What's wrong with GUI Composer?
I had not used it in a few months, and I logged back in today, and it looks like it's broken:
Windows 11 22H2 PC, Google Chrome 121.0.6167.189
  • I just tried this on slightly newer Windows 11 and Chrome versions and all seemed fine with me. Can you try a different browser? Or try cleaning the your browser cache?
    I just tried with Edge on the same PC, and it seems to work.  It still is not working under Chrome.  I had used GUI Composer extensively last autumn with the same PC and Chrome.  Clearing the browser cached did not fix the issue.  Chrome was updated to the latest version 122.0.6261.70 today and the issue remains.
  • Chrome is typically well supported by GUI Composer. I'm not sure why you are having issue there while Edge (which is Chromium based) is fine. I'll need to investigate further.
  • Hi Mark,
    Could you give this another try today and see if the issue persists on Chrome?
    ki
  • It is the same today.
    FYI...I tried my home network, no change.  I disabled the ad blocker, set zoom to 100%, and allowed 3rd party cookies.  No changes after all of these.
    Perhaps it some Chrome setting, although I don't recall making changes.   From a quick look, I do not see any obvious settings that might impact the site.
  • Thanks Mark. We are still investigating. We can't seem to reproduce the issue on our end yet so it is taking some time.
  • Mark - On chrome, can you open the debug console in the browser provide the console messages/errors?
    To so do:
    Open GC, once the windows are shown, press F12 to open Chrome Development Tools, then switch to Console tab (red box), right click in console output and choose “Save As.
  • The log file is attached.
    utag.266.js?utv=ut4.39.202311032045:3 Refused to load the script 'https://img.en25.com/i/elqCfg.min.js' because it violates the following Content Security Policy directive: "script-src 'self' https://*.ti.com  https://*.akamaihd.net https://code.jquery.com https://tags.tiqcdn.com https://*.tealiumiq.com https://*.google-analytics.com https://*.googletagmanager.com https://*.googleadservices.com https://googleads.g.doubleclick.net https://*.decibelinsight.net https://*.abtasty.com wss://*.decibelinsight.net https://*.brightcove.net https://*.px-cloud.net https://*.3playmedia.com https://*.zencdn.net data: blob: 'unsafe-inline' 'unsafe-eval'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
    u.loader @ utag.266.js?utv=ut4.39.202311032045:3
    utag.272.js?utv=ut4.39.202311032045:3 Refused to load the script 'https://img.en25.com/i/elqCfg.min.js' because it violates the following Content Security Policy directive: "script-src 'self' https://*.ti.com  https://*.akamaihd.net https://code.jquery.com https://tags.tiqcdn.com https://*.tealiumiq.com https://*.google-analytics.com https://*.googletagmanager.com https://*.googleadservices.com https://googleads.g.doubleclick.net https://*.decibelinsight.net https://*.abtasty.com wss://*.decibelinsight.net https://*.brightcove.net https://*.px-cloud.net https://*.3playmedia.com https://*.zencdn.net data: blob: 'unsafe-inline' 'unsafe-eval'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
    u.loader @ utag.272.js?utv=ut4.39.202311032045:3
    ti-core-assets.html.js:187 Help for gc.console:
    To see logs for a particular module, set a cookie for that module name (e.g. gc.console.setCookie('ti-core-backplane',5) ).
    To see logs for all modules, use a module name of 'all (e.g. gc.console.setCookie('all',5) ).
    To see the location that logged the message, click on the triangle to the left of the message to expand the stack trace.
    Colors: Red: error, Orange: warning, Black: info or a generic log, Blue: debug.
    Commands: the following function calls can be called from the Chrome dev tools console window command line:
    gc.console.setCookie(moduleName,<0-5>)
     - creates a cookie for the specified module name. Use 'all' for all modules.
     - value: 0 = remove the cookie, 1 = only errors, 2 = errors and warnings, 3 = errors,warnings,info, 4 = errors,warnings,info,logs, 5=debug+all others
    gc.console.getCookies()
     - dynamically updates any added or removed cookies and returns a list of all currently active cookies and their values.
    gc.console.log(moduleName,msg)
    - To log messages, use gc.console.log / gc.console.error / gc.console.warning / gc.console.info / gc.console.debug
     This file is deprecated. Please use `iron-flex-layout/iron-flex-layout-classes.html`, and one of the specific dom-modules instead
    (anonymous) @ v2/components/iron-f…ex-layout.html.js:2
    ti-guicomposer-editor-area.html.js:129 [Deprecation] Listener added for a synchronous 'DOMNodeInserted' DOM Mutation Event. This event type is deprecated (https://w3c.github.io/uievents/#legacy-event-types) and work is underway to remove it from this browser. Usage of this event listener will cause performance issues today, and represents a risk of future incompatibility. Consider using MutationObserver instead.
    ready @ ti-guicomposer-editor-area.html.js:129
    color-editor.html.js:45 this.value =
    ti-core-splitter.html.js:148 targetChanged: target=transportSelectionPanel[minWidth]=undefined
    ti-core-splitter.html.js:137 update: dimension=width, horiz=false
    ti-core-splitter.html.js:148 targetChanged: target=transportSelectionPanel[minWidth]=100px
    workspace/default//project.json:1
           Failed to load resource: the server responded with a status of 404 ()
    GcConsole.ts:357 Enter "gc.console.help() + <enter>" to see help info for GcConsole logging.
    GcConsole.ts:109 [myapp] info: index.js is loaded...
  • Thanks. Engineering took a look and suggested clearing the local storage.
    • Select the Application tab
    • Select the Local Storage -> http://dev.ti.com node on the left
    • Select the gc.designer key, right click and select delete
    • Press F5 to reload the designer
  • Hello Ki,
    I did as suggested, and no luck.  The log from the developer tools is below, and it looks similar to what I had seen before.
    u.send @ utag.266.js?utv=ut4.39.202311032045:16
    sendTag @ utag.js:440
    trigger @ utag.js:441
    track @ utag.js:431
    utag.track @ utag.js:816
    view @ utag.js:431
    (anonymous) @ utag.266.js?utv=ut4.39.202311032045:5
    window.onload @ utag.js:467
    load (async)
    window.addLoadEvent @ utag.js:467
    u.extend @ utag.273.js?utv=ut4.39.202401242034:112
    execute_send @ utag.273.js?utv=ut4.39.202401242034:123
    u.send @ utag.273.js?utv=ut4.39.202401242034:119
    LOAD @ utag.js:420
    (anonymous) @ utag.273.js?utv=ut4.39.202401242034:146
    u.send @ utag.272.js?utv=ut4.39.202311032045:14
    track @ utag.js:431
    view @ utag.js:431
    (anonymous) @ utag.272.js?utv=ut4.39.202311032045:5
    window.onload @ utag.js:468
    load (async)
    LOAD @ utag.js:420
    iron-shadow-flex-layout.html.js:2 This file is deprecated. Please use `iron-flex-layout/iron-flex-layout-classes.html`, and one of the specific dom-modules instead
    (anonymous) @ iron-shadow-flex-layout.html.js:2
    iron-flex-layout.html.js:2 This file is deprecated. Please use `iron-flex-layout/iron-flex-layout-classes.html`, and one of the specific dom-modules instead
    (anonymous) @ iron-flex-layout.html.js:2
    _readySelf @ polymer-mini.html.js:157
    _ready @ polymer-mini.html.js:137
    _readyClients @ polymer-mini.html.js:144
    _ready @ polymer-mini.html.js:132
    _tryReady @ polymer-mini.html.js:122
    _initFeatures @ polymer.html.js:4140
    __initialize @ polymer-micro.html.js:227
    createdCallback @ polymer-micro.html.js:210
    created @ webcomponents-lite.js:2220
    upgradeWithDefinition @ webcomponents-lite.js:2188
    upgrade @ webcomponents-lite.js:2176
    added @ webcomponents-lite.js:1981
    (anonymous) @ webcomponents-lite.js:1990
    (anonymous) @ webcomponents-lite.js:1922
    findAllElements @ webcomponents-lite.js:1938
    findAllElements @ webcomponents-lite.js:1939
    forSubtree @ webcomponents-lite.js:1921
    addedSubtree @ webcomponents-lite.js:1989
    addedNode @ webcomponents-lite.js:1978
    upgradeDocument @ webcomponents-lite.js:2139
    _forDocumentTree @ webcomponents-lite.js:1967
    forDocumentTree @ webcomponents-lite.js:1953
    upgradeDocumentTree @ webcomponents-lite.js:2144
    register @ webcomponents-lite.js:2266
    window.Polymer @ polymer-micro.html.js:55
    (anonymous) @ ti-guicomposer-app.html.js:2
    v2/components/font-awesome/fontawesome-webfont.woff:1
           GET https://dev.ti.com/gc/v2/components/font-awesome/fontawesome-webfont.woff net::ERR_ABORTED 404 (Not Found)
    v2/components/font-awesome/fontawesome-webfont.ttf:1
           GET https://dev.ti.com/gc/v2/components/font-awesome/fontawesome-webfont.ttf net::ERR_ABORTED 404 (Not Found)
    Mark
  • Thanks for trying. Can you start a private E2E discussion with me?
