Currently I am using breakpoint triggered file input in order to set up my test conditions every SW cycle. With the TI-Format dat file however, it appears that I can only insert values for the entire data type (i.e. hex, integer, long, float). What I would like to do (specifically for the hex data input type), is apply a masking operation to the values being input so that certain cycles I can affect only specific bits, and others none at all. Is this possible? It doesn't appear to be, however I thought I'd best check with the experts before giving up!
Joshua
