Code Composer Studio hangs with BlackHawk BH-LAN-560 emulator since rev 12.2
Other Parts Discussed in Thread: OMAP-L138
Since at least revision 12.2 of Code Composer Studio (ie 12.2 & 12.3) in Windows 10 using BlackHawk BH-LAN-560 emulator, the connect command to my OMAP-L138 DSP hangs (when switched to debug mode, emulator is detected; it hangs only when "connect" debug command is triggered).
When using back rev 12.0, all is fine. Same workspace & project files are used in all cases.
Any idea ?
    This is a known issue. There was a change made to a file in CCSv12.1.0 that impacted XDS560v1 probes.
    To be frank, XDS560v1 based probes are no longer officially supported. TI XDS560v1 support has been completely removed in 12.3. We are working with Blackhawk to have it removed for Blackhawk probes in future releases.
    I would recommend staying with 12.0 if you wish to continue to use your BH XDS560v1 based probe.
    ki
  • Hello Ki,
    Thanks for your ultrafast answer.
