In CCS12.x I see following error:
Because of this may be I am not able to get the proper sysconfig UI
Any suggestions ?
Any suggestions ?
Hi this occur when
1. Open the sysconfig file
2. Open CCS App Centre
Best Regards, Shiv
I am using Version: 12.2.0.00009 and Version: 12.3.0.00005.
With versions I see the problem.
Best Regards, Shiv
Please note that there is an (unrelated) known issue with the App Center in CCS 12.3.0. We are working to resolve this.
There should be no issue with 12.2.0 however. Does the issue only occur when opening up App Center?
Also try the troubleshooting steps in section 9.4.2 and 9.4.3 of the User's Guide:
https://software-dl.ti.com/ccs/esd/documents/users_guide/ccs_troubleshooting.html#general-ide
ki
Hi this occur when
And I did check above troubleshoot, that is not helping.
Best Regards, Shiv
Just to confirm, If you skip step 2 (opening app center), there is no problem?
Can you share the project and sysconfig file? You can remove all other source files (besides syscfg file) from the project if you wish.
