudio.marker (4.0.0.201102161800) "Marker Plug-in" [Active]
com.ti.ccstudio.memory.ui (4.0.0.201010201600) "CCS Memory UI Plug-in" [Installed]
com.ti.ccstudio.memory.ui (4.0.0.201102161800) "CCS Memory UI Plug-in" [Active]
com.ti.ccstudio.multi.purpose.view (4.2.0.201010201600) "CCS Control Panel View" [Installed]
com.ti.ccstudio.multi.purpose.view (4.2.0.201102161800) "CCS Control Panel View" [Active]
com.ti.ccstudio.multi.purpose.view.contributors (4.1.0.201010201600) "Control Panel View Contributors" [Installed]
com.ti.ccstudio.multi.purpose.view.contributors (4.1.0.201102161800) "Control Panel View Contributors" [Active]
com.ti.ccstudio.osgi (4.0.0.201102161800) "CCE OSGi Hooks" [Resolved]
com.ti.ccstudio.osgi (4.0.0.201010201600) "CCE OSGi Hooks" [Resolved]
com.ti.ccstudio.pinconnect (4.0.0.201010201600) "PinConnect Tool Plug-in" [Installed]
com.ti.ccstudio.pinconnect (4.0.0.201102161800) "PinConnect Tool Plug-in" [Resolved]
com.ti.ccstudio.pinport.common (4.0.0.201010201600) "Common Plug-in For Pin and Port Connect Tools" [Installed]
com.ti.ccstudio.pinport.common (4.0.0.201102161800) "Common Plug-in For Pin and Port Connect Tools" [Resolved]
com.ti.ccstudio.portconnect (4.0.0.201010201600) "PortConnect Tool Plug-in" [Installed]
com.ti.ccstudio.portconnect (4.0.0.201102161800) "PortConnect Tool Plug-in" [Resolved]
com.ti.ccstudio.product.paths (4.1.0.201010201600) "CCS Product Paths" [Installed]
com.ti.ccstudio.product.paths (4.1.0.201102161800) "CCS Product Paths" [Active]
com.ti.ccstudio.profile.setup (4.0.0.201010201600) "Profile Setup Plug-in" [Resolved]
com.ti.ccstudio.profile.setup (4.0.0.201102161800) "Profile Setup Plug-in" [Resolved]
com.ti.ccstudio.profile.setup.ui (4.0.0.201010201600) "Profile SetupUI Plug-in" [Installed]
com.ti.ccstudio.profile.setup.ui (4.0.0.201102161800) "Profile SetupUI Plug-in" [Active]
com.ti.ccstudio.project.core (4.2.0.201010201600) "CCS Project Core" [Installed]
com.ti.ccstudio.project.core (4.2.2.201102161800) "CCS Project Core" [Resolved]
com.ti.ccstudio.project.templates (4.2.0.201010201600) "CCS Built-in Project Templates" [Installed]
com.ti.ccstudio.project.templates (4.2.0.201102161800) "CCS Built-in Project Templates" [Resolved]
com.ti.ccstudio.project.ui (4.2.0.201010201600) "CCE Project User Interface" [Installed]
com.ti.ccstudio.project.ui (4.2.2.201102161800) "CCS Project User Interface" [Active]
com.ti.ccstudio.rhino (4.0.0.201010201600) "CCE Rhino JavaScript Engine" [Installed]
com.ti.ccstudio.rhino (4.0.0.201102161800) "CCE Rhino JavaScript Engine" [Resolved]
com.ti.ccstudio.scripting.console (4.0.0.201010201600) "Scripting Console" [Installed]
com.ti.ccstudio.scripting.console (4.0.0.201102161800) "Scripting Console" [Active]
com.ti.ccstudio.scripting.dss (4.0.0.201010201600) "Debug Server Scripting" [Installed]
com.ti.ccstudio.scripting.dss (4.0.0.201102161800) "Debug Server Scripting" [Resolved]
com.ti.ccstudio.scripting.environment (4.0.0.201010201600) "CCE Scripting Environment" [Installed]
com.ti.ccstudio.scripting.environment (4.0.0.201102161800) "CCE Scripting Environment" [Resolved]
com.ti.ccstudio.scripting.gss (4.2.0.201010201600) "CodeComposer Studio Scripting" [Installed]
com.ti.ccstudio.scripting.gss (4.2.2.201102161800) "CodeComposer Studio Scripting" [Resolved]
com.ti.ccstudio.scripting.ui (4.0.0.201010201600) "User Interface Scripting" [Installed]
com.ti.ccstudio.scripting.ui (4.0.0.201102161800) "User Interface Scripting" [Resolved]
com.ti.ccstudio.system.hotmenu (4.0.0.201010201600) "CCS System Hotmenu Plug-in" [Installed]
com.ti.ccstudio.system.hotmenu (4.0.0.201102161800) "CCS System Hotmenu Plug-in" [Active]
com.ti.ccstudio.system.setup (4.2.0.201010201600) "CCE System Setup" [Installed]
com.ti.ccstudio.system.setup (4.2.2.201102161800) "CCE System Setup" [Active]
com.ti.ccstudio.system.setup.ui (4.0.0.201010201600) "CCS System Setup Editor Plug-in" [Installed]
com.ti.ccstudio.system.setup.ui (4.2.2.201102161800) "CCS System Setup Editor Plug-in" [Active]
com.ti.ccstudio.trace.control (4.1.0.201010201600) "Trace Control Plug-in" [Installed]
com.ti.ccstudio.trace.control (4.1.0.201102161800) "Trace Control Plug-in" [Active]
com.ti.ccstudio.ui (4.1.0.201010201600) "CCS Platform User Interface" [Installed]
com.ti.ccstudio.ui (4.2.2.201102161800) "CCS Platform User Interface" [Active]
com.ti.ccstudio.ui.cheatsheets (4.0.0.201010201600) "Cheatsheets Plug-in" [Installed]
com.ti.ccstudio.ui.cheatsheets (4.0.0.201102161800) "Cheatsheets Plug-in" [Resolved]
com.ti.ccstudio.ui.forms (4.0.0.201010201600) "Forms Plug-in" [Installed]
com.ti.ccstudio.ui.forms (4.0.0.201102161800) "Forms Plug-in" [Resolved]
com.ti.ccstudio.update (4.0.0.201010201600) "CCS Update Plug-in" [Installed]
com.ti.ccstudio.update (4.0.0.201102161800) "CCS Update Plug-in" [Active]
com.ti.ccstudio.useaccess (4.0.0.201010201600) "Use Access Plug-in" [Installed]
com.ti.ccstudio.useaccess (4.0.0.201102161800) "Use Access Plug-in" [Resolved]
com.ti.common.core (4.2.0.201010201600) "Common TI Platform Core" [Installed]
com.ti.common.core (4.2.2.201102161800) "Common TI Platform Core" [Active]
com.ti.common.managedbuild.core (4.2.0.201010201600) "TI Common Managed-Build Core" [Installed]
com.ti.common.managedbuild.core (4.2.2.201102161800) "TI Common Managed-Build Core" [Active]
com.ti.common.managedbuild.ui (4.2.0.201010201600) "TI Common Managed-Build UI" [Installed]
com.ti.common.managedbuild.ui (4.2.2.201102161800) "TI Common Managed-Build UI" [Active]
com.ti.common.project.core (4.2.0.201010201600) "TI Common Project Core" [Installed]
com.ti.common.project.core (4.2.2.201102161800) "TI Common Project Core" [Resolved]
com.ti.common.project.ui (4.2.0.201010201600) "TI Common Project UI" [Installed]
com.ti.common.project.ui (4.2.2.201102161800) "TI Common Project UI" [Resolved]
com.ti.common.ui (4.1.0.201010201600) "Common TI User Interface" [Installed]
com.ti.common.ui (4.2.2.201102161800) "Common TI User Interface" [Active]
com.ti.common.update.discovery (4.1.1.201010201600) "Extension Site Discovery" [Installed]
com.ti.common.update.discovery (4.1.1.201102161800) "Extension Site Discovery" [Active]
com.ti.dvt.analysis.framework (2.0.0.201008091238) "DVT Analysis Framework" [Installed]
com.ti.dvt.analysis.framework (2.0.0.201011171816) "DVT Analysis Framework" [Resolved]
com.ti.dvt.cceideadapter (2.0.0.201008091238) "CCStudio v4 IDE Adapter" [Installed]
com.ti.dvt.cceideadapter (2.0.0.201011171816) "CCStudio v4 IDE Adapter" [Resolved]
com.ti.dvt.ccesymbolmanager (2.0.0.201008091238) "CCStudio 4.0 Symbol Manager" [Installed]
com.ti.dvt.ccesymbolmanager (2.0.0.201011171816) "CCStudio 4.0 Symbol Manager" [Resolved]
com.ti.dvt.codegenCoverage (2.0.0.201008091238) "Codegen_Code_Coverage Plug-in" [Installed]
com.ti.dvt.codegenCoverage (2.0.0.201011171816) "Codegen_Code_Coverage Plug-in" [Active]
com.ti.dvt.control.engine (2.0.0.201008091238) "DVT Control Engine" [Installed]
com.ti.dvt.control.engine (2.0.0.201011171816) "DVT Control Engine" [Resolved]
com.ti.dvt.control.gui (2.0.0.201008091238) "DVT Control GUI" [Installed]
com.ti.dvt.control.gui (2.0.0.201011171816) "DVT Control GUI" [Resolved]
com.ti.dvt.coverageplugin (2.0.0.201008091238) "Coverageplugin Plug-in" [Installed]
com.ti.dvt.coverageplugin (2.0.0.201011171816) "Coverageplugin Plug-in" [Active]
com.ti.dvt.datamodel (2.0.0.201008091238) "DVT Model" [Installed]
com.ti.dvt.datamodel (2.0.0.201011171816) "DVT Model" [Active]
com.ti.dvt.graph.visualization (1.0.0.201007072025) "Visualization Plug-in" [Installed]
com.ti.dvt.graph.visualization (2.0.0.201008091238) "Visualization Plug-in" [Installed]
com.ti.dvt.graph.visualization (2.0.0.201011171816) "Visualization Plug-in" [Active]
com.ti.dvt.graph.visualization.doc (2.0.0.201008091238) "Graph Visualization Help Plug-in" [Installed]
com.ti.dvt.graph.visualization.doc (2.0.0.201011171816) "Graph Visualization Help Plug-in" [Resolved]
com.ti.dvt.gridview (2.0.0.201008091238) "Gridview Plug-in" [Installed]
com.ti.dvt.gridview (2.0.0.201011171816) "Gridview Plug-in" [Resolved]
com.ti.dvt.ideadapter (2.0.0.201008091238) "IDEAdapter" [Installed]
com.ti.dvt.ideadapter (2.0.0.201011171816) "IDEAdapter" [Active]
com.ti.dvt.ideadapterplugin (2.0.0.201008091238) "IDEAdapter Plug-in" [Installed]
com.ti.dvt.ideadapterplugin (2.0.0.201011171816) "IDEAdapter Plug-in" [Active]
com.ti.dvt.ofssymbolmanager (2.0.0.201008091238) "OFSSymbolManager Plug-in" [Installed]
com.ti.dvt.ofssymbolmanager (2.0.0.201011171816) "OFSSymbolManager Plug-in" [Resolved]
com.ti.dvt.profileanalysis (2.0.0.201008091238) "DVT Profile Analysis Providers" [Installed]
com.ti.dvt.profileanalysis (2.0.0.201011171816) "DVT Profile Analysis Providers" [Resolved]
com.ti.dvt.profileanalysis.doc (2.0.0.201008091238) "DVT Profile Analysis Providers Help" [Installed]
com.ti.dvt.profileanalysis.doc (2.0.0.201011171816) "DVT Profile Analysis Providers Help" [Resolved]
com.ti.dvt.profileanalysismanager (1.0.0.201007072025) "Profiler Analysis Manager" [Installed]
com.ti.dvt.profileanalysismanager (2.0.0.201008091238) "Profiler Analysis Manager" [Installed]
com.ti.dvt.profileanalysismanager (2.0.0.201011171816) "Profiler Analysis Manager" [Resolved]
com.ti.dvt.profileanalysismanagerplugin (1.0.0.201007072025) "Profile Server Plug-in" [Installed]
com.ti.dvt.profileanalysismanagerplugin (2.0.0.201008091238) "Profile Server Plug-in" [Installed]
com.ti.dvt.profileanalysismanagerplugin (2.0.0.201011171816) "Profile Server Plug-in" [Active]
com.ti.dvt.profiledata (2.0.0.201008091238) "Profile Data Source" [Resolved]
com.ti.dvt.profiledata (2.0.0.201011171816) "Profile Data Source" [Resolved]
com.ti.dvt.rovsupport (2.0.0.201008091238) "Rovsupport Plug-in" [Installed]
com.ti.dvt.rovsupport (2.0.0.201011171816) "Rovsupport Plug-in" [Active]
com.ti.dvt.rovsupport.doc (2.0.0.201008091238) "ROV Support Doc Plug-in" [Installed]
com.ti.dvt.rovsupport.doc (2.0.0.201011171816) "ROV Support Doc Plug-in" [Resolved]
com.ti.dvt.rta (1.0.0.201007072025) "DSP/BIOS RTA" [Installed]
com.ti.dvt.rta (2.0.0.201008091238) "DSP/BIOS RTA" [Installed]
com.ti.dvt.rta (2.0.0.201011171816) "DSP/BIOS RTA" [Active]
com.ti.dvt.rta.doc (2.0.0.201008091238) "RTA Help" [Installed]
com.ti.dvt.rta.doc (2.0.0.201011171816) "RTA Help" [Resolved]
com.ti.dvt.rta.interfaces (1.0.0.201007072025) "RTA interfaces" [Installed]
com.ti.dvt.rta.interfaces (2.0.0.201008091238) "RTA interfaces" [Installed]
com.ti.dvt.rta.interfaces (2.0.0.201011171816) "RTA interfaces" [Resolved]
com.ti.dvt.scripting.ui (1.0.0.201007072025) "DVT Scripting Plugin" [Installed]
com.ti.dvt.scripting.ui (2.0.0.201011171816) "DVT Scripting Plugin" [Resolved]
com.ti.dvt.server (3.20.6.81) "ROV Controller" [Resolved]
com.ti.dvt.sourceref (2.0.0.201008091238) "Source Reference Plug-in" [Installed]
com.ti.dvt.sourceref (2.0.0.201011171816) "Source Reference Plug-in" [Resolved]
com.ti.dvt.sourcerefplugin (2.0.0.201008091238) "Source Reference Preference Plug-in" [Installed]
com.ti.dvt.sourcerefplugin (2.0.0.201011171816) "Source Reference Preference Plug-in" [Resolved]
com.ti.dvt.symbolmanager (2.0.0.201008091238) "SymbolManager" [Installed]
com.ti.dvt.symbolmanager (2.0.0.201011171816) "SymbolManager" [Resolved]
com.ti.dvt.symbolmanagerplugin (2.0.0.201008091238) "SymbolManager Plug-in" [Installed]
com.ti.dvt.symbolmanagerplugin (2.0.0.201011171816) "SymbolManager Plug-in" [Active]
com.ti.dvt.tidisassembly (2.0.0.201008091238) "TIDisassembly Plug-in" [Resolved]
com.ti.dvt.tidisassembly (2.0.0.201011171816) "TIDisassembly Plug-in" [Resolved]
com.ti.dvt.trace (1.0.0.201007072025) "DVT Trace Analyzer" [Installed]
com.ti.dvt.trace (2.0.0.201011171816) "DVT Trace Analyzer" [Active]
com.ti.dvt.trace.doc (1.1.0.201007072025) "Trace_Analyzer_User_Guide" [Installed]
com.ti.dvt.trace.doc (2.0.0.201011171816) "Trace_Analyzer_User_Guide" [Resolved]
com.ti.dvt.ui (2.0.0.201008091238) "DvtUI Plug-in" [Installed]
com.ti.dvt.ui (2.0.0.201011171816) "DvtUI Plug-in" [Active]
com.ti.dvt.ui.doc (2.0.0.201008091238) "com.ti.dvt.ui.doc" [Installed]
com.ti.dvt.ui.doc (2.0.0.201011171816) "com.ti.dvt.ui.doc" [Resolved]
com.ti.dvt.via.doc (2.0.0.201008091238) "Image Analyzer" [Installed]
com.ti.dvt.via.doc (2.0.0.201011171816) "Image Analyzer" [Resolved]
com.ti.dvt.via.imvr (1.0.0.201007072025) "Image Viewer Plug-in" [Installed]
com.ti.dvt.via.imvr (2.0.0.201008091238) "Image Viewer Plug-in" [Installed]
com.ti.dvt.via.imvr (2.0.0.201011171816) "Image Viewer Plug-in" [Resolved]
com.ti.dvt.via.plugin (2.0.0.201008091238) "Image Analyzer" [Installed]
com.ti.dvt.via.plugin (2.0.0.201011171816) "Image Analyzer" [Active]
com.ti.dvt.via.plugin.ccs (2.0.0.201008091238) "Image Analyzer (CCS)" [Installed]
com.ti.dvt.via.plugin.ccs (2.0.0.201011171816) "Image Analyzer (CCS)" [Active]
com.ti.fnc (4.0.0.201010201600) "FlexNet Connect Plug-in" [Active]
com.ti.fnc (4.0.0.201102161800) "FlexNet Connect Plug-in" [Resolved]
com.ti.rta (3.20.6.81) "XDC RTA Plug-in" [Resolved]
com.ti.rta.support (3.20.6.81) "Shared ROV interface implementations" [Resolved]
com.ti.rtsc.DSPBIOS.product_5.41.10.36 (5.41.10.36) "DSP/BIOS Tool Plugin" [Resolved]
com.ti.rtsc.DSPBIOS.product.ui (5.41.10.36) "DSP/BIOS UI Plugin" [Resolved]
com.ti.rtsc.IPC.product_1.21.2.23 (1.21.2.23) "IPC (Multicore and I/O) Tool Plugin" [Resolved]
com.ti.rtsc.IPC.product.ui (1.21.2.23) "IPC (Multicore and I/O) UI Plugin" [Resolved]
com.ti.rtsc.SYSBIOS.product_6.30.3.46 (6.30.3.46) "SYS/BIOS Tool Plugin" [Resolved]
com.ti.rtsc.SYSBIOS.product.ui (6.30.3.46) "SYS/BIOS UI Plugin" [Resolved]
com.ti.targets.omf (3.20.6.81) "Object file readers" [Resolved]
com.ti.util (2.0.0.201008091238) "Util Plug-in" [Resolved]
com.ti.util (2.0.0.201011171816) "Util Plug-in" [Resolved]
com.ti.util.ui (2.0.0.201008091238) "Util Plug-in" [Installed]
com.ti.util.ui (2.0.0.201011171816) "Util Plug-in" [Active]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.cdt (3.1.0.200606261600) "Eclipse C/C++ Development Tools" [Resolved]
org.eclipse.cdt.core (3.1.0.vTI-201010201600) "C/C++ Development Tools Core" [Installed]
org.eclipse.cdt.core (3.1.0.vTI-201102161800) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.win32 (3.1.0.200606261600) "C/C++ Development Tools Core for Windows" [Resolved]
org.eclipse.cdt.debug.core (3.1.0.vTI-201010201600) "C/C++ Development Tools Debug Model" [Installed]
org.eclipse.cdt.debug.core (3.1.0.vTI-201102161800) "C/C++ Development Tools Debug Model" [Active]
org.eclipse.cdt.debug.mi.core (3.1.0.200606261600) "C/C++ Development Tools GDB/MI CDI Debugger Core" [Resolved]
org.eclipse.cdt.debug.mi.ui (3.1.0.200606261600) "C/C++ Development Tools GDB/MI CDI Debugger UI" [Resolved]
org.eclipse.cdt.debug.ui (3.1.0.vTI-201010201600) "C/C++ Development Tools Debugger UI" [Installed]
org.eclipse.cdt.debug.ui (3.1.0.vTI-201102161800) "C/C++ Development Tools Debugger UI" [Active]
org.eclipse.cdt.launch (3.1.0.vTI-201010201600) "C/C++ Development Tools Launching Support" [Installed]
org.eclipse.cdt.launch (3.1.0.vTI-201102161800) "C/C++ Development Tools Launching Support" [Active]
org.eclipse.cdt.make.core (3.1.0.vTI-201010201600) "C/C++ Standard make Build Core" [Installed]
org.eclipse.cdt.make.core (3.1.0.vTI-201102161800) "C/C++ Standard make Build Core" [Active]
org.eclipse.cdt.make.ui (3.1.0.vTI-201010201600) "C/C++ Standard make Build UI" [Installed]
org.eclipse.cdt.make.ui (3.1.0.vTI-201102161800) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (3.1.0.vTI-201010201600) "C/C++ Managed Builder Core" [Installed]
org.eclipse.cdt.managedbuilder.core (3.1.0.vTI-201102161800) "C/C++ Managed Builder Core" [Active]
org.eclipse.cdt.managedbuilder.gnu.ui (3.1.0.vTI-201010201600) "GNU Managed Build Definitions" [Installed]
org.eclipse.cdt.managedbuilder.gnu.ui (3.1.0.vTI-201102161800) "GNU Managed Build Definitions" [Resolved]
org.eclipse.cdt.managedbuilder.ui (3.1.0.vTI-201010201600) "C/C++ Managed Builder UI" [Installed]
org.eclipse.cdt.managedbuilder.ui (3.1.0.vTI-201102161800) "C/C++ Managed Builder UI" [Active]
org.eclipse.cdt.refactoring (3.1.0.vTI-201010201600) "C/C++ Refactoring" [Installed]
org.eclipse.cdt.refactoring (3.1.0.vTI-201102161800) "C/C++ Refactoring" [Resolved]
org.eclipse.cdt.ui (3.1.0.vTI-201010201600) "C/C++ Development Tools UI" [Installed]
org.eclipse.cdt.ui (3.1.0.vTI-201102161800) "C/C++ Development Tools UI" [Active]
org.eclipse.compare (3.2.0.vTI-201010201600) "Compare Support" [Installed]
org.eclipse.compare (3.2.0.vTI-201102161800) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism" [Active]
org.eclipse.core.expressions (3.2.0.v20060605-1400) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.2.0.v20060605-1400) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File System for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.vTI-201010201600) "Eclipse Jobs Mechanism" [Installed]
org.eclipse.core.jobs (3.2.0.vTI-201102161800) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.0.vTI-201010201600) "Core Resource Management" [Installed]
org.eclipse.core.resources (3.2.0.vTI-201102161800) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.vTI-201102161800) "Core Runtime" [Active]
org.eclipse.core.runtime (3.2.0.vTI-201010201600) "Core Runtime" [Installed]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.0.v20060603) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Active]
org.eclipse.dd.debug.memory.renderings.traditional (1.0.0.vTI-201010201600) "Traditional Memory Rendering" [Installed]
org.eclipse.dd.debug.memory.renderings.traditional (1.0.0.vTI-201102161800) "Traditional Memory Rendering" [Resolved]
org.eclipse.debug.core (3.2.0.vTI-201010201600) "Debug Core" [Installed]
org.eclipse.debug.core (3.2.0.vTI-201102161800) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.0.vTI-201010201600) "Debug UI" [Installed]
org.eclipse.debug.ui (3.2.0.vTI-201102161800) "Debug UI" [Active]
org.eclipse.draw2d (3.2.0.v20060626) "Draw2d" [Resolved]
org.eclipse.equinox.common (3.2.0.vTI-201005061800) "Common Eclipse Runtime" [Installed]
org.eclipse.equinox.common (3.2.0.vTI-201008051800) "Common Eclipse Runtime" [Installed]
org.eclipse.equinox.common (3.2.0.vTI-201102161800) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.common (3.2.0.vTI-201008091000) "Common Eclipse Runtime" [Installed]
org.eclipse.equinox.common (3.2.0.vTI-201010201600) "Common Eclipse Runtime" [Installed]
org.eclipse.equinox.preferences (3.2.0.v20060601) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.0.v20060601) "Extension Registry Support" [Active]
org.eclipse.gef (3.2.0.v20060626) "Graphical Editing Framework" [Resolved]
org.eclipse.help (3.2.0.v20060602) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server" [Resolved]
org.eclipse.help.base (3.2.0.v20060601) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.0.v20060602) "Help System Webapp" [Resolved]
org.eclipse.jface (3.2.0.vTI-201010201600) "JFace" [Resolved]
org.eclipse.jface (3.2.0.vTI-201102161800) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding" [Resolved]
org.eclipse.jface.text (3.2.0.vTI-201010201600) "JFace Text" [Resolved]
org.eclipse.jface.text (3.2.0.vTI-201102161800) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.0.v20060605-1400) "Refactoring Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.2.0.v20060605-1400) "Refactoring UI" [Resolved]
org.eclipse.osgi (3.2.0.vTI-201010201600) "OSGi System Bundle" [Installed]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development Environment Runtime" [Resolved]
org.eclipse.platform (3.2.0.vTI-201010201600) "Eclipse Platform" [Installed]
org.eclipse.platform (3.2.0.vTI-201102161800) "Eclipse Platform" [Resolved]
org.eclipse.rcp (3.2.0.vTI-201010201600) "Eclipse RCP" [Installed]
org.eclipse.rcp (3.2.0.vTI-201102161800) "Eclipse RCP" [Resolved]
org.eclipse.rtsc.project.templates (3.20.6.81) "RTSC Built-in Project Templates" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS (1.2.0.201010201600) "DSP/BIOS Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS (1.2.2.201102161800) "DSP/BIOS Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31
(1.2.0.201010201600) "DSP/BIOS v5.31 Managed Build Definitions"
[Installed]
(1.2.0.201102161800) "DSP/BIOS v5.31 Managed Build Definitions"
[Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40
(1.2.0.201010201600) "DSP/BIOS v5.40 Managed Build Definitions"
[Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40 (1.2.0.201102161800) "DSP/BIOS v5.40 Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_6.00
(1.2.2.201102161800) "DSP/BIOS v6.00 Managed Build Definitions"
[Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC (1.2.0.201010201600) "XDC Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC (1.2.2.201102161800) "XDC Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00 (1.2.0.201010201600) "XDC v3.00 Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00 (1.2.2.201102161800) "XDC v3.00 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10 (1.2.0.201010201600) "XDC v3.10 Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10 (1.2.2.201102161800) "XDC v3.10 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15 (1.2.0.201010201600) "XDC v3.15 Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15 (1.2.2.201102161800) "XDC v3.15 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16 (1.2.0.201010201600) "XDC v3.16 Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16 (1.2.2.201102161800) "XDC v3.16 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.contenttype (3.20.6.81) "RTSC file content describers" [Resolved]
org.eclipse.rtsc.xdctools.core (3.20.6.81) "XDCtools core" [Resolved]
org.eclipse.rtsc.xdctools.managedbuild.core (1.2.0.201010201600) "RTSC Managed Build Core" [Installed]
org.eclipse.rtsc.xdctools.managedbuild.core (1.2.2.201102161800) "RTSC Managed Build Core" [Active]
org.eclipse.rtsc.xdctools.managedbuild.ui (1.2.0.201010201600) "RTSC Managed Build UI" [Installed]
org.eclipse.rtsc.xdctools.managedbuild.ui (1.2.2.201102161800) "RTSC Managed Build UI" [Active]
org.eclipse.rtsc.xdctools.model (3.20.6.81) "Model Plug-in" [Resolved]
org.eclipse.rtsc.xdctools.model.lang (3.20.6.81) "Lang Fragment" [Resolved]
org.eclipse.rtsc.xdctools.product_3.20.6.81 (3.20.6.81) "XDCtools Tool Plugin" [Resolved]
org.eclipse.rtsc.xdctools.product.ui (3.20.6.81) "XDCtools UI Plugin" [Resolved]
org.eclipse.rtsc.xdctools.rta (3.20.6.81) "XDCtools RTA" [Resolved]
org.eclipse.rtsc.xdctools.server (3.20.6.81) "XDCscript command server" [Resolved]
org.eclipse.rtsc.xdctools.sg (3.20.6.81) "XDCtools SG Plug-in" [Resolved]
org.eclipse.rtsc.xdctools.sg.def (3.20.6.81) "XDCtools SG Def Plug-in" [Resolved]
org.eclipse.rtsc.xdctools.ui (3.20.6.81) "Eclipse Plug-in" [Resolved]
org.eclipse.rtsc.xdctools.ui.contentassist (3.20.6.81) "RTSC C/C++ Content Assist" [Active]
org.eclipse.rtsc.xdctools.ui.editors (3.20.6.81) "Editors Plug-in" [Resolved]
org.eclipse.search (3.2.0.vTI-201010201600) "Search Support" [Installed]
org.eclipse.search (3.2.0.vTI-201102161800) "Search Support" [Active]
org.eclipse.swt (3.2.0.vTI-201010201600) "Standard Widget Toolkit" [Installed]
org.eclipse.swt (3.4.0.vTI-201102161800) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.0.vTI-201010201600) "Standard Widget Toolkit for Windows" [Installed]
org.eclipse.swt.win32.win32.x86 (3.4.0.vTI-201102161800) "Standard Widget Toolkit for Windows" [Resolved]
org.eclipse.team.core (3.2.0.I200606051140) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.0.M20060628) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.2.0.I200606011710) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200606051140) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.0.I200606051140) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.0.I200606051140) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tm.terminal (1.0.0.vTI-201010201600) "Target Management Terminal Widget" [Installed]
org.eclipse.tm.terminal (1.0.0.vTI-201102161800) "Target Management Terminal Widget" [Resolved]
org.eclipse.tm.terminal.serial (1.0.0.v20070605) "Target Management Terminal Serial Connector" [Resolved]
org.eclipse.tm.terminal.view (1.0.0.v20070620) "Target Management Terminal View" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.0.vTI-201010201600) "Eclipse UI" [Installed]
org.eclipse.ui (3.2.0.vTI-201102161800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.0.vTI-201010201600) "Cheat Sheets" [Installed]
org.eclipse.ui.cheatsheets (3.2.0.vTI-201102161800) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.vTI-201010201600) "Console" [Installed]
org.eclipse.ui.console (3.1.100.vTI-201102161800) "Console" [Active]
org.eclipse.ui.editors (3.2.0.vTI-201010201600) "Default Text Editor" [Installed]
org.eclipse.ui.editors (3.2.0.vTI-201102161800) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.100.vTI-201010201600) "External Tools" [Installed]
org.eclipse.ui.externaltools (3.1.100.vTI-201102161800) "External Tools" [Resolved]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.2.0.vTI-201010201600) "Eclipse IDE UI" [Installed]
org.eclipse.ui.ide (3.2.0.vTI-201102161800) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.0.v20060601) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.0.v20060602) "Universal Welcome" [Resolved]
org.eclipse.ui.navigator (3.2.0.I20060605-1400) "Common Navigator View" [Resolved]
org.eclipse.ui.navigator.resources (3.2.0.I20060605-1400) "Navigator Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21 Presentation Plug-in" [Resolved]
org.eclipse.ui.views (3.2.0.vTI-201010201600) "Views" [Installed]
org.eclipse.ui.views (3.2.0.vTI-201102161800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.0.I20060605-1400) "Tabbed Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.2.0.vTI-201010201600) "Workbench" [Installed]
org.eclipse.ui.workbench (3.2.0.vTI-201102161800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.vTI-201010201600) "Text Editor Framework" [Installed]
org.eclipse.ui.workbench.texteditor (3.2.0.vTI-201102161800) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.2.0.vTI-201102161800) "Install/Update Configurator" [Active]
org.eclipse.update.configurator (3.2.0.vTI-201010201600) "Install/Update Configurator" [Installed]
org.eclipse.update.core (3.2.0.vTI-201010201600) "Install/Update Core" [Installed]
org.eclipse.update.core (3.2.0.vTI-201102161800) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.0.vTI-201010201600) "Install/Update Core for Windows" [Resolved]
org.eclipse.update.core.win32 (3.2.0.vTI-201102161800) "Install/Update Core for Windows" [Resolved]
org.eclipse.update.scheduler (3.2.0.v20060605) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.2.0.vTI-201010201600) "Install/Update UI" [Installed]
org.eclipse.update.ui (3.2.0.vTI-201102161800) "Install/Update UI" [Active]
system.bundle (3.2.0.vTI-201102161800) "OSGi System Bundle" [Active]
xdc.tools.xgconf.modeldata (3.20.6.81) "Modeldata Plug-in" [Resolved]
*** User Preferences:
#Thu Jun 23 09:08:44 EDT 2011
/project/prj_v4/org.eclipse.cdt.core/indexerId=org.eclipse.cdt.core.domsourceindexer
@org.eclipse.debug.ui=3.2.0.vTI-201102161800
@org.eclipse.ui.ide=3.2.0.vTI-201102161800
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/environment/project/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673=<?xml
version\="1.0" encoding\="UTF-8"?>\r\n<environment/>\r\n
/project/prjv6/org.eclipse.cdt.managedbuilder.core/environment/project/com.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400=<?xml
/instance/org.eclipse.cdt.core/indexerId=org.eclipse.cdt.core.domsourceindexer
@org.eclipse.cdt.ui=3.1.0.vTI-201102161800
/instance/org.eclipse.cdt.managedbuilder.core/properties/Project.com.ti.ccstudio.buildDefinitions.MSP430.executableProjectType.463506595/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663=\#\r\n\#Thu
Jun 23 09\:06\:28 EDT
2011\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.ToolchainPlaceholder.95893310\=\\\#\\r\\n\\\#Thu
Jun 23 09\\\:06\\\:28 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/nwk/nwk_frame.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.2087695278\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/nwk_applications/nwk_ioctl.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.1592875455\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.2018820287\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/nwk/nwk_globals.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.33632730\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.998291008\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.57896802\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/nwk_applications/nwk_security.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/bsp/bsp.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Applications/application/prj-camera/prj_camera.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.397777807\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.748912577\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/nwk_applications/nwk_join.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/nwk_applications/nwk_link.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Fri
Nov 12 10\\\:49\\\:18 EST
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Applications/application/End\\
Device/main_babble.c\=\\\#\\r\\n\\\#Thu Jun 23 09\\\:06\\\:28 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.1031452240\=\\\#\\r\\n\\\#Mon
Nov 29 08\\\:19\\\:24 EST
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.linkerDebug.1128124303\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/nwk_applications/nwk_freq.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/nwk/nwk_api.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.688978495\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.488424606\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663\=\\\#\\r\\n\\\#Thu
2011\\r\\nrcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021./prj_v4/Applications/application/prj_PIR/prj_sensor.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021./prj_v4/Applications/application/prj_micrec/prj_micrec.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.635650604\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/nwk/nwk_QMgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/nwk/nwk.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Applications/application/prj_micrec/prj_micrec.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Applications/application/prj_control/prj_control.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.1992216237\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.1239807530\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Applications/application/prj_PIR/prj_sensor.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.2040253796\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.1259589605\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.1452477784\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Applications/application/End\\
Device/prj_main.c\=\\\#\\r\\n\\\#Thu Jun 23 09\\\:06\\\:28 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.584169263\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.1970827291\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Applications/application/prj_PIR/prj_pir.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/nwk_applications/nwk_ping.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Applications/application/Cell/prj_cell.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.1285449978\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Fri
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/mrfi/mrfi.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686.52376909\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663./prj_v4/Components/nwk_applications/nwk_mgmt.c\=\\\#\\r\\n\\\#Thu
Jun 23 09\\\:06\\\:28 EDT 2011\\r\\nrebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.core.resources/pathvariable.CCS_MSP430_3_2_2_CG_ROOT=C\:/Program
Files/Texas Instruments/ccsv4/tools/compiler/msp430
@org.eclipse.ui.browser=3.2.0.v20060602
/instance/org.eclipse.ui.editors/overviewRuler_migration=migrated_3.1
/instance/com.ti.common.ui/activeProject=prjv6
/project/prjv6/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400/internalBuilder/ignoreErr=true
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/environment/project/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663=<?xml
/instance/org.eclipse.core.resources/version=1
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313/internalBuilder/enabled=false
@org.eclipse.core.resources=3.2.0.vTI-201102161800
/instance/org.eclipse.ui.editors/org.eclipse.cdt.ui.editor.CEditor.internal.delegateSaveAs=true
/instance/org.eclipse.ui/showIntro=false
/project/prjv6/org.eclipse.cdt.managedbuilder.core/environment/project=<?xml
/instance/org.eclipse.cdt.managedbuilder.core/properties/Project.com.ti.ccstudio.buildDefinitions.MSP430.executableProjectType.463506595/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313=\#\r\n\#Thu
Jun 23 09\:06\:27 EDT
2011\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Mon
Nov 29 08\\\:19\\\:22 EST
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/mrfi/mrfi.c\=\\\#\\r\\n\\\#Thu
Jun 23 09\\\:06\\\:27 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/nwk_applications/nwk_ping.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.linkerDebug.1105208585\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/nwk_applications/nwk_security.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Applications/application/End\\
Device/main_babble.c\=\\\#\\r\\n\\\#Tue Apr 06 15\\\:51\\\:37 EDT
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Mon
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/nwk_applications/nwk_mgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/nwk/nwk_api.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/nwk/nwk_QMgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/nwk_applications/nwk_join.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./prj_v4/Applications/application/End\\
Device/main_babble.c\=\\\#\\r\\n\\\#Thu Jun 23 09\\\:06\\\:27 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/nwk/nwk_api.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./prj_v4/Applications/application/prj_PIR/prj_sensor.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/nwk_applications/nwk_link.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/mrfi/mrfi.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/nwk/nwk.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/nwk_applications/nwk_ioctl.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/bsp/bsp.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./prj_v4/Applications/application/prj_PIR/prj_pir.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/nwk_applications/nwk_freq.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/nwk/nwk_globals.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./prj_v4/Applications/application/Cell/prj_main.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/nwk_applications/nwk_security.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./prj_v4/Applications/application/End\\
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Mon
Nov 08 11\\\:49\\\:26 EST
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./prj_v4/Applications/application/prj_PIR/prj_pir.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/nwk_applications/nwk_join.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Mon
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/nwk/nwk_globals.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./prj_v4/Applications/application/prj_PIR/prj_sensor.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./prj_v4/Applications/application/Cell/prj_cell.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/nwk/nwk_frame.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/nwk_applications/nwk_link.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313\=\\\#\\r\\n\\\#Thu
2011\\r\\nrcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./prj_v4/Applications/application/prj-camera/prj_camera.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./prj_v4/Applications/application/prj_control/prj_control.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/nwk_applications/nwk_freq.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./prj_v4/Applications/application/prj-camera/prj_camera.c\=\\\#\\r\\n\\\#Thu
Device/prj_main.cc\=\\\#\\r\\n\\\#Tue Apr 06 15\\\:51\\\:37 EDT
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/nwk/nwk.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/nwk/nwk_frame.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.DebugToolchain.457756360\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./prj_v4/Applications/application/Cell/prj_main.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/nwk_applications/nwk_ping.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./prj_v4/Applications/application/prj_control/prj_control.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/nwk_applications/nwk_ioctl.c\=\\\#\\r\\n\\\#Thu
Device/main_prj.c\=\\\#\\r\\n\\\#Tue Apr 06 15\\\:51\\\:37 EDT
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Components/nwk_applications/nwk_mgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./Project/Applications/application/End\\
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313./prj_v4/Applications/application/End\\
2010\\r\\nrebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./prj_v4/Applications/application/End\\
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/bsp/bsp.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./prj_v4/Applications/application/Cell/prj_cell.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267./Project/Components/nwk/nwk_QMgmt.c\=\\\#\\r\\n\\\#Thu
Jun 23 09\\\:06\\\:27 EDT 2011\\r\\nrebuildState\\\=false\\r\\n\r\n
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@com.ti.common.ui=4.2.2.201102161800
file_export_version=3.0
@org.eclipse.cdt.core=3.1.0.vTI-201102161800
/instance/com.ti.ccstudio.disassembly.ui/com.ti.ccstudio.debug.ui.TIDisassemblyView+syncActionId=true
@com.ti.ccstudio.disassembly.ui=4.1.0.201102161800
/instance/org.eclipse.cdt.managedbuilder.core/properties/Project.com.ti.ccstudio.buildDefinitions.MSP430.executableProjectType.463506595/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155=\#\r\n\#Thu
2011\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/nwk_applications/nwk_ioctl.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/nwk_applications/nwk_mgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.5823919\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1370623765./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1338172368\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.823523058\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/nwk_applications/nwk_security.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/nwk/nwk_globals.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1311835614\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1370623765\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/bsp/bsp.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/nwk/nwk_frame.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Applications/bluetooth.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.943003900\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/nwk/nwk_api.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.711683417\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Applications/application/End\\
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1607491152\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/nwk_applications/nwk_join.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1370623765./prj_v4/Applications/application/prj_PIR/prj_sensor.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/nwk_applications/nwk_link.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1693417095\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.ToolchainPlaceholder.1540048753\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Applications/application/prj_PIR/prj_sensor.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1257457704\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/nwk_applications/nwk_freq.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1370623765./prj_v4/Applications/application/prj_control/prj_control.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.438188096\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Applications/application/prj_control/prj_control.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/nwk/nwk.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.109171608\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/mrfi/mrfi.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155\=\\\#\\r\\n\\\#Thu
2011\\r\\nrcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Applications/camera.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/nwk/nwk_QMgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1152771986\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Applications/application/prj_PIR/prj_pir.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1370623765./prj_v4/Applications/camera.c\=\\\#\\r\\n\\\#Thu
Device/prj_main.c\=\\\#\\r\\n\\\#Thu Jun 23 09\\\:06\\\:27 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.710825708\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1370623765./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.linkerDebug.716956704\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Applications/application/Cell/prj_cell.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Applications/application/prj-camera/prj_camera.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1789320392\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1190864739\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1370623765./prj_v4/Applications/bluetooth.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1540310268\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155./prj_v4/Components/nwk_applications/nwk_ping.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1688801234\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1370623765./prj_v4/Applications/application/prj_PIR/prj_pir.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.2104393309\=\\\#\\r\\n\\\#Thu
/instance/org.eclipse.core.resources/pathvariable.CCS_C2000_5_2_9_CG_ROOT=C\:/Program
Files/Texas Instruments/ccsv4/tools/compiler/C2000 Code Generation
Tools 5.2.9
/instance/com.ti.ccstudio.disassembly.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.core.resources/pathvariable.CCS_C2000_5_2_7_CG_ROOT=C\:/Program
Tools 5.2.7
/instance/org.eclipse.ui.ide/platformState=1302289512537
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695/internalBuilder/enabled=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/Project.com.ti.ccstudio.buildDefinitions.MSP430.executableProjectType.463506595/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695=\#\r\n\#Thu
2011\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.2129729050\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/End\\
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.109400039\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/nwk_applications/nwk_join.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.1017357743\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/examples/avr/avrtest.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.1435330980\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/prj_control/prj_control.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/nwk_applications/nwk_link.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1806408632./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/examples/avr/dumpfile.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/prj-camera/prj_camera.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/nwk/nwk_frame.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/nwk_applications/nwk_freq.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/hwdrivers/msp430_sd_spi/msp430_sd_spi.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.220484251\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/nwk/nwk_globals.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.1933691287\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/prj_PIR/prj_sensor.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1806408632./prj_v4/Applications/prj.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.899037752\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.1991588516\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/Cell/prj_cell.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695\=\\\#\\r\\n\\\#Thu
2011\\r\\nrcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.1650565857\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.1819616787\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.linkerDebug.366239097\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1806408632\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1806408632./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/examples/avr/dumpfile.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/bsp/bsp.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.1918154846\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/prj_micrec/prj_micrec.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.64820207\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1806408632./prj_v4/Applications/application/prj_micrec/prj_micrec.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.1559534400\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/prj_PIR/prj_pir.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.1965155519\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/prj.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.689673853\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.337089093\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1806408632./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/hwdrivers/msp430_sd_spi/msp430_sd_spi.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/nwk/nwk_QMgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/nwk_applications/nwk_ping.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.1604299233\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/mrfi/mrfi.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.2079143412\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.1028944346\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Tue
Jul 20 09\\\:07\\\:37 EDT
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/nwk_applications/nwk_mgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/protocols/sdcard_spi/sd.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.ToolchainPlaceholder.157797845\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/nwk/nwk.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.602903291\=\\\#\\r\\n\\\#Tue
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1806408632./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/examples/avr/avrtest.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.973398143\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/nwk/nwk_api.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/nwk_applications/nwk_security.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889.358198374\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695./prj_v4/Components/nwk_applications/nwk_ioctl.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1806408632./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/protocols/sdcard_spi/sd.c\=\\\#\\r\\n\\\#Thu
/project/prjv6/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400/internalBuilder/enabled=false
/instance/org.eclipse.cdt.managedbuilder.core/properties/Project.com.ti.ccstudio.buildDefinitions.MSP430.executableProjectType.463506595/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885=\#\r\n\#Thu
2011\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Applications/application/prj_PIR/prj_pir.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/nwk_applications/nwk_mgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.894588827\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/nwk/nwk_frame.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/bsp/bsp.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.2081472003\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1935831095\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.787558829./prj_v4/Applications/application/prj_PIR/prj_sensor.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/nwk_applications/nwk_ioctl.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.478177042\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1012427566\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/nwk_applications/nwk_join.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/nwk_applications/nwk_security.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Applications/application/End\\
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1917017371\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/nwk_applications/nwk_link.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1780279918\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Applications/application/prj_PIR/prj_sensor.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/nwk/nwk_api.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.695637286\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Applications/application/prj-camera/prj_camera.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/nwk_applications/nwk_freq.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1866573318\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.795892277\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.574272963\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885\=\\\#\\r\\n\\\#Thu
2011\\r\\nrcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/nwk/nwk.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1261035781\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.2066796105\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.787558829./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.863455894\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/mrfi/mrfi.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/nwk/nwk_QMgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.787558829./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Applications/application/Cell/prj_cell.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1413357439\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1345924671\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1585266813\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.ToolchainPlaceholder.1251508560\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.787558829\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1006040466\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/nwk/nwk_globals.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885./prj_v4/Components/nwk_applications/nwk_ping.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.linkerDebug.501397864\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.12134315\=\\\#\\r\\n\\\#Thu
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/environment/project/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797=<?xml
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/environment/project=<?xml
/instance/com.ti.ccstudio.debug.core/CCEDebugOptions.TARGET_CONFIGURATION_FILE=C\:/Texas
Instruments/SimpliciTI-CCS-1.1.1/Projects/Examples/eZ430RF/prjv4/CCS/Project/MSP430F2274.ccxml
/instance/org.eclipse.cdt.managedbuilder.core/properties/Project.com.ti.ccstudio.buildDefinitions.MSP430.executableProjectType.463506595/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797=\#\r\n\#Thu
2011\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/nwk/nwk_globals.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.1992251219\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/mrfi/mrfi.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/bsp/bsp.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/efs.c\=\\\#\\r\\n\\\#Fri
Apr 08 12\\\:12\\\:47 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/extract.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/hwdrivers/linuxfile/linuxfile.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/extract.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/soft_uart.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/fs/vfat/ui.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/nwk_applications/nwk_freq.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/init.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/ioman_small.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.1715847664\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/debug.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_control/prj_control.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/cpi.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.1070175355\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797\=\\\#\\r\\n\\\#Thu
2011\\r\\nrcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/nwk_applications/nwk_link.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/hwdrivers/linuxfile/helper.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.406093893\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_PIR/prj_sensor.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/hwdrivers/linuxfile/linuxfile.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/disc.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/nwk/nwk_api.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/plibc.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/hwdrivers/atmega_spi/atmega_spi.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.ToolchainPlaceholder.1963335821\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.1015071349\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/cpa.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.1052210395\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/examples/avr/dumpfile.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/soft_uart.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.2051146739\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.628079338\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/cp.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.1070184684\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/fs/vfat/ui.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/examples/avr/dumpfile.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/nwk/nwk_QMgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/plibc.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/cpa.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/nwk_applications/nwk_mgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/nwk_applications/nwk_security.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.1175415249\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/interface.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/nwk/nwk.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/efs.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/hwdrivers/tms67xx_sd/dsp67xx.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/mkdir.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/mkdir.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/hwdrivers/linuxfile/helper.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.953928325\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/nwk_applications/nwk_join.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.834335048\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.151975857\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/examples/avr/avrtest.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.586230001\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/End\\
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.linkerDebug.1330886185\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/cp.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/partition.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/list.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/hwdrivers/atmega_spi/atmega_spi.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.732561260\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/ioman_small.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_PIR/prj_pir.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/interface.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.2009526295\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/list.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj-camera/prj_camera.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/cpo.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/examples/avr/avrtest.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/disc.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/sextract.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.762789779\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/ioman.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.483041867\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.1558916234\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/hwdrivers/tms67xx_sd/dsp67xx.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/nwk_applications/nwk_ioctl.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.1878650429\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/nwk_applications/nwk_ping.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/Cell/prj_cell.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/cpo.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.286010509\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/sextract.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/init.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1406387448./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/debug.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1928400021.250120053\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/partition.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/src/base/ioman.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Applications/application/prj_micrec/efsl-0.3.6/util/fsutil/cpi.c\=\\\#\\r\\n\\\#Fri
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797./prj_v4/Components/nwk/nwk_frame.c\=\\\#\\r\\n\\\#Thu
@org.eclipse.cdt.debug.core=3.1.0.vTI-201102161800
/instance/org.eclipse.core.resources/description.autobuilding=true
/instance/org.eclipse.core.resources/pathvariable.CCS_MSP430_3_2_3_CG_ROOT=C\:/Program
Files/Texas Instruments/ccsv4/tools/compiler/MSP430 Code Generation
Tools 3.2.3
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/environment/project/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885=<?xml
version\="1.0" encoding\="UTF-8"?>\r\n<environment/>\r\n
@org.eclipse.ui.editors=3.2.0.vTI-201102161800
/instance/org.eclipse.debug.ui/com.ti.ccstudio.memory.ui.viewPanesVisibility.com.ti.ccstudio.memory.ui.view.TIMemoryView.0=com.ti.ccstudio.memory.ui.MemoryView.RenderingViewPane,
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Texas
Instruments\\SimpliciTI-CCS-1.1.1\\Projects\\Examples\\eZ430RF,C\:\\data\\liquid_robotics\\build\\,C\:\\data\\liquid_robotics\\build\\lr_controller\\Controller,C\:\\data\\liquid_robotics\\build\\lr_controller,C\:\\data\\MSRA\\multistatic\\trunk\\work
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/Project.com.ti.ccstudio.buildDefinitions.MSP430.executableProjectType.463506595/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883=\#\r\n\#Thu
2011\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1580145984\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1037869573\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.785956874\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/nwk/nwk_frame.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/mrfi/mrfi.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/nwk_applications/nwk_freq.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Applications/application/End\\
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1809758685\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686./prj_v4/Applications/application/prj_control/prj_control.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1007082518\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.896812853\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Applications/application/Cell/prj_cell.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1177077616\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Applications/application/prj_PIR/prj_pir.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Applications/application/prj_control/prj_control.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.ToolchainPlaceholder.908557281\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1431733097\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.2111183268\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/bsp/bsp.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/nwk/nwk_QMgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/nwk_applications/nwk_ping.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1432280347\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1202958334\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.215471739\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/nwk_applications/nwk_mgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/nwk_applications/nwk_security.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.578225947\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Applications/application/prj-camera/prj_camera.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/nwk/nwk_globals.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1621782505\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/nwk/nwk.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.linkerDebug.738160644\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1523000830\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686./prj_v4/Applications/application/prj_PIR/prj_pir.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/nwk_applications/nwk_join.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883\=\\\#\\r\\n\\\#Thu
2011\\r\\nrcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.504812157\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1358454561\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1305887686./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/nwk_applications/nwk_ioctl.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/nwk_applications/nwk_link.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883./prj_v4/Components/nwk/nwk_api.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.402831300\=\\\#\\r\\n\\\#Thu
/instance/org.eclipse.core.resources/pathvariable.CCS_C2000_5_2_3_CG_ROOT=C\:/Program
Files/Texas Instruments/ccsv4/tools/compiler/c2000
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155/internalBuilder/ignoreErr=true
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/environment/project/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313=<?xml
/instance/org.eclipse.core.resources/pathvariable.CCS_C2000_5_2_1_CG_ROOT=C\:/Program
/project/prjv6/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.Release.203053380/internalBuilder/enabled=false
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885/internalBuilder/ignoreErr=true
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/environment/project/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695=<?xml
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.253557313/internalBuilder/ignoreErr=true
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/environment/project/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883=<?xml
/instance/org.eclipse.core.resources/pathvariable.CCS_MSP430_3_2_1_CG_ROOT=C\:/Program
Files/Texas Instruments/ccsv4/tools/compiler/msp430
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1751283885/internalBuilder/enabled=false
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883/internalBuilder/ignoreErr=true
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/environment/project/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155=<?xml
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673/internalBuilder/enabled=false
/project/prjv6/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.Release.203053380/internalBuilder/ignoreErr=true
@org.eclipse.search=3.2.0.vTI-201102161800
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797/internalBuilder/enabled=false
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1680838883/internalBuilder/enabled=false
/instance/org.eclipse.core.resources/pathvariable.DEV_ROOT=C\:/Texas Instruments/SimpliciTI-CCS-1.1.1
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663/internalBuilder/enabled=false
/instance/org.eclipse.ui.browser/browsers=<?xml
version\="1.0" encoding\="UTF-8"?>\r\n<web-browsers
current\="0">\r\n<system/>\r\n<external
location\="C\:\\Program Files\\Mozilla Firefox\\firefox.exe"
name\="Firefox"/>\r\n<external location\="C\:\\Program
Files\\Internet Explorer\\iexplore.exe" name\="Internet
Explorer"/>\r\n</web-browsers>
/instance/org.eclipse.cdt.managedbuilder.core/properties/Project.com.ti.ccstudio.buildDefinitions.MSP430.executableProjectType.463506595/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673=\#\r\n\#Thu
Jun 23 09\:06\:27 EDT
2011\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Mon
Nov 08 11\\\:49\\\:26 EST
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.ToolchainPlaceholder.639615255\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Applications/application/End\\
Device/main_babble.c\=\\\#\\r\\n\\\#Thu Jun 23 09\\\:06\\\:27 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/nwk_applications/nwk_ping.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.869989221\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/nwk/nwk_globals.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/nwk/nwk.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Applications/application/prj_PIR/prj_sensor.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/nwk_applications/nwk_mgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/nwk/nwk_QMgmt.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.624854187\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889./prj_v4/Applications/application/prj_control/prj_control.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1669903196\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.320216239\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889./prj_v4/Applications/application/End\\
Device/prj_cell.c\=\\\#\\r\\n\\\#Thu Jun 23 09\\\:06\\\:27 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Applications/application/prj_PIR/prj_pir.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1807133437\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1058301919\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1110868047\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Applications/application/prj_mic/prj_mic.c\=\\\#\\r\\n\\\#Mon
2010\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/nwk_applications/nwk_join.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673\=\\\#\\r\\n\\\#Thu
2011\\r\\nrcState\\\=-1\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.952448893\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/nwk_applications/nwk_link.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889./prj_v4/Applications/application/prj_PIR/prj_sensor.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.linkerDebug.442934056\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.411526821\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/nwk_applications/nwk_ioctl.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/nwk_applications/nwk_freq.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889./prj_v4/Applications/application/prj-camera/prj_camera.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1430532076\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/nwk_applications/nwk_security.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/nwk/nwk_api.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Applications/application/prj_control/prj_control.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Applications/application/prj-camera/prj_camera.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1305637427\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1973556795\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/nwk/nwk_frame.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.132719737\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/bsp/bsp.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.735155850\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Components/mrfi/mrfi.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.1014918079\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673./prj_v4/Applications/application/Cell/prj_main.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889./prj_v4/Applications/application/prj_PIR/prj_pir.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1631135267.922695080\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.2091970889./prj_v4/Applications/application/prj_bt_bridge/prj_bt_bridge.c\=\\\#\\r\\n\\\#Thu
Jun 23 09\\\:06\\\:27 EDT 2011\\r\\nrebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/instance/com.ti.ccstudio.ui/CCStudioUIPreferences.IS_NOT_FIRST_CCE_LAUNCH=true
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.437976695/internalBuilder/ignoreErr=true
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1853495663/internalBuilder/ignoreErr=true
/instance/org.eclipse.search/org.eclipse.search.defaultPerspective=org.eclipse.search.defaultPerspective.none
/instance/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.core.cDebug.common_source_containers=<?xml
version\="1.0"
encoding\="UTF-8"?>\r\n<sourceLookupDirector>\r\n<sourceContainers
duplicates\="false"/>\r\n</sourceLookupDirector>\r\n
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=2
@com.ti.ccstudio.ui=4.2.2.201102161800
/instance/org.eclipse.core.resources/pathvariable.CCS_C2000_5_2_8_CG_ROOT=C\:/Program
Tools 5.2.8
/instance/org.eclipse.core.resources/pathvariable.CCS_C2000_5_2_6_CG_ROOT=C\:/Program
Tools 5.2.6
/instance/org.eclipse.cdt.managedbuilder.core/properties/prjv6.com.ti.ccstudio.buildDefinitions.MSP430.ProjectType.1081414322/com.ti.ccstudio.buildDefinitions.MSP430.Release.203053380=\#\r\n\#Thu
Jun 23 09\:06\:28 EDT
2011\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.ReleaseToolchain.1171568427\=\\\#\\r\\n\\\#Thu
Jun 23 09\\\:06\\\:28 EDT
2011\\r\\nrebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Release.ToolchainPlaceholder.1188109975\=\\\#\\r\\n\\\#Wed
Jun 01 12\\\:25\\\:19 EDT
2011\\r\\nrebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.linkerRelease.1564743491\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerRelease.904158821\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Release.203053380\=\\\#\\r\\n\\\#Thu
2011\\r\\nrcState\\\=-1\\r\\nrebuildState\\\=true\\r\\n\r\n
/instance/org.eclipse.core.resources/pathvariable.CCS_MSP430_3_3_3_CG_ROOT=C\:/Program
Tools 3.3.3
/instance/org.eclipse.cdt.managedbuilder.core/properties/prjv6.com.ti.ccstudio.buildDefinitions.MSP430.ProjectType.1081414322/com.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400=\#\r\n\#Thu
2011\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.2.8/src/interfaces/lpc2000_spi.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.2.8/src/regressiontest.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.2.8/src/ioman_v2.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/SWI2C/sw_i2c_tmp100.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.3.6/src/base/ioman_small.c\=\\\#\\r\\n\\\#Wed
Jun 22 15\\\:56\\\:41 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.3.6/examples/avr/avrtest.c\=\\\#\\r\\n\\\#Wed
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.2.8/src/interfaces/lpc2000_dbg_printf.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.2.8/src/interfaces/dsp67xx.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/MMA8450Q/Start08.c\=\\\#\\r\\n\\\#Mon
Jun 06 14\\\:02\\\:24 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/I2C/DMA\\
support/TI_USCI_I2C_master_dma.c\=\\\#\\r\\n\\\#Thu Jun 23
09\\\:06\\\:28 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/MMA8450Q/main.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.2.8/src/interfaces/lpc2000_dbg_printf.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.2.8/src/interfaces/atmega128.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.ToolchainPlaceholder.2085490896\=\\\#\\r\\n\\\#Wed
2011\\r\\nrebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.2.8/src/interfaces/helper.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.linkerDebug.2127460393\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.2.8/src/interfaces/nios2.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.2.8/src/interfaces/linuxfile.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.2.8/src/ioman.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.2.8/src/ioman_v2.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.DebugToolchain.2056620112\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.2.8/src/interfaces/dsp67xx.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/I2C/DMA\\
09\\\:06\\\:28 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.2.8/src/interfaces/atmega128.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.2.8/src/regressiontest.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.3.6/examples/avr/dumpfile.c\=\\\#\\r\\n\\\#Wed
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.3.6/src/base/ioman.c\=\\\#\\r\\n\\\#Wed
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.3.6/src/base/ioman_small.c\=\\\#\\r\\n\\\#Wed
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430_3.2.exe.compilerDebug.1939453634./prjv6/efsl-0.3.6/examples/avr/avrtest.c\=\\\#\\r\\n\\\#Wed
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/MMA8450Q/main.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/MMA8450Q/Start08.c\=\\\#\\r\\n\\\#Mon
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.2.8/src/ioman.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.2.8/src/interfaces/helper.c\=\\\#\\r\\n\\\#Thu
support/main.c\=\\\#\\r\\n\\\#Thu Jun 23 09\\\:06\\\:28 EDT
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.2.8/src/interfaces/linuxfile.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.3.6/src/base/ioman.c\=\\\#\\r\\n\\\#Wed
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/SWI2C/sw_i2c_tmp100.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.2.8/src/interfaces/nios2.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.2.8/src/interfaces/lpc2000_spi.c\=\\\#\\r\\n\\\#Thu
2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP430.Debug.2033062400./prjv6/efsl-0.3.6/examples/avr/dumpfile.c\=\\\#\\r\\n\\\#Wed
/instance/com.ti.ccstudio.debug.ui/com.ti.ccstudio.debug.ui.legacy.LaunchConfigurationMigrator.ran=true
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.1910452797/internalBuilder/ignoreErr=true
@com.ti.ccstudio.debug.core=4.2.2.201102161800
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.938598155/internalBuilder/enabled=false
@com.ti.ccstudio.debug.ui=4.2.2.201102161800
@org.eclipse.ui=3.2.0.vTI-201102161800
@org.eclipse.cdt.managedbuilder.core=3.1.0.vTI-201102161800
/project/prj_v4/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.MSP430.exe.debug.432156673/internalBuilder/ignoreErr=true
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
*** Current Install Configuration:
Install configuration:
Last changed on Jun 23, 2011
Location: file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/configuration/org.eclipse.update/platform.xml
Configured sites:
file:/C:/Program Files/Texas Instruments/bios_5_41_10_36/eclipse/
file:/C:/Program Files/Texas Instruments/bios_5_41_09_34/eclipse/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/
platform:/base/
file:/C:/Program Files/Texas Instruments/bios_6_30_03_46/eclipse/
file:/C:/Program Files/Texas Instruments/ipc_1_21_02_23/eclipse/
Configured features:
ID: com.ti.bios_5.41, Version: 5.41.10.36
ID: org.eclipse.rtsc.xdctools.product.ui, Version: 3.20.6.81
ID: com.ti.ccstudio.emu.5.0.158.1, Version: 5.0.158.1
ID: com.ti.ccstudio.msp430, Version: 4.0.0.201102161800
ID: com.ti.ccstudio.emu.5.0.333.0, Version: 5.0.333.0
ID: com.ti.ccstudio.emu.5.0.104.0, Version: 5.0.104.0
ID: com.ti.bios_5.41, Version: 5.41.0.06
ID: com.ti.bios_6.30, Version: 6.30.0.28
ID: org.eclipse.rtsc.xdctools.product.ui, Version: 3.20.0.41
ID: org.eclipse.cdt, Version: 3.1.0.vTI-201102161800
ID: com.ti.dvt.rov, Version: 2.0.0.201011171816
ID: com.ti.ccstudio.product, Version: 4.2.3.00004
ID: com.bh.ccstudio.emulation, Version: 4.2.1.001
ID: com.ti.dvt.ccstudio, Version: 2.0.0.201011171816
ID: com.ti.ccstudio.c2000, Version: 4.0.0.201102161800
ID: org.eclipse.tm.terminal, Version: 1.0.0.vTI-201102161800
ID: org.eclipse.platform, Version: 3.2.0.vTI-201102161800
ID: com.ti.cgt.msp430.3.3, Version: 3.3.3
ID: com.ti.dvt.profileanalysismanager, Version: 2.0.0.201011171816
ID: com.ti.dvt.via.ccs, Version: 2.0.0.201011171816
ID: com.ti.dvt.analysis, Version: 2.0.0.201011171816
ID: com.ti.dvt.trace.ccs, Version: 2.1.0.201007072025
ID: com.ti.ccstudio.branding, Version: 4.0.0.201102161800
ID: org.eclipse.rcp, Version: 3.2.0.vTI-201102161800
ID: com.sd.ccstudio.emulation, Version: 4.2.2.4
ID: com.ti.ccstudio.rtsc, Version: 4.0.0.201102161800
ID: com.ti.ccstudio.msp430.emu, Version: 4.4.8.3
ID: com.ti.dvt.rta, Version: 2.0.0.201011171816
ID: com.ti.dvt.graph.visualization, Version: 2.0.0.201011171816
ID: com.ti.ipc_1.21, Version: 1.21.0.14
ID: com.ti.dvt.core.ccstudio, Version: 2.0.0.201011171816
ID: com.ti.dvt.scripting.ui, Version: 1.0.0.201007072025
ID: com.ti.cgt.c2000.5.2, Version: 5.2.9
ID: com.ti.sdo.grace.dummy_1.0, Version: 1.0.0.0
ID: com.ti.dvt.control, Version: 2.0.0.201011171816
ID: com.ti.cgt.msp430.3.2, Version: 3.2.3
ID: com.ti.bios_6.30, Version: 6.30.3.46
ID: com.ti.ipc_1.21, Version: 1.21.2.23
Configured plug-ins:
file:/C:/Program Files/Texas Instruments/bios_5_41_10_36/eclipse/plugins/com.ti.bios.rta_5.41.10.36.jar
file:/C:/Program Files/Texas Instruments/bios_5_41_10_36/eclipse/plugins/com.ti.rtsc.DSPBIOS.product.ui_5.41.10.36/
file:/C:/Program Files/Texas Instruments/bios_5_41_10_36/eclipse/plugins/com.ti.rtsc.DSPBIOS.product_5.41.10.36/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/com.ti.dvt.server_3.20.6.81.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/com.ti.rta.support_3.20.6.81.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/com.ti.rta_3.20.6.81.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/com.ti.targets.omf_3.20.6.81/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.project.templates_3.20.6.81.jar
Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.contenttype_3.20.6.81.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.core_3.20.6.81/
Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.model.lang_3.20.6.81.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.model_3.20.6.81.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.product.ui_3.20.6.81/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.product_3.20.6.81/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.rta_3.20.6.81/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.server_3.20.6.81/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.sg.def_3.20.6.81.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.sg_3.20.6.81.jar
Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.ui.contentassist_3.20.6.81.jar
Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.ui.editors_3.20.6.81.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/org.eclipse.rtsc.xdctools.ui_3.20.6.81.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_06_81/eclipse/plugins/xdc.tools.xgconf.modeldata_3.20.6.81.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ibm.icu_3.4.4.1.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.jcraft.jsch_0.1.28.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.apps_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.apps_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.binaryparser_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.binaryparser_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.branding_4.1.0.201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.branding_4.2.2.201102161800/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint.core_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint.core_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint.ui_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint_4.0.0.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_4.1_4.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_4.1_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.0_4.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.0_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.1_4.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.1_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.2_4.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.2_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_6.0_4.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_6.0_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_legacy_4.1.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_legacy_4.1.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.core_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.builddefinitions.generator_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.GNU_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.GNU_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_2.0_4.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_2.0_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.0_4.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.0_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.1_4.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.1_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.2_4.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.2_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.3_4.1.3.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.3_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.4_4.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.4_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_4.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_legacy_4.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_legacy_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.c2000help.doc_4.0.0.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.breakpoint.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.breakpoint.ui_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.cacheview_1.0.0.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.core_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.core_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.memoryserver_4.0.0.201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.memoryserver_4.0.0.201102161800/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.mptv_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.mptv_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.registers.ui_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.registers.ui_4.1.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.server.extensions_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.server.extensions_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.server.factory_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.server.factory_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.core_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.core_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.msp430_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.msp430_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.ui_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.ui.msp430_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.ui.msp430_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.ui_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.device.setup_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.device.setup_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.disassembly.core_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.disassembly.core_4.1.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.disassembly.ui_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.disassembly.ui_4.1.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.errorparser_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.errorparser_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.gelhelp.doc_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.gelhelp.doc_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.jline_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.jline_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.mainhelp.doc_4.0.0.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.managedbuild.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.managedbuild.core_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.managedbuild.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.managedbuild.ui_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.marker_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.marker_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.memory.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.memory.ui_4.0.0.201102161800.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.multi.purpose.view.contributors_4.1.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.multi.purpose.view.contributors_4.1.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.multi.purpose.view_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.multi.purpose.view_4.2.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.osgi_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.osgi_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.pinconnect_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.pinconnect_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.pinport.common_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.pinport.common_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.portconnect_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.portconnect_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.product.paths_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.product.paths_4.1.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.profile.setup.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.profile.setup.ui_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.profile.setup_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.profile.setup_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.core_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.templates_4.2.0.201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.templates_4.2.0.201102161800/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.ui_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.rhino_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.rhino_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.console_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.console_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.dss_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.dss_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.environment_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.environment_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.gss_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.gss_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.ui_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.hotmenu_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.hotmenu_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.setup.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.setup.ui_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.setup_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.setup_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.trace.control_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.trace.control_4.1.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui.cheatsheets_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui.cheatsheets_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui.forms_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui.forms_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.update_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.update_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.useaccess_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.useaccess_4.0.0.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.core_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.managedbuild.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.managedbuild.core_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.managedbuild.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.managedbuild.ui_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.project.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.project.core_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.project.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.project.ui_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.ui_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.ui_4.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.update.discovery_4.1.1.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.update.discovery_4.1.1.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.analysis.framework_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.analysis.framework_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.cceideadapter_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.cceideadapter_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ccesymbolmanager_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ccesymbolmanager_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.codegenCoverage_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.codegenCoverage_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.control.engine_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.control.engine_2.0.0.201011171816/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.control.gui_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.control.gui_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.coverageplugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.coverageplugin_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.datamodel_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.datamodel_2.0.0.201011171816/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization.doc_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization.doc_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.gridview_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.gridview_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ideadapterplugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ideadapterplugin_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ideadapter_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ideadapter_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ofssymbolmanager_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ofssymbolmanager_2.0.0.201011171816/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysis.doc_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysis.doc_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanagerplugin_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanagerplugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanagerplugin_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanager_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanager_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanager_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysis_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysis_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profiledata_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profiledata_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rovsupport.doc_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rovsupport.doc_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rovsupport_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rovsupport_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.doc_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.doc_2.0.0.201011171816/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.interfaces_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.interfaces_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.interfaces_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.scripting.ui_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.scripting.ui_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.sourcerefplugin_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.sourcerefplugin_2.0.0.201011171816/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.sourceref_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.sourceref_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.symbolmanagerplugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.symbolmanagerplugin_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.symbolmanager_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.symbolmanager_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.tidisassembly_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.tidisassembly_2.0.0.201011171816/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.trace.doc_1.1.0.201007072025/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.trace.doc_2.0.0.201011171816/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.trace_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.trace_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ui.doc_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ui.doc_2.0.0.201011171816/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ui_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ui_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.doc_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.doc_2.0.0.201011171816/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.imvr_1.0.0.201007072025.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.imvr_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.imvr_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.plugin.ccs_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.plugin.ccs_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.plugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.plugin_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.fnc_4.0.0.201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.fnc_4.0.0.201102161800/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.util.ui_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.util.ui_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.util_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.util_2.0.0.201011171816.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.apache.ant_1.6.5/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.apache.lucene_1.4.103.v20060601/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ant.core_3.1.100.v20060531.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.core.win32_3.1.0.200606261600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.core_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.core_3.1.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.core_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.core_3.1.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.mi.core_3.1.0.200606261600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.mi.ui_3.1.0.200606261600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.ui_3.1.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.launch_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.launch_3.1.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.make.core_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.make.core_3.1.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.make.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.make.ui_3.1.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.core_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.core_3.1.0.vTI-201102161800.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.gnu.ui_3.1.0.vTI-201010201600.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.gnu.ui_3.1.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.ui_3.1.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.refactoring_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.refactoring_3.1.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.ui_3.1.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt_3.1.0.200606261600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.compare_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.compare_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.boot_3.1.100.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.commands_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.contenttype_3.2.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.expressions_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.filebuffers_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.filesystem.win32.x86_1.0.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.filesystem_1.0.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.jobs_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.jobs_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources.compatibility_3.2.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources.win32_3.2.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime.compatibility.auth_3.2.0.v20060601.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime.compatibility.registry_3.2.0.v20060603/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime.compatibility_3.1.100.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.variables_3.1.100.v20060605.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.dd.debug.memory.renderings.traditional_1.0.0.vTI-201010201600.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.dd.debug.memory.renderings.traditional_1.0.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.debug.core_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.debug.core_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.debug.ui_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.debug.ui_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.draw2d_3.2.0.v20060626.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.vTI-201005061800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.vTI-201008051800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.vTI-201008091000.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.preferences_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.registry_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.gef_3.2.0.v20060626.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.appserver_3.1.100.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.base_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.ui_3.2.0.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.webapp_3.2.0.v20060602/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help_3.2.0.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface.databinding_1.0.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface.text_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface.text_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ltk.core.refactoring_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi.services_3.1.100.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi.util_3.1.100.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.pde.runtime_3.2.0.v20060605.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.platform_3.2.0.vTI-201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.platform_3.2.0.vTI-201102161800/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rcp_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rcp_3.2.0.vTI-201102161800.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_1.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_1.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31_1.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31_1.2.0.201102161800.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40_1.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40_1.2.0.201102161800.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_6.00_1.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_1.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_1.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00_1.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00_1.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10_1.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10_1.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15_1.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15_1.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16_1.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16_1.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.managedbuild.core_1.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.managedbuild.core_1.2.2.201102161800.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.managedbuild.ui_1.2.0.201010201600.jar
Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.managedbuild.ui_1.2.2.201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.search_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.search_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.swt.win32.win32.x86_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.swt.win32.win32.x86_3.4.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.swt_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.swt_3.4.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.core_3.2.0.I200606051140.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.core_3.2.0.M20060628.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.2.0.I200606051140.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.ssh_3.2.0.I200606011710.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.ui_3.2.0.I200606051140.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.ui_3.2.0.I200606051140.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.text_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal.serial_1.0.0.v20070605.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal.view_1.0.0.v20070620.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal_1.0.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal_1.0.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tomcat_4.1.130.v20060601/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.browser_3.2.0.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.cheatsheets_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.cheatsheets_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.console_3.1.100.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.console_3.1.100.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.editors_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.editors_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.externaltools_3.1.100.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.externaltools_3.1.100.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.forms_3.2.0.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.ide_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.ide_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.intro.universal_3.2.0.v20060602/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.intro_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.navigator.resources_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.navigator_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.presentations.r21_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.views.properties.tabbed_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.views_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.views_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.win32_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I20060605-1400/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.configurator_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.configurator_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.core.win32_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.core.win32_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.core_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.core_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.scheduler_3.2.0.v20060605.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.ui_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.ui_3.2.0.vTI-201102161800.jar
file:/C:/Program Files/Texas Instruments/bios_6_30_03_46/eclipse/plugins/com.ti.rtsc.SYSBIOS.product.ui_6.30.3.46/
file:/C:/Program Files/Texas Instruments/bios_6_30_03_46/eclipse/plugins/com.ti.rtsc.SYSBIOS.product_6.30.3.46/
file:/C:/Program Files/Texas Instruments/ipc_1_21_02_23/eclipse/plugins/com.ti.rtsc.IPC.product.ui_1.21.2.23/
file:/C:/Program Files/Texas Instruments/ipc_1_21_02_23/eclipse/plugins/com.ti.rtsc.IPC.product_1.21.2.23/
