CCS newest version fail on update.
When I try to update I get:
The link it tries to go in https://software-dl.ti.com but the resource gets a 302 moved response, directing to https://downloads.ti.com and the resource does not exist at that adress.
This is not a bug, but probably admin changed some settings at the repo end.
C.
  • Hi Can,
      I will forward your question to our CCS team.
  • Hi Can, could you confirm you are using CCS 12.0.0 when you do the check for updates?  For some reason I do not see this issue.
  • Hello AndyW;
    I am using Version: 12.5.0.00007, which is the latest I downloaded recently.
    Here is a screenshot of both errors:
    When you try to update, it fails saying "cannot complete the install because of a conflicting dependency" and when you click details, a second window pops up, saying "no repository found at https://software-dl.ti.com/ccs/esd/CCSv12/Updates/CCS12.0.0.00009_update"
    I took the liberty of checking the resource above with wget, and here is the response:
    wget https://software-dl.ti.com/ccs/esd/CCSv12/Updates/CCS12.0.0.00009_update
    --2023-10-09 18:42:45--  https://software-dl.ti.com/ccs/esd/CCSv12/Updates/CCS12.0.0.00009_update
    Resolving software-dl.ti.com (software-dl.ti.com)... 23.45.237.63, 2a02:26f0:9700:193::b48, 2a02:26f0:9700:181::b48
    Connecting to software-dl.ti.com (software-dl.ti.com)|23.45.237.63|:443... connected.
    HTTP request sent, awaiting response... 302 Moved Temporarily
    Location: https://downloads.ti.com/ccs/esd/CCSv12/Updates/CCS12.0.0.00009_update [following]
    --2023-10-09 18:42:45--  https://downloads.ti.com/ccs/esd/CCSv12/Updates/CCS12.0.0.00009_update
    Resolving downloads.ti.com (downloads.ti.com)... 23.45.237.63
    Connecting to downloads.ti.com (downloads.ti.com)|23.45.237.63|:443... connected.
    HTTP request sent, awaiting response... 404 Not Found
    2023-10-09 18:42:48 ERROR 404: Not Found.
    wget software-dl.ti.com/.../CCS12.0.0.00009_update
    --2023-10-09 18:42:45--  software-dl.ti.com/.../CCS12.0.0.00009_update
    Location: downloads.ti.com/.../CCS12.0.0.00009_update [following]
    --2023-10-09 18:42:45--  downloads.ti.com/.../CCS12.0.0.00009_update
    I think this is not a CCS error, but a problem with the distribution system for updates. as you see, when you request the resource in question,  it gets a 302 moved temp response, and the new resource it points to (https://downloads.ti.com....) does not have this resource. It could be a web server misconfiguration, router misconfiguration, or some problem with the underlying content distribution network. It could also be the case that, depending on where you are on the internet*, it could be returning these 302's. Then again, I could be wrong, and it might be a CCS issue.
    * [I checked from server in germany, and it had the same results]
    -C.A.
  • Thank you for your observations.  I'm still not sure why I don't see the same issue, but I did clear up a potential server side cache and syncing issue.  Would you be able to give it another try and let me know if this helped?
