A minor GUI problem best illustrated. As the memory allocation fills up, it looks like the green fill bar masks digit(s) of the available units. In this case "1," is missing:
Can you access the below?
If not, do you have issue with other the TI sites like: https://dev.ti.com/ ?
https://sir.ext.ti.com/ : No access.
TI Developer Zone : Access is OK here.
Can you try again?
Yes that works now, thanks. However, I noticed that the rendering isn't quite right when I get redirected here: sir.ext.ti.com/.../Dashboard.jspa
I checked this in both Chrome and Edge.
I see this issue also so it looks like a wide spread issue. I'll let IT know.
The direct links work ok though: https://sir.ext.ti.com/jira/browse/EXT_EP-11477
