Other Parts Discussed in Thread: CCSTUDIO
in the Details>> I see, "File /UnitTests/.project is read-only."
I extracted files form source control in order to work on integrating CCS4 into our build system. I just finished putting in relative links so that I can build in other directories. apparently CCS4 does not understand source control. the files are read-only until they are checked out for edit. I am not editing, I am building. the files will all be read-only.
I suspect this in a problem inherent in CCS4. this post is in hope of a solution. if not, then a suggestion for a fix.
