Could not update CCS ver.: 12.1.0.00007 to ver. 12.02. Update stops with error message:
Available SW sites:
Dimitar
Available SW sites:
Dimitar
Hello Dimitar,
I checked the status of the update on the server and that appears to be functioning. I was able to update CCS 12.1.0 to CCS 12.2.0 successfully without issue. Hence the issue must be something specific to your environment. Please try again and if the issue again occurs, you can take a look at section 9.3.5 of the troubleshooting chapter:
If none of the suggestions there helps, there is always the option to do a full clean install of CCS 12.2. If you follow this route, my apologies for the inconvenience for the incremental update failure.
ki
