Unable to create this part due to an internal error. Reason for the failure: java.io.FileNotFoundException (The system cannot find the path specified)
Every time I try to open definition of a function on CCS 4 I get this error.
From what I understand here, its because I m using a workspace from a different PC (C:\Users\Supriya\Desktop). How can I change the path below?
Details>>
java.io.FileNotFoundException: C:\Users\Supriya\Desktop\Sandeep\Debug\Digitrapper 10 12 - Copy\pH test 10ms test 2\src\splitHw.c (The system cannot find the path specified)
    at java.io.FileInputStream.open(Native Method)
    at java.io.FileInputStream.<init>(Unknown Source)
    at org.eclipse.cdt.core.resources.FileStorage.getContents(FileStorage.java:38)
    at org.eclipse.ui.editors.text.StorageDocumentProvider.setDocumentContent(StorageDocumentProvider.java:191)
    at org.eclipse.ui.editors.text.FileDocumentProvider.setDocumentContent(FileDocumentProvider.java:426)
    at org.eclipse.ui.editors.text.StorageDocumentProvider.createDocument(StorageDocumentProvider.java:228)
    at org.eclipse.cdt.internal.ui.editor.ExternalSearchDocumentProvider.createDocument(ExternalSearchDocumentProvider.java:86)
    at org.eclipse.cdt.internal.ui.editor.ExternalSearchDocumentProvider.createElementInfo(ExternalSearchDocumentProvider.java:40)
    at org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(AbstractDocumentProvider.java:398)
    at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:3077)
    at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:173)
    at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1513)
    at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:182)
    at org.eclipse.cdt.internal.ui.editor.CEditor.doSetInput(CEditor.java:252)
    at org.eclipse.ui.texteditor.AbstractTextEditor$17.run(AbstractTextEditor.java:2410)
    at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:369)
    at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:313)
    at org.eclipse.jface.window.ApplicationWindow$1.run(ApplicationWindow.java:763)
    at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
    at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWindow.java:760)
    at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2296)
    at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:2428)
    at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:2455)
    at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:839)
    at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:583)
    at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:372)
    at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:566)
    at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:214)
    at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2588)
    at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2521)
    at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPage.java:2513)
    at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.java:2498)
    at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2493)
    at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2470)
    at org.eclipse.cdt.internal.ui.search.actions.SelectionParseAction.open(SelectionParseAction.java:548)
    at org.eclipse.cdt.internal.ui.search.actions.OpenDefinitionAction$Runner$1.run(OpenDefinitionAction.java:76)
    at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:123)
    at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3325)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2971)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1914)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:419)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
    at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:97)
    at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
    at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
    at org.eclipse.core.launcher.Main.run(Main.java:996)
    at org.eclipse.core.launcher.Main.main(Main.java:971)
