I am getting the following link error -- "Conflicting architecture profiles M/A" for each object in my linker command, which I've included. I am using the following
compile command: (for a single module -- til.c). The same command is used for all object files.
Can you give me any clue on what I'm doing wrong. Thank you.
/root/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueabi-g++ \
-Wl,-Map,cesl_TI_Agent.map -mcpu=cortex-m3 -mthumb -g3 -gdwarf-2 -o"cesl_TI_Agent.elf" \
ld command: (for all modules successfully compiled with above switches)
./usr/local/cesl/src/til/src/til.o ./usr/local/cesl/src/til/src/til_callback.o ./usr/local/cesl/src/til/src/til_internal.o ./usr/local/cesl/src/shims/Tcp/TcpShim/src/TcpShim.o ./usr/local/cesl/src/refdesign/VASCManager/src/AgentDeviceInfo.o ./usr/local/cesl/src/refdesign/VASCManager/src/VASCManagerExample.o ./usr/local/cesl/src/refdesign/VASCManager/src/VASCMeasurement.o ./usr/local/cesl/src/refdesign/BloodPressureMonitorAgent/AgentRefDesign.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascAgentBloodPressure.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascAgentCardiovascular.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascAgentGlucoseMeter.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascAgentLivingHub.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascAgentMedMonitor.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascAgentPMStore.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascAgentPulseOxim.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascAgentPulseOximWithScanner.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascAgentSpecialization.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascAgentStrengthFitness.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascAgentThermometer.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascAgentWeightScale.o ./usr/local/cesl/src/refdesign/AgentSpecializations/src/VascCommandLine.o ./usr/local/cesl/src/object/src/VascAccumulator.o ./usr/local/cesl/src/object/src/VascAgent.o ./usr/local/cesl/src/object/src/VascAsnHelper.o ./usr/local/cesl/src/object/src/VascAttribute.o ./usr/local/cesl/src/object/src/VascAttributeHelper.o ./usr/local/cesl/src/object/src/VascAttributeList.o ./usr/local/cesl/src/object/src/VascDIM.o ./usr/local/cesl/src/object/src/VascDataProtoType.o ./usr/local/cesl/src/object/src/VascDevice.o ./usr/local/cesl/src/object/src/VascEpiCfgScanner.o ./usr/local/cesl/src/object/src/VascException.o ./usr/local/cesl/src/object/src/VascFloat.o ./usr/local/cesl/src/object/src/VascGuard.o ./usr/local/cesl/src/object/src/VascManager.o ./usr/local/cesl/src/object/src/VascMessageFactory.o ./usr/local/cesl/src/object/src/VascObject.o ./usr/local/cesl/src/object/src/VascPMSegment.o ./usr/local/cesl/src/object/src/VascPMStore.o ./usr/local/cesl/src/object/src/VascPeriCfgScanner.o ./usr/local/cesl/src/object/src/VascPermanentDataStore.o ./usr/local/cesl/src/object/src/VascScan.o ./usr/local/cesl/src/object/src/VascScanner.o ./usr/local/cesl/src/object/src/VascSerialization.o ./usr/local/cesl/src/object/src/VascStore.o ./usr/local/cesl/src/object/src/VascTestObject.o ./usr/local/cesl/src/object/src/VascTimer.o ./usr/local/cesl/src/association/src/AgentFSM.o ./usr/local/cesl/src/association/src/Associate.o ./usr/local/cesl/src/association/src/AssociateMessages.o ./usr/local/cesl/src/association/src/AssociateQueue.o ./usr/local/cesl/src/association/src/ManagerFSM.o ./usr/local/cesl/src/VASCTrace/src/vasc.o ./usr/local/cesl/src/TransportAPI/src/TransportAPI.o ./usr/local/cesl/src/TransportAPI/src/eventProcessingThread.o ./usr/local/cesl/src/Service/src/VascService.o ./usr/local/cesl/src/MessageModule/src/VascActionPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascApduImpl.o ./usr/local/cesl/src/MessageModule/src/VascAssociationAbortApdu.o ./usr/local/cesl/src/MessageModule/src/VascAssociationApdu.o ./usr/local/cesl/src/MessageModule/src/VascAssociationReleaseRequestApdu.o ./usr/local/cesl/src/MessageModule/src/VascAssociationReleaseResponseApdu.o ./usr/local/cesl/src/MessageModule/src/VascAssociationRequestApdu.o ./usr/local/cesl/src/MessageModule/src/VascAssociationResponseApdu.o ./usr/local/cesl/src/MessageModule/src/VascEventReportPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascPresentationApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoerPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivClearSegmentsActionPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivClearSegmentsAllActionPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivClearSegmentsByInstanceIdActionPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivClearSegmentsByTimeActionPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivConfigReportPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivGetPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivGetSegmentInfoActionPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivGetSegmentInfoAllActionPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivGetSegmentInfoByInstanceIdActionPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivGetSegmentInfoByTimeActionPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivScanReportInfoFixedPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivScanReportInfoGroupedPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivScanReportInfoMPFixedPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivScanReportInfoMPGroupedPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivScanReportInfoMPVarPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivScanReportInfoVarPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivScanReportPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivSegmentDataEventPrstApdu.o ./usr/local/cesl/src/MessageModule/src/VascRoivSetArgumentSimplePrstApdu.o ./usr/local/cesl/src/MessageModule/src/VasctApdu.o ./usr/local/cesl/src/MessageModule/src/VascRorsTrigSegmDataXferRspActionPrstApdu.o ./usr/local/cesl/src/ASN1/src/ANY.o ./usr/local/cesl/src/ASN1/src/ASN1CSupport.o ./usr/local/cesl/src/ASN1/src/AVA-Type.o ./usr/local/cesl/src/ASN1/src/AareApdu.o ./usr/local/cesl/src/ASN1/src/AarqApdu.o ./usr/local/cesl/src/ASN1/src/Abort-reason.o ./usr/local/cesl/src/ASN1/src/AbrtApdu.o ./usr/local/cesl/src/ASN1/src/AbsTimeRange.o ./usr/local/cesl/src/ASN1/src/AbsoluteTime.o ./usr/local/cesl/src/ASN1/src/AbsoluteTimeAdjust.o ./usr/local/cesl/src/ASN1/src/ActionArgumentSimple.o ./usr/local/cesl/src/ASN1/src/ActionResultSimple.o ./usr/local/cesl/src/ASN1/src/AlertOpTextString.o ./usr/local/cesl/src/ASN1/src/ApduType.o ./usr/local/cesl/src/ASN1/src/AssociateResult.o ./usr/local/cesl/src/ASN1/src/AssociationVersion.o ./usr/local/cesl/src/ASN1/src/AttrValMap.o ./usr/local/cesl/src/ASN1/src/AttrValMapEntry.o ./usr/local/cesl/src/ASN1/src/AttributeIdList.o ./usr/local/cesl/src/ASN1/src/AttributeList.o ./usr/local/cesl/src/ASN1/src/AttributeModEntry.o ./usr/local/cesl/src/ASN1/src/AuthBody.o ./usr/local/cesl/src/ASN1/src/AuthBodyAndStrucType.o ./usr/local/cesl/src/ASN1/src/AuthBodyStrucType.o ./usr/local/cesl/src/ASN1/src/BITS-16.o ./usr/local/cesl/src/ASN1/src/BITS-32.o ./usr/local/cesl/src/ASN1/src/BIT_STRING.o ./usr/local/cesl/src/ASN1/src/BasicNuObsValue.o ./usr/local/cesl/src/ASN1/src/BasicNuObsValueCmp.o ./usr/local/cesl/src/ASN1/src/BatMeasure.o ./usr/local/cesl/src/ASN1/src/CertifiedDeviceClassEntry.o ./usr/local/cesl/src/ASN1/src/CertifiedDeviceClassList.o ./usr/local/cesl/src/ASN1/src/ConfigId.o ./usr/local/cesl/src/ASN1/src/ConfigObject.o ./usr/local/cesl/src/ASN1/src/ConfigObjectList.o ./usr/local/cesl/src/ASN1/src/ConfigReport.o ./usr/local/cesl/src/ASN1/src/ConfigReportRsp.o ./usr/local/cesl/src/ASN1/src/ConfigResult.o ./usr/local/cesl/src/ASN1/src/ConfirmMode.o ./usr/local/cesl/src/ASN1/src/ContinuaBodyStruct.o ./usr/local/cesl/src/ASN1/src/ContinuaRegStruct.o ./usr/local/cesl/src/ASN1/src/ContinuaStructType.o ./usr/local/cesl/src/ASN1/src/CurLimAlStat.o ./usr/local/cesl/src/ASN1/src/CurLimAlVal.o ./usr/local/cesl/src/ASN1/src/DataApdu.o ./usr/local/cesl/src/ASN1/src/DataProto.o ./usr/local/cesl/src/ASN1/src/DataProtoId.o ./usr/local/cesl/src/ASN1/src/DataProtoList.o ./usr/local/cesl/src/ASN1/src/DataReqId.o ./usr/local/cesl/src/ASN1/src/DataReqMode.o ./usr/local/cesl/src/ASN1/src/DataReqModeCapab.o ./usr/local/cesl/src/ASN1/src/DataReqModeFlags.o ./usr/local/cesl/src/ASN1/src/DataReqResult.o ./usr/local/cesl/src/ASN1/src/DataRequest.o ./usr/local/cesl/src/ASN1/src/DataResponse.o ./usr/local/cesl/src/ASN1/src/EncodingRules.o ./usr/local/cesl/src/ASN1/src/EnumObsValue.o ./usr/local/cesl/src/ASN1/src/EnumPrintableString.o ./usr/local/cesl/src/ASN1/src/EnumVal.o ./usr/local/cesl/src/ASN1/src/ErrorResult.o ./usr/local/cesl/src/ASN1/src/EventReportArgumentSimple.o ./usr/local/cesl/src/ASN1/src/EventReportResultSimple.o ./usr/local/cesl/src/ASN1/src/FLOAT-Type.o ./usr/local/cesl/src/ASN1/src/FunctionalUnits.o ./usr/local/cesl/src/ASN1/src/GetArgumentSimple.o ./usr/local/cesl/src/ASN1/src/GetResultSimple.o ./usr/local/cesl/src/ASN1/src/HANDLE.o ./usr/local/cesl/src/ASN1/src/HANDLEList.o ./usr/local/cesl/src/ASN1/src/HandleAttrValMap.o ./usr/local/cesl/src/ASN1/src/HandleAttrValMapEntry.o ./usr/local/cesl/src/ASN1/src/HighResRelativeTime.o ./usr/local/cesl/src/ASN1/src/INT-I16.o ./usr/local/cesl/src/ASN1/src/INT-I32.o ./usr/local/cesl/src/ASN1/src/INT-I8.o ./usr/local/cesl/src/ASN1/src/INT-U16.o ./usr/local/cesl/src/ASN1/src/INT-U32.o ./usr/local/cesl/src/ASN1/src/INT-U8.o ./usr/local/cesl/src/ASN1/src/INTEGER.o ./usr/local/cesl/src/ASN1/src/InstNumber.o ./usr/local/cesl/src/ASN1/src/InvokeIDType.o ./usr/local/cesl/src/ASN1/src/ManufSpecAssociationInformation.o ./usr/local/cesl/src/ASN1/src/MdsTimeCapState.o ./usr/local/cesl/src/ASN1/src/MdsTimeInfo.o ./usr/local/cesl/src/ASN1/src/MeasurementStatus.o ./usr/local/cesl/src/ASN1/src/MetricIdList.o ./usr/local/cesl/src/ASN1/src/MetricSpecSmall.o ./usr/local/cesl/src/ASN1/src/MetricStructureSmall.o ./usr/local/cesl/src/ASN1/src/ModificationList.o ./usr/local/cesl/src/ASN1/src/ModifyOperator.o ./usr/local/cesl/src/ASN1/src/NativeEnumerated.o ./usr/local/cesl/src/ASN1/src/NativeInteger.o ./usr/local/cesl/src/ASN1/src/NomPartition.o ./usr/local/cesl/src/ASN1/src/NomenclatureVersion.o ./usr/local/cesl/src/ASN1/src/NuObsValue.o ./usr/local/cesl/src/ASN1/src/NuObsValueCmp.o ./usr/local/cesl/src/ASN1/src/OCTET_STRING.o ./usr/local/cesl/src/ASN1/src/OID-Type.o ./usr/local/cesl/src/ASN1/src/ObservationScan.o ./usr/local/cesl/src/ASN1/src/ObservationScanFixed.o ./usr/local/cesl/src/ASN1/src/ObservationScanGrouped.o ./usr/local/cesl/src/ASN1/src/OperationalState.o ./usr/local/cesl/src/ASN1/src/PersonId.o ./usr/local/cesl/src/ASN1/src/PhdAssociationInformation.o ./usr/local/cesl/src/ASN1/src/PmSegmentEntryMap.o ./usr/local/cesl/src/ASN1/src/PmStoreCapab.o ./usr/local/cesl/src/ASN1/src/PowerStatus.o ./usr/local/cesl/src/ASN1/src/PrivateOid.o ./usr/local/cesl/src/ASN1/src/ProdSpecEntry.o ./usr/local/cesl/src/ASN1/src/ProductionSpec.o ./usr/local/cesl/src/ASN1/src/ProtocolVersion.o ./usr/local/cesl/src/ASN1/src/PrstApdu.o ./usr/local/cesl/src/ASN1/src/RegCertData.o ./usr/local/cesl/src/ASN1/src/RegCertDataList.o ./usr/local/cesl/src/ASN1/src/RegulationBitFieldType.o ./usr/local/cesl/src/ASN1/src/RejectResult.o ./usr/local/cesl/src/ASN1/src/RelativeTime.o ./usr/local/cesl/src/ASN1/src/ReleaseRequestReason.o ./usr/local/cesl/src/ASN1/src/ReleaseResponseReason.o ./usr/local/cesl/src/ASN1/src/RlreApdu.o ./usr/local/cesl/src/ASN1/src/RlrqApdu.o ./usr/local/cesl/src/ASN1/src/RoerErrorValue.o ./usr/local/cesl/src/ASN1/src/RorjProblem.o ./usr/local/cesl/src/ASN1/src/SFLOAT-Type.o ./usr/local/cesl/src/ASN1/src/SaFlags.o ./usr/local/cesl/src/ASN1/src/SaSpec.o ./usr/local/cesl/src/ASN1/src/SampleType.o ./usr/local/cesl/src/ASN1/src/ScaleRangeSpec16.o ./usr/local/cesl/src/ASN1/src/ScaleRangeSpec32.o ./usr/local/cesl/src/ASN1/src/ScaleRangeSpec8.o ./usr/local/cesl/src/ASN1/src/ScanReportInfoFixed.o ./usr/local/cesl/src/ASN1/src/ScanReportInfoGrouped.o ./usr/local/cesl/src/ASN1/src/ScanReportInfoMPFixed.o ./usr/local/cesl/src/ASN1/src/ScanReportInfoMPGrouped.o ./usr/local/cesl/src/ASN1/src/ScanReportInfoMPVar.o ./usr/local/cesl/src/ASN1/src/ScanReportInfoVar.o ./usr/local/cesl/src/ASN1/src/ScanReportPerFixed.o ./usr/local/cesl/src/ASN1/src/ScanReportPerGrouped.o ./usr/local/cesl/src/ASN1/src/ScanReportPerVar.o ./usr/local/cesl/src/ASN1/src/SegmDataEventDescr.o ./usr/local/cesl/src/ASN1/src/SegmEntryElem.o ./usr/local/cesl/src/ASN1/src/SegmEntryElemList.o ./usr/local/cesl/src/ASN1/src/SegmEntryHeader.o ./usr/local/cesl/src/ASN1/src/SegmEvtStatus.o ./usr/local/cesl/src/ASN1/src/SegmIdList.o ./usr/local/cesl/src/ASN1/src/SegmSelection.o ./usr/local/cesl/src/ASN1/src/SegmStatType.o ./usr/local/cesl/src/ASN1/src/SegmentDataEvent.o ./usr/local/cesl/src/ASN1/src/SegmentDataResult.o ./usr/local/cesl/src/ASN1/src/SegmentInfo.o ./usr/local/cesl/src/ASN1/src/SegmentInfoList.o ./usr/local/cesl/src/ASN1/src/SegmentStatisticEntry.o ./usr/local/cesl/src/ASN1/src/SegmentStatistics.o ./usr/local/cesl/src/ASN1/src/SetArgumentSimple.o ./usr/local/cesl/src/ASN1/src/SetResultSimple.o ./usr/local/cesl/src/ASN1/src/SetTimeInvoke.o ./usr/local/cesl/src/ASN1/src/SimpleNuObsValue.o ./usr/local/cesl/src/ASN1/src/SimpleNuObsValueCmp.o ./usr/local/cesl/src/ASN1/src/StoSampleAlg.o ./usr/local/cesl/src/ASN1/src/SupplementalTypeList.o ./usr/local/cesl/src/ASN1/src/SystemModel.o ./usr/local/cesl/src/ASN1/src/SystemType.o ./usr/local/cesl/src/ASN1/src/TYPE.o ./usr/local/cesl/src/ASN1/src/TimeProtocolId.o ./usr/local/cesl/src/ASN1/src/TrigSegmDataXferReq.o ./usr/local/cesl/src/ASN1/src/TrigSegmDataXferRsp.o ./usr/local/cesl/src/ASN1/src/TrigSegmXferRsp.o ./usr/local/cesl/src/ASN1/src/TypeVer.o ./usr/local/cesl/src/ASN1/src/TypeVerList.o ./usr/local/cesl/src/ASN1/src/UuidIdent.o ./usr/local/cesl/src/ASN1/src/asn_SEQUENCE_OF.o ./usr/local/cesl/src/ASN1/src/asn_SET_OF.o ./usr/local/cesl/src/ASN1/src/asn_codecs_prim.o ./usr/local/cesl/src/ASN1/src/ber_decoder.o ./usr/local/cesl/src/ASN1/src/ber_tlv_length.o ./usr/local/cesl/src/ASN1/src/ber_tlv_tag.o ./usr/local/cesl/src/ASN1/src/constr_CHOICE.o ./usr/local/cesl/src/ASN1/src/constr_SEQUENCE.o ./usr/local/cesl/src/ASN1/src/constr_SEQUENCE_OF.o ./usr/local/cesl/src/ASN1/src/constr_SET_OF.o ./usr/local/cesl/src/ASN1/src/constr_TYPE.o ./usr/local/cesl/src/ASN1/src/constraints.o ./usr/local/cesl/src/ASN1/src/der_encoder.o ./usr/local/cesl/src/ASN1/src/per_decoder.o ./usr/local/cesl/src/ASN1/src/per_encoder.o ./usr/local/cesl/src/ASN1/src/per_support.o ./usr/local/cesl/src/ASN1/src/xer_decoder.o ./usr/local/cesl/src/ASN1/src/xer_encoder.o ./usr/local/cesl/src/ASN1/src/xer_support.o
