Part Number: CODECOMPOSER
Other Parts Discussed in Thread: CCSTUDIO
Hi e2e community,
I've been having issues with unattended mode (and even text mode) installation with CCS. I've tried the 5 latest versions (11.2 -> 12.3). I'm trying to install on Docker starting with Ubuntu 22.04 as the base image. All pre-reqs are installed as per details defined in https://software-dl.ti.com/ccs/esd/documents/ccsv12_linux_host_support.html
I see some documentation out there for older versions of CCStudio working for some people in docker containers, but those are not known to work with our SimpleLink or TI gcc toolchains. I do not see any examples out there for docker images for CCStudio newer than version 9.
After every attempt to install via command line, this is the response:
Error: There has been an error.
Text mode is not supported. Please set your display and run the installer again.
TIA,
Seth
